Administrators Andrew Reid Posted June 22, 2017 Administrators Share Posted June 22, 2017 The Canon 100D is £250 used and I have always had a bit of a soft spot for it, being the smallest and lightest Canon DSLR body. I recently installed an experimental version of Magic Lantern on the 100D and am absolutely taken-aback by how good the image is! It practically eliminates moire and softness. The 100D shoots continuous 1.7K RAW video in 25p and 24p to SD card. Read the full article benymypony, kaylee, tupp and 2 others 5 Link to comment Share on other sites More sharing options...
mercer Posted June 22, 2017 Share Posted June 22, 2017 Sounds pretty cool. Do you think this would make a better B-cam to a 5D3 than a 70D would, for second unit, due to the lack of moire? I always shoot in 2:35 with my 5D3. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted June 22, 2017 Author Administrators Share Posted June 22, 2017 Moire is not 100% absolutely completely gone but it is FAR better than the 100D out of the box video mode! Yes a good second unit to a 5D3, but it depends on how you use it. The 70D is double the price but has the benefit of articulated screen and Dual Pixel AF. I have always had a soft spot for the 100D though with it being so small and light compared to 5D3 and even the 70D. 80D, EOS M5 have a brighter future if ML port ever comes to fruition, which I think it will do eventually! mercer 1 Link to comment Share on other sites More sharing options...
tupp Posted June 22, 2017 Share Posted June 22, 2017 Thanks for this article. Very helpful! From your article: 51 minutes ago, Andrew Reid said: For post processing you need an app called MLVFS (download) for MacOS or Windows. MLVFS also works in most Linux distros (and, consequently, probably in Android as well). It's just a simple compile using "make." Link to comment Share on other sites More sharing options...
BenEricson Posted June 22, 2017 Share Posted June 22, 2017 This is really cool. So compact. Can this do 60p or 48p at 10 bit in raw? I love the 5D3 Raw image, but something cheaper that I could throw on a tripod would be awesome. Link to comment Share on other sites More sharing options...
alanpoiuyt Posted June 22, 2017 Share Posted June 22, 2017 This guy shoots amazing stuff on an eos M with Magic Lantern & crop mode Christina Ava, samuel.cabral, mercer and 1 other 4 Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted June 22, 2017 Super Members Share Posted June 22, 2017 1 hour ago, mercer said: Sounds pretty cool. Do you think this would make a better B-cam to a 5D3 than a 70D would... You've done it now mentioning the B word haven't you? I've only just finished reading that C200 thread webrunner5, BenEricson, Andrew Reid and 1 other 4 Link to comment Share on other sites More sharing options...
Justin Bacle Posted June 22, 2017 Share Posted June 22, 2017 This is just great news ! I was looking at the 100D yesterday looking at the raw recording capabilities. I have to get one of these ! Link to comment Share on other sites More sharing options...
mercer Posted June 22, 2017 Share Posted June 22, 2017 6 minutes ago, alanpoiuyt said: This guy shoots amazing stuff on an eos M with Magic Lantern & crop mode That looks amazing. I just read the comments and he didn't even use Raw in that video. I think it was just the bitrate hack. It looks great though. That crop mode is amazing. Actually I'm not even sure he uses the bitrate hack. Link to comment Share on other sites More sharing options...
cantsin Posted June 22, 2017 Share Posted June 22, 2017 1 hour ago, tupp said: MLVFS also works in most Linux distros (and, consequently, probably in Android as well). It's just a simple compile using "make." I tried, but it doesn't work.... Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted June 22, 2017 Author Administrators Share Posted June 22, 2017 MLVFS needs FUSE on MacOS, and it does work on Linux but I'd question why you'd even bother with it on Android as the mobile processors don't exactly cut through RAW video in Resolve, do they.... tupp 1 Link to comment Share on other sites More sharing options...
sandro Posted June 22, 2017 Share Posted June 22, 2017 so how is the resolution now? usual canon soft look? Link to comment Share on other sites More sharing options...
mercer Posted June 22, 2017 Share Posted June 22, 2017 27 minutes ago, sandro said: so how is the resolution now? usual canon soft look? Read the article, Reid has screengrabs from clips he took with it. samuel.cabral 1 Link to comment Share on other sites More sharing options...
mercer Posted June 22, 2017 Share Posted June 22, 2017 5 hours ago, Andrew Reid said: Moire is not 100% absolutely completely gone but it is FAR better than the 100D out of the box video mode! Yes a good second unit to a 5D3, but it depends on how you use it. The 70D is double the price but has the benefit of articulated screen and Dual Pixel AF. I have always had a soft spot for the 100D though with it being so small and light compared to 5D3 and even the 70D. 80D, EOS M5 have a brighter future if ML port ever comes to fruition, which I think it will do eventually! Well, I primarily use the 24-70mm f/4 handheld, and am planning on buying that 35mm f/2. My friend also has the 28-135mm, so I was thinking the SL1 could sit in my bag in crop mode. Then when using a prime, but need a quick long shot or some range, I could pull out the SL1. Or maybe it would be a good camera to have the 100mm L macro living on it. Is crop mode a 3X crop of the aps-c? Or is it 5X? Link to comment Share on other sites More sharing options...
tupp Posted June 23, 2017 Share Posted June 23, 2017 7 hours ago, cantsin said: I tried, but it doesn't work.... Right... Did you try turning off your computer and then turning it back on? I've heard that doing so is the best remedy for oversimplified anecdotal computer problems. 6 hours ago, Andrew Reid said: MLVFS needs FUSE on MacOS, and it does work on Linux but I'd question why you'd even bother with it on Android as the mobile processors don't exactly cut through RAW video in Resolve, do they.... Actually, Android can run on x86 processors, and, as I recall, Android was briefly listed as a Linux distribution on Distrowatch in its early days, prior to the Google acquisition. However, I didn't mention the possibility of using MLVFS on Android to suggest that someone should try it. You left out an important OS that runs MLVFS (Linux), and I was merely giving another example of an OS (Android Linux) on which MLVFS could work. MLVFS is open source software, so it can probably be compiled to work on several other platforms (the BSDs notwithstanding). Link to comment Share on other sites More sharing options...
HockeyFan12 Posted June 23, 2017 Share Posted June 23, 2017 Does this work at 24fps 16:9 at 10 bit or is it scope only? Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted June 23, 2017 Author Administrators Share Posted June 23, 2017 4 hours ago, HockeyFan12 said: Does this work at 24fps 16:9 at 10 bit or is it scope only? If you drop the horizontal resolution (it increases the crop though) you can shoot 16:9 7 hours ago, tupp said: Actually, Android can run on x86 processors, and, as I recall, Android was briefly listed as a Linux distribution on Distrowatch in its early days, prior to the Google acquisition. Yeah there is a version for x86, I tried installing it once on the Samsung Tab S Pro (Windows 10 tablet) and it can be installed on the Microsoft Surface Pro 4. The problems is the drivers aren't always reliable so you have missing WiFi, etc. and it needs patching up to work properly... depending on the hardware. Check out ReMix OS. They sell Android x86 pre-installed on tablets that they have programmed it to works on. Issue is still performance and app selection vs MacOS and Windows, it's just not as good for raw video. It's a novelty. Link to comment Share on other sites More sharing options...
tugela Posted June 23, 2017 Share Posted June 23, 2017 21 hours ago, mercer said: Read the article, Reid has screengrabs from clips he took with it. it is ~720p before debeyering, so it is still going to be soft compared to modern hybrid cameras. There is not much you can do about that. Good for the average laptop or cell phone using YouTube, but falling short compared to an oversampled 4K camera when it comes to displaying on a big 4K TV screen. Link to comment Share on other sites More sharing options...
Deadcode Posted June 23, 2017 Share Posted June 23, 2017 15 minutes ago, tugela said: it is ~720p before debeyering, so it is still going to be soft compared to modern hybrid cameras. There is not much you can do about that. Good for the average laptop or cell phone using YouTube, but falling short compared to an oversampled 4K camera when it comes to displaying on a big 4K TV screen. Do i read in another topic there is a complain that RED Weapon's 8K is too "sharp" and you complaining here that a 300 eur camera is too soft even if it's shoots raw? i know, your iphone 7 has better resolution and log with filmic pro... You should read the article... Andrew Reid 1 Link to comment Share on other sites More sharing options...
Roberto Mena Posted June 23, 2017 Share Posted June 23, 2017 Mr. Reid, how did you come up with the resolution of 1.7K RAW for the 100D's magic lantern video? I ask only because I have suspected for a while now that indeed the resolution produced from my 7D with ML MLV video looked almost twice as sharp as its native h.264 codec video and in my head I thought it was probably around 1.5K. Link to comment Share on other sites More sharing options...
