kgv5 Posted June 16, 2017 Share Posted June 16, 2017 Hi, i am interested in buying used sigma 8-16 for my ursa mini 4.6k for certain "dramatic" UWA shots, does anybody knows if it will cover UM sensor at 8mm? Will it vignette? Maybe somebody tried 8-16 on 1dx II (4k cropped about 1.4x)? UM sensor is slightly larger than APS-c (1.38 vs 1.6x crop) so i dont know...If it doesnt work at 8mm there is no point of having this lens, it is better to buy canon 10-18 STM which works great @10mm even with filter. What do you think? In this test i was using 10-18 on 11mm because i had huge firecrest 100mm filter holder attached (polarizer+grad) and it vignetted on 10mm, 10mm was good with just a polarizer screwed on though. Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted June 16, 2017 Super Members Share Posted June 16, 2017 I can't give you the definitive answer regarding the exact combination you're after but I've got an 8mm Samyang that I've put on a Nikon D800 to do a quick test for you. The D800 is obviously full frame but does auto crop at 1.2 and 1.5 so these examples show you exactly what it covers at full frame, 1.2 and 1.5 Judging by that, I'd say you'll probably get away with it. Maybe jonpais 1 Link to comment Share on other sites More sharing options...
kgv5 Posted June 16, 2017 Author Share Posted June 16, 2017 @BTM_Pix, thank you very much, when i change the size of fullframe sitll you posted to 140 percent it shows some dark corners, probably it would work at around 8,2-8,5mm and 2,35:1 aspect ratio without any problem. Thanks again. Link to comment Share on other sites More sharing options...
tweak Posted June 16, 2017 Share Posted June 16, 2017 I think it will probably work, because it works with a metabones SB on m4/3. Link to comment Share on other sites More sharing options...
kgv5 Posted June 16, 2017 Author Share Posted June 16, 2017 I have ordered the lens, I shoud have it next week so i will post the results. I couldnt find anything about sigma 8-16 with ursa mini 4.6k so it shoud be interesting Now I wish i had ursa pro with internal NDs, i will not be able to screw my firecrests on 8-16... Link to comment Share on other sites More sharing options...
AaronChicago Posted June 16, 2017 Share Posted June 16, 2017 I get a small amount of vignetting at 18mm with the Sigma 18-35 on the 4.6K. Link to comment Share on other sites More sharing options...
Turboguard Posted June 18, 2017 Share Posted June 18, 2017 Interested to see your results. How much wider can you really go? 8mm is insane, I use a 10mm on Bmpcc with speedbooster and I can basically see my own shoulders, lol Not exactly maybe, but if I stretch out my arm I can see half of my upper arm so maybe 6" from my shoulder. Here's an test video I did when I got the lens. andrgl 1 Link to comment Share on other sites More sharing options...
kgv5 Posted June 18, 2017 Author Share Posted June 18, 2017 I was able to get the answer from blackmagic forum. 8mm shows only very slight vignetting on UM4.6K full sensor readout, totally usable IMO. https://forum.blackmagicdesign.com/viewtopic.php?f=2&t=60592&sid=94dfac12855cd4840fd19a1ead5504e8 I will have this lens in the next couple of days so I will make some tests (and maybe comparison with canon 10-18 STM). Link to comment Share on other sites More sharing options...
andrgl Posted June 19, 2017 Share Posted June 19, 2017 On 6/18/2017 at 2:41 AM, Turboguard said: Interested to see your results. How much wider can you really go? 8mm is insane, I use a 10mm on Bmpcc with speedbooster and I can basically see my own shoulders, lol Not exactly maybe, but if I stretch out my arm I can see half of my upper arm so maybe 6" from my shoulder. Here's an test video I did when I got the lens. Expand Checked your post and video description, I must be daft because I couldn't see what lens you shot with... can you help me out? Link to comment Share on other sites More sharing options...
Turboguard Posted June 22, 2017 Share Posted June 22, 2017 On 6/19/2017 at 12:33 AM, andrgl said: Checked your post and video description, I must be daft because I couldn't see what lens you shot with... can you help me out? Expand It's the Rokinon 10mm T3.1 Cine DS. Also, obviously added post cinescope bars which cover up more of the image! Link to comment Share on other sites More sharing options...
