Linus N Posted June 15, 2017 Share Posted June 15, 2017 Hey fellow forumites! As I'm sure all eager GH5 owners have seen, Adobe came out with version 11.1.2 of Premiere Pro CC with added support for GH5 10bit files. YAY! Or at least that was my facial expression until I got into Premiere only to realize my Program window only shows a zoomed view of the top left corner of my footage. Regardless of 1080p/4K footage, sequence resolution or other applied scaling the issue is there. Come on, Adobe... really? I have no solution other than downgrading (again) to 11.0.X to get my files working "properly" again. Curious what other people's experiences are, and if anyone has a solution for the top left crop. For now I've moved this particular project over to Resolve 14 which handles the files just fine. Link to comment Share on other sites More sharing options...
Brother Posted June 15, 2017 Share Posted June 15, 2017 Posted this in another thread: "The only thing you have to turn on is the "High Quality Playback" setting. Once that is on you can select different playback resolutions like 1/8 and it will reduce the quality and it won't zoom in." Found this in a Facebook group but haven't tried it yet. AaronChicago 1 Link to comment Share on other sites More sharing options...
Linus N Posted June 15, 2017 Author Share Posted June 15, 2017 3 hours ago, Brother said: Posted this in another thread: "The only thing you have to turn on is the "High Quality Playback" setting. Once that is on you can select different playback resolutions like 1/8 and it will reduce the quality and it won't zoom in." Found this in a Facebook group but haven't tried it yet. Ooh! I'll give it a try after this House of Cards episode HelsinkiZim 1 Link to comment Share on other sites More sharing options...
Orangenz Posted June 17, 2017 Share Posted June 17, 2017 On 2017-6-16 at 0:25 AM, Linus N said: Hey fellow forumites! As I'm sure all eager GH5 owners have seen, Adobe came out with version 11.1.2 of Premiere Pro CC with added support for GH5 10bit files. YAY! Or at least that was my facial expression until I got into Premiere only to realize my Program window only shows a zoomed view of the top left corner of my footage. Regardless of 1080p/4K footage, sequence resolution or other applied scaling the issue is there. Come on, Adobe... really? I have no solution other than downgrading (again) to 11.0.X to get my files working "properly" again. Curious what other people's experiences are, and if anyone has a solution for the top left crop. For now I've moved this particular project over to Resolve 14 which handles the files just fine. No problem with the main monitor here but any footage at all (ie. not GH5 related) now appears zoomed in as you describe on the secondary 1080 monitor. Link to comment Share on other sites More sharing options...
Orangenz Posted June 18, 2017 Share Posted June 18, 2017 On 2017-6-17 at 3:01 PM, Orangenz said: No problem with the main monitor here but any footage at all (ie. not GH5 related) now appears zoomed in as you describe on the secondary 1080 monitor. My two monitors where running different frequencies (60 and 50Hz). Unenabling then reconnecting to the 2nd monitor fixed it so all working well again both at 60Hz. Link to comment Share on other sites More sharing options...
