Adobe Media Encoder Error -1609629695
A Furry Peanut
Does anyone know why this is happening? I have tried:
- deleting and undeleting the clips from my timeline
- copying and pasting onto new sequence
- copying and pasting onto new project
- renaming my premiere pro file
- saving premiere pro to a different location (desktop) with different name then exporting to a different location,
- change the renderer in AME from GPU Acceleration to Software Only
- exporting directly from premiere pro instead of AME
All the above methods did not work, the only solution I have found was exporting in a different format then converting it to mp4 however I was wondering if there was another way around this. I also noticed that whenever I try to export the "Around timecode" and "Rendering at offset" in the error message would be different but the "Error code" would always be -1609629695
The errors happens "around timecode 1:22:04
You could try to nest this sequence or render the clip at this time and insert the rendered clip back it in your timeline
Also, during export, pick QUEUE, then you can choose to render using CPU or GPU. Sometime using CPU fixes the problem (but it will take more time to render)
Hi had this one recently, this is a "cuda - GPU out of memory error".
You should close your other programs (even your web browser and such as they use Video Ram) and restart premiere and start rendering
I recommend using AME "alone" to render it as there will be more ram available as premiere will be openned "headless" if oppened by AME for rendering.
If you're stuck, render with GPU only (but restart Premiere before rendering as switching from GPU to CPU might not empty ram)
I have quite some problems with recent versions of Pr/Ae as my GPU is quite old now. The latest Cuda core takes waaay more gpu ram and GPUs under 2Gig of ram struggle :s
Let us know if you have any success ;)
Expand
Expand
I have already tried these two suggestions and unfortunately they have not worked for me :(
  On 6/7/2017 at 7:42 PM, jcs said:
@A Furry Peanut try disabling the Lumetri effect, which is where the error is reportedly happening. If that fixes the issue, recreate the Lumetri settings, one at a time until you find what is causing the error.
Expand
I have too many clips with lumetri so instead I used "Global fx mute" and even with all the effects turned off, I still got the same error. Although in hindsight I do believe that rendering in a different format then converting to mp4 is more efficient then going through every clip with lumetri and disabling/enabling to see where the problem lies haha.
  On 6/8/2017 at 3:53 AM, A Furry Peanut said:
3.5gb video card memory, for this specific project I used Red Giant's DeNoiser III and Universe. Project is 1080p at 29.97 fps filmed with canon 70D and t7i.
Expand
Trying to find out how many screens..
Can you go into the effects panel and make sure that nenoiser is at the very top of the effects list, ie. above lumetri
Expand
I had this issue as well, copied all my luts to AME's Lumetri/Creative folder, and it solved the problem.
  On 6/8/2017 at 5:46 AM, A Furry Peanut said:
Not to my knowledge, and I tried exporting with "Global fx mute" which is supposed to mute all effects including lumetri and I still got the problem.
Expand
If you export the sequence from premiere, does it behave the same? The only thing which comes in my mind is to clear all cache, restart computer and try again.
Expand
Yes, and I just tried clearing all cache and restarting but unfortunately that did not work either.
Oh well, this has been the only project where I have encountered this problem and hopefully it stays that way. Thanks to everyone for trying to help :)
