C/Y speedboster adapters
enny
Hi guys I have bmcc with CY spedboster looking for wide angle lenses like 18 15 but my choice is limited since I need cy mount can I use other adapters like cy to canon adapter on my spedboster  so I can use 15 mm 2.8 canon lens
23 hours ago, Shirozina said:
No as the flange distance is wrong. Better to trade your Speedbooster for an EF version and then convert your CY lenses to EF with adapters.
That sucks, so basicly with EF Speedbooster i will be able to use my yashica lenses with adapter?
2 One more question if you don't mind meatbons has Canon EF Lens to BMCC T Speed Booster 0.64x and 0.58x what am i looking at here between 64x and 58x and EF is basicly canon mount lenses like Canon FD 17mm F/4 S.S.C that i am planing to buy
Thanks again
Thanks again
Canon FD is different to EF and will need a separate speedbooster or some major lens surgery to change ( shorten) the mount to EF.
You need to adapt to EF with Edmika adapter. Pretty easy to do, will cost 75dollars.
1 hour ago, Shirozina said:
What's so special about the FD 17mm that it's worth adapting it for?
I don't think it's particularly special. Most vintage ultrawides aren't. But it's got super low distortion and can look nice depending upon what your going for. I'd say it's best on full frame though, kind of pointless on APSC or at least not that special.
Instead of spending money on new booster what do you think about Carl Zeiss Distagon T* 18mm F4. Looking for a wide angle lens or Tokina 17mm F/3.5 Lens For Contax C/Y i have about 600 dollars to spend
