adminkatana Posted February 20, 2018 Share Posted February 20, 2018 On 13/02/2018 at 9:03 AM, hyalinejim said: You get different options depending on whether you have mlv_rec or mlv_lite modules loaded. MLV LITE: If you go into the menu for RAW Video you should see an item for Data Format - you can change bit depth and compression. Lossless plus slightly lower bit depth allows longer recording times, higher frame rates, higher resolutions in crop_rec. There is no sound, or at least there wasn't last time I looked into this. But read this https://www.magiclantern.fm/forum/index.php?topic=16650.msg192161#msg192161) MLV REC: You can change bit depth only Thank you! I have been browsing ML forums for the past few nights/ downloading various versions of the nightly builds and nothing has enabled the crop record mode for me or the ability to choose the Data Format. However, clicking your link took me through to a version that finally added this functionality! (I don't understand why it was so difficult to find?) Quote Link to comment Share on other sites More sharing options...
AZGeorge Posted February 20, 2018 Share Posted February 20, 2018 On 2/7/2018 at 4:33 AM, Alpicat said: I had the same problem with MLVFS lossless compressed raw files from my EOS M - could only see noise. I think there's an updated version which supports lossless raw but couldn't find it. I'm now using a program called MLV App which works fine with lossless. It also allows you to batch convert the files directly from card into computer if you want it to (similar to mlvfs). I'm using the QTv0.13alpha version of the program: https://ilia3101.github.io/MLV-App/ Thank you so much. Yes, it worked perfectly. I converted my crop MLV into a .mov with the first try. FYI there is now have a '14' version out there. For me, this workflow is better than the MLVFS track. I use Resolve, but I also use Vegas Pro Edit too, because it is so quick and easy. After using MLV App and exporting as .mov, I can import the file into either one and go from there. Alpicat 1 Quote Link to comment Share on other sites More sharing options...
kidzrevil Posted February 21, 2018 Share Posted February 21, 2018 Upscaled 4K hdr witih the 5d mark iii. Im amazed at how far you can push the mark iii in raw Quote Link to comment Share on other sites More sharing options...
ragunaath Posted February 22, 2018 Share Posted February 22, 2018 Hi, I went through the post and discussions related to RAW recording, we are going to shoot a short film on 5D MK III, it's my friend's camera and he has 95 Mbps Sandisk SD card. I tried the RAW calculator, we intend to shoot 1920 x 818 as a 2.35:1 aspect ratio. The calculator shows 62.8 MB/s for 14bit uncompressed RAW. Also when I choose, 12 bit or 10 bit, it shows 53.9 MB/s and 44.9 MB/s respectively. 1. Is Sandisk 90 Mbps Extreme Pro SD card or 120 Mbps CF card, enough to shoot in Uncompressed RAW? 2. If I can go for compressed 12bit or 10bit, is Sandisk 90 Mbps Extreme Pro SD card, enough? Also, It would be helpful, If you could share the link to 10bit / 12bit compressed RAW build (relatively stable) for 5D MK III, I'm little confused on which one to download. Thankyou Quote Link to comment Share on other sites More sharing options...
PannySVHS Posted February 22, 2018 Share Posted February 22, 2018 @kidzrevil Shreeks, the video is not available. Hurry, hurry, hurry, we want to see it. Please don´t hurry, just take your time, stress sucks. Sorry for pushing:) Quote Link to comment Share on other sites More sharing options...
kidzrevil Posted February 22, 2018 Share Posted February 22, 2018 @PannySVHS I deleted it ? im going to make a new one Quote Link to comment Share on other sites More sharing options...
PannySVHS Posted February 22, 2018 Share Posted February 22, 2018 @kidzrevil you better! Quote Link to comment Share on other sites More sharing options...
kidzrevil Posted February 23, 2018 Share Posted February 23, 2018 not HDR but some high bit depth h.265 footage from the Canon 5D mark iii. Upscaled using my technique the image looks clean. Reminds me of the “soft 4K” from the Canon XC10 minus the noise reduction,compression and digital sharpening artifacts from 8-10 bit compressed cameras. It makes upscaling a dream, it enlarges like when people blow up 16mm film to 35mm Quote Link to comment Share on other sites More sharing options...
kidzrevil Posted February 24, 2018 Share Posted February 24, 2018 Quote Link to comment Share on other sites More sharing options...
Alpicat Posted March 2, 2018 Share Posted March 2, 2018 I'm enjoying using magic lantern on the 50D, especially the crop mode. Only downside I'm still trying to work out is that liveview turns pink when you're in crop mode and hit record (with lens IS turned on), so focussing can be a bit tough. Other than that this camera is pretty amazing for video. Here's something I shot with my music, mostly 1920x1080 crop mode, with some shots using full sensor (1568x882). Lens: Canon 17-55mm f2.8. Unfortunately youtube compression does seem to make the image visibly softer than in the original file - I guess the snowfall doesn't help with compression! webrunner5 1 Quote Link to comment Share on other sites More sharing options...
webrunner5 Posted March 2, 2018 Share Posted March 2, 2018 Nice video. But it looks like you have a Hell of a lot of "White Noise" in it LoL. Alpicat 1 Quote Link to comment Share on other sites More sharing options...
kye Posted March 15, 2018 Share Posted March 15, 2018 This is probably a stupid question, but I can't work out how to select some of the resolutions people talk about. When I go into RAW video (MLV) --> Resolution I can only choose from 640, 960, 1280, 1600, etc. People talk a lot about 1344 and other modes but I can't find them. Changing the aspect ratio only changes the vertical resolution, not horizontal. I saw instructions in the EOS-M thread to enable crop_rec module, but that's not in the build I have. I'm using 700D with the 10/12 bit RAW Video experimental build 700D115 (released Jan 31 2018). What am I missing? I must admit that I find ML confusing as hell, even though I have a computer science degree! hang on, are you guys using the crop_rec module? that would make more sense... Quote Link to comment Share on other sites More sharing options...
kye Posted March 15, 2018 Share Posted March 15, 2018 Installed crop_rec but that didn't help me either, I looked in the 3x3 crop mode and used the 720/60fps canon mode but no joy there either. any help would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted March 15, 2018 Super Members Share Posted March 15, 2018 Anyone tried the Canon 20-35mm f2.8 L? I just bought one at a good price. I was actually after the 5D rear cap it came with but might keep the lens to use for a Canon with video in the future. If anyone used it with a 5Diii and ML raw I would love to see the results. Quote Link to comment Share on other sites More sharing options...
kidzrevil Posted March 16, 2018 Share Posted March 16, 2018 Quote Link to comment Share on other sites More sharing options...
Tergelet Posted March 28, 2018 Share Posted March 28, 2018 A great combination of experimenting things. I admire your creativity. Quote Link to comment Share on other sites More sharing options...
SlanderShot Posted March 29, 2018 Share Posted March 29, 2018 Here my last work about my travel in Japan in march 2018. Shot with 5DIII RAW 14bits lossless 1920x1080 29fps EF 24 70mm 2.8 Grade on DR14 + Film Convert / edit on PP CC 2018 cameraeye, mercer and Stathman 3 Quote Link to comment Share on other sites More sharing options...
kidzrevil Posted March 29, 2018 Share Posted March 29, 2018 @SlanderShot what program do you use to convert the lossless dng’s Quote Link to comment Share on other sites More sharing options...
SlanderShot Posted March 29, 2018 Share Posted March 29, 2018 1 hour ago, kidzrevil said: @SlanderShot what program do you use to convert the lossless dng’s Only MLVFS. Quote Link to comment Share on other sites More sharing options...
kidzrevil Posted March 29, 2018 Share Posted March 29, 2018 @SlanderShot ah man Im looking for something that works with windows ? Quote Link to comment Share on other sites More sharing options...
