AaronChicago Posted June 4, 2017 Share Posted June 4, 2017 I've had a hell of time editing 4K anamorphic 4:3 footage from the GH5. I guess it's the scaling that is slowing it down. Do any of you guys transcode your footage into the stretched aspect before you start editing? Georgios 1 Link to comment Share on other sites More sharing options...
Bioskop.Inc Posted June 4, 2017 Share Posted June 4, 2017 3 hours ago, AaronChicago said: I've had a hell of time editing 4K anamorphic 4:3 footage from the GH5. I guess it's the scaling that is slowing it down. Do any of you guys transcode your footage into the stretched aspect before you start editing? What I do, with FCPX, is create a timeline with the desired stretch format (2048x858 - 2k 2.39:1) & then stretch the footage - as i'm shooting on 16:9, the edges do fall outside the timeline's borders. It all depends on what your NLE will let you do - some might not let you make custom timeline sizes & then you'll just have to adjust the height of anamorphic footage, so you end up with black bars on the top/bottom. If you still have to transcode your footage to an editable format, then yes, your best option is to do the stretch/squeeze then. I stick to Cinema DCP standards: http://unravel.com.au/files/Unravel_Resolution_CheatSheet.pdf AaronChicago and Bold 2 Link to comment Share on other sites More sharing options...
AaronChicago Posted June 4, 2017 Author Share Posted June 4, 2017 9 minutes ago, Bioskop.Inc said: What I do, with FCPX, is create a timeline with the desired stretch format (2048x858 - 2k 2.39:1) & then stretch the footage - as i'm shooting on 16:9, the edges do fall outside the timeline's borders. It all depends on what your NLE will let you do - some might not let you make custom timeline sizes & then you'll just have to adjust the height of anamorphic footage, so you end up with black bars on the top/bottom. If you still have to transcode your footage to an editable format, then yes, your best option is to do the stretch/squeeze then. I stick to Cinema DCP standards: http://unravel.com.au/files/Unravel_Resolution_CheatSheet.pdf Yeah I actually don't mind having the black bars in a 1920x1080 or 3840x2160 file. The scaling playback is just so slow. I can play 4K or 10 bit GH5 files just fine in Premiere (other than anamorphic stretched). Link to comment Share on other sites More sharing options...
nahua Posted June 4, 2017 Share Posted June 4, 2017 I just transcode direct - no stretching. I did this with the "5K" h265 4:3 files. Transcode h265 to ProRes. Then in Premiere, just change the aspect ratio to 2:1 (interpret footage). Plays back fine. Or you could use Davinci. But I let the program stretch the footage, not the transcode stage. Link to comment Share on other sites More sharing options...
Ian Edward Weir Posted June 6, 2017 Share Posted June 6, 2017 On 6/4/2017 at 10:07 AM, AaronChicago said: I've had a hell of time editing 4K anamorphic 4:3 footage from the GH5. I guess it's the scaling that is slowing it down. Do any of you guys transcode your footage into the stretched aspect before you start editing? I do it in my work flow. I shoot GH4 4:3 4k with 1.75x and stretch to 5k 2.35:1 - 5120x2179. I then build a dailies sequence and do a media management transcoding to Pro Res or go clip by clip adding an in and out. I export out 5k Pro Res and then edit and finish on a 4k timeline 3840x2160. I have a Mac Book Pro from 2012 and it works like a charm. I do allot of nature films and do it this way so I have a collection of 5k pro res footage. AaronChicago 1 Link to comment Share on other sites More sharing options...
AaronChicago Posted June 6, 2017 Author Share Posted June 6, 2017 The stretching of the footage is what slows it down for me. I can play back the 4:3 4K files in Premiere no problem. As soon as and adjust the scale to 58% x 29% it drags. Link to comment Share on other sites More sharing options...
Ian Edward Weir Posted June 6, 2017 Share Posted June 6, 2017 2 minutes ago, AaronChicago said: The stretching of the footage is what slows it down for me. I can play back the 4:3 4K files in Premiere no problem. As soon as and adjust the scale to 58% x 29% it drags. It slows you down because your messing with H264, which is always a night mare. I can't edit at all with H264 or computer crashes. I dump out 5k Pro Res and everything works great. If you are doing music video or something small I would transcode. Feature or documentary maybe not. Link to comment Share on other sites More sharing options...
Todd Matthews Posted June 7, 2017 Share Posted June 7, 2017 I had the same issue, but editing via proxy in Premiere resolved that. 720p worked fine and left plenty of headroom without requiring a lot of extra space. Link to comment Share on other sites More sharing options...
