GH5 int 8 bit conversion magenta-cast
Fellow GH5 users, something that I have seen from day 1 using the GH5 is that when developing raw pictures internally, they almost always had a magenta cast, so I always had to dial the hue-wheel against green, before converting to jpg and sending them to my phone over Wi-Fi.
Today I too discovered the clear difference in color cast when using VLOG-L in 10 bit vs 8 bit. A lot of magenta / green going on in the shadows when shooting 8 bit. Maybe even more pronounced when filming 1080p. I'll post some screen shots in the bottom of the post.
I wonder, could there be a connection since both raw-files processed in camera to 8bit jpg, and vlog-footage processed to 8bit turns against magenta. The 8 bit conversion conspiracy.. :lol:
What I really want to know is if I'm the only one getting this color cast when processing raw-files internally or if maybe there is a trend amongst other users as well.
By the way, white balance set to daylight. There's a green tree outside the window so the color cast should more be against green.
25p8bit
25p10bit
50p8bit
