enny Posted June 24, 2017 Share Posted June 24, 2017 So what do you guys use to create sound Fx and mix your your films pro tools or something else Thanks Link to comment Share on other sites More sharing options...
Shirozina Posted June 24, 2017 Share Posted June 24, 2017 Adobe Audition is the obvious solution if you have Premier pro as you can work via dynamic link. If you are not signed up the Adobe suite licence then there are quite a few good standalone options which others will no doubt chip in with. I've not got any reason to use anything other than Audition though. Link to comment Share on other sites More sharing options...
funkyou86 Posted June 24, 2017 Share Posted June 24, 2017 42 minutes ago, Shirozina said: Adobe Audition is the obvious solution if you have Premier pro as you can work via dynamic link. If you are not signed up the Adobe suite licence then there are quite a few good standalone options which others will no doubt chip in with. I've not got any reason to use anything other than Audition though. After several years of working with Logic and other DAWs I found Audition not so user friendly (but this is only my personal opinion, audition is a great piece of SW) , so I compose the sounds in premiere, export the OMF, import the OMF in to DAW and mix it there. Link to comment Share on other sites More sharing options...
Shirozina Posted June 24, 2017 Share Posted June 24, 2017 4 minutes ago, funkyou86 said: After several years of working with Logic and other DAWs I found Audition not so user friendly (but this is only my personal opinion, audition is a great piece of SW) , so I compose the sounds in premiere, export the OMF, import the OMF in to DAW and mix it there. Sounds complicated - what's not so user friendly about Audition? Link to comment Share on other sites More sharing options...
no_connection Posted June 24, 2017 Share Posted June 24, 2017 Reaperhttp://www.reaper.fm/ best one hands down, or up, your choice buggz 1 Link to comment Share on other sites More sharing options...
sondreg Posted June 24, 2017 Share Posted June 24, 2017 I use Cubase, but didn't purchase the full version for OMF support, still works great for me tho, found it to be more user friendly than reaper (which is probably the best for the money). Link to comment Share on other sites More sharing options...
buggz Posted June 24, 2017 Share Posted June 24, 2017 4 hours ago, no_connection said: Reaperhttp://www.reaper.fm/ best one hands down, or up, your choice I too like this, I purchased it. Thought long and hard about buying into the Protools stuff, but then, didn't like the idea, too much like the arrogant Adobe world I abandoned. Link to comment Share on other sites More sharing options...
majoraxis Posted June 24, 2017 Share Posted June 24, 2017 Reaper here as well. Eventually I hope it will be on the Fairlight Audio tab of Resolve 14, but I have yet to explore and test it. Link to comment Share on other sites More sharing options...
sondreg Posted June 24, 2017 Share Posted June 24, 2017 IMO what DAW you use doesn't really matter other than personal preference, what does matter is plugins I usually use Waves, grabbed the Gold-bundle and the API-560 EQ a while back and those have been my gotos, X-Noise is pretty neat too but haven't purchased that one yet. Link to comment Share on other sites More sharing options...
Liam Posted June 24, 2017 Share Posted June 24, 2017 I like Audacity.. but it's basically all I've even looked at since it's the free one. I've heard it's limited compared to others, which I believe, but I've never felt too trapped Kisaha 1 Link to comment Share on other sites More sharing options...
IronFilm Posted June 26, 2017 Share Posted June 26, 2017 On 6/25/2017 at 6:55 AM, Liam said: I like Audacity.. but it's basically all I've even looked at since it's the free one. I've heard it's limited compared to others, which I believe, but I've never felt too trapped Audacity is actually pretty good, plus is the best price.... FREE! (is, open source) Link to comment Share on other sites More sharing options...
