enny Posted June 10, 2017 Share Posted June 10, 2017 Hi guys looking to get a budged friendly looking at FEELWORLD F7 7 it has only HDMI connection where BMCC has SDI i am looking use hdmi to sdi converter do you guys see any issues here with 50 dollars converters or just get a proper sdi monitor. Thanks Link to comment Share on other sites More sharing options...
Juxx989 Posted June 11, 2017 Share Posted June 11, 2017 I found this best view monitor on ebay for $100 bucks $200 bucks new on amazon... It works great with both my NX-1 and BMPCC its allegedly 10 bit, has false color crystal clear wave form audio speaker headphone jack... Composite In + out.. HDMI in + Out. Can use Canon or Sony batteries with the included adapters... Only complaints I have is its 7" which is fairly big and it has no battery level display so you dont know until about 3-5 mins before shut off the power button changes color... also Ive heard that on these cheaper monitor models is when you turn them off they still drain the battery unless you unplug them this one counters that with a "Master" power switch that completely stops the drain.... then a standby power switch I would say max to spend is $200 if you go beyond that you may as well get a used Recorder/monitor Like Atomos or BM Video assist- https://www.amazon.com/BESTVIEW-S7-camera-monitor-19201200/dp/B01MXBPW27/ref=sr_1_2?ie=UTF8&qid=1497161658&sr=8-2&keywords=Bestview+S7 http://www.ebay.com/itm/Bestview-S7-7-DCI-4K-HDMI-DSLR-LCD-Monitor-With-Full-HD-Display-1920-x-1200-5D2-/272661718435?hash=item3f7be7a5a3:g:4tgAAOSwjL5ZD1WJ Link to comment Share on other sites More sharing options...
