Brian Williams Posted August 25, 2018 Share Posted August 25, 2018 Here are my tests from the past day with 1736x1120 resolution. https://vimeo.com/286711725 https://vimeo.com/286711914 Using a $30 toy c-mount lens (can't figure out how to embed...) meudig, kaylee, Emanuel and 1 other 4 Link to comment Share on other sites More sharing options...
Brian Williams Posted August 27, 2018 Share Posted August 27, 2018 One more using the mv1080 mode, 1736x1120 14bit raw My color grading skills dont do any of this justice. heart0less and meudig 2 Link to comment Share on other sites More sharing options...
Alpicat Posted August 27, 2018 Share Posted August 27, 2018 @Brian Williams these tests are great and the colours look good! Would be interesting to know what your post production process was. Link to comment Share on other sites More sharing options...
Brian Williams Posted August 27, 2018 Share Posted August 27, 2018 Thanks @Alpicat. For the first few tests I used MLV app to decode the MLV files to DNG, then brought into Resolve 15 for editing and CC. On that last test, I finally got MLVFS to work on my Mac (still no luck on Windows side, just pink DNG's), and after a few strange renders (realized I had to set Chroma smoothing to 2x2 in MLVFS to get rid of some weird patterns that were showing up) I brought those DNG's into Resolve- MLVFS workflow is a great timesaver. Alpicat 1 Link to comment Share on other sites More sharing options...
Alpicat Posted August 27, 2018 Share Posted August 27, 2018 @Brian Williams I'm using Windows and was also getting corrupt files with MLVFS. I don't think it's compatible with lossless raw files, but need to check if there's an updated version. The patterns you were seeing are the focus pixels? MLV App works fine for me and it gets rid of focus pixels automatically without using chroma smoothing, but would be interesting to see if MLVFS produces different results at all with the exported DNGs (in terms of colour and image quality). Link to comment Share on other sites More sharing options...
Brian Williams Posted August 27, 2018 Share Posted August 27, 2018 4 minutes ago, Alpicat said: @Brian Williams I'm using Windows and was also getting corrupt files with MLVFS. I don't think it's compatible with lossless raw files, but need to check if there's an updated version. The patterns you were seeing are the focus pixels? MLV App works fine for me and it gets rid of focus pixels automatically without using chroma smoothing, but would be interesting to see if MLVFS produces different results at all with the exported DNGs (in terms of colour and image quality). I guess they were focus pixels, it was a clear pattern in the center- I didn't realize focus pixels we're a thing. And yes, MLV app fixed it automatically, but MLVFS is such a quicker process, even with the Chroma smoothing turned on, so I think I will stick with that. MLVFS seems to work fine with lossless DNG's on the Mac side, and it's as easy as a mouse click (no cmd prompt or terminal needed). Link to comment Share on other sites More sharing options...
mercer Posted August 27, 2018 Share Posted August 27, 2018 2 hours ago, Brian Williams said: I guess they were focus pixels, it was a clear pattern in the center- I didn't realize focus pixels we're a thing. And yes, MLV app fixed it automatically, but MLVFS is such a quicker process, even with the Chroma smoothing turned on, so I think I will stick with that. MLVFS seems to work fine with lossless DNG's on the Mac side, and it's as easy as a mouse click (no cmd prompt or terminal needed). Nice work and yes, MLVFS are like magic and turn a somewhat tedious process into a piece of cake. But I will say that I really like the MLV App’s implementation of a LogC curve. It works brilliantly with basic LogC to Rec709 LUTS or corrects/grades simply with some simple curves and saturation. So for anybody who uses a different NLE than Resolve and is looking for a quick ProRes conversion, the MLV App is great. To add, I cannot stress this enough... I love what you guys are getting with the eos-m... it really is the camera that keeps on giving thanks to ML. I know these are shot with the experimental Raw builds and SD card overclocking mixed with crop mode and whatever other voodoo the ML team has figured out, but has there been any advancements with the bitrate hack? With the crop mode, it always seemed like a good compromise between quality and ease of use. Also what other cameras benefit from these new builds? I’d love to see the 70D with this quality and DPAF. Link to comment Share on other sites More sharing options...
Brian Williams Posted August 27, 2018 Share Posted August 27, 2018 2 hours ago, Alpicat said: @Brian Williams I'm using Windows and was also getting corrupt files with MLVFS. I don't think it's compatible with lossless raw files, but need to check if there's an updated version. The patterns you were seeing are the focus pixels? MLV App works fine for me and it gets rid of focus pixels automatically without using chroma smoothing, but would be interesting to see if MLVFS produces different results at all with the exported DNGs (in terms of colour and image quality). As I'm reading more, I'm hearing that chroma smoothing, while getting rid of focus pixels, degrades the image- is this true? If so, I guess the MLV app may be a better way to go. Link to comment Share on other sites More sharing options...
Alpicat Posted September 6, 2018 Share Posted September 6, 2018 @Brian Williams with MLVFS I think there might be an option to remove focus pixels in the same way that MLV App does (with a focus pixel map) but don't remember what the option was called. Chroma smoothing supposedly does degrade image quality slightly - but probably not noticeable most of the time. @mercer I've tried converting mlvs to prores (using the LogC curve) on MLV App, and I agree the results are great! Interestingly with the EOS M I found that when I exported some shots to prores, it got rid of aliaising and moire, which remained an issue when exporting to cdng... but in some other cases where there was a different type of aliaising it didn't make a difference and possibly the cdngs were better! There haven't been updates for the bitrate hack that I know of. We were extremely lucky that the magic lantern forum members did so much work with the EOS M these last few months. It's gone a bit quiet now and will probably be a while before we see any new updates for that camera, but that's ok. Now I'm just waiting for Viltrox to release their EF-M speedbooster so I can turn my EOS M into a 'full-frame' camera using the mv1080p mode! I think the 70D also benefits from SD card overclocking but don't know if that camera can record lossless raw yet. Link to comment Share on other sites More sharing options...
Brian Williams Posted September 6, 2018 Share Posted September 6, 2018 34 minutes ago, Alpicat said: Now I'm just waiting for Viltrox to release their EF-M speedbooster so I can turn my EOS M into a 'full-frame' camera using the mv1080p mode! Yes, same here! I keep checking their website in hopes of seeing something. Alpicat 1 Link to comment Share on other sites More sharing options...
Alpicat Posted September 6, 2018 Share Posted September 6, 2018 3 minutes ago, Brian Williams said: Yes, same here! I keep checking their website in hopes of seeing something. The place to check is here: Link to comment Share on other sites More sharing options...
Jimmy Posted September 7, 2018 Share Posted September 7, 2018 Sounds like they hacked the 5D iv ! Link to comment Share on other sites More sharing options...
Cippo Posted September 19, 2018 Share Posted September 19, 2018 Dual ISO without aliasing & without quality loss! https://www.magiclantern.fm/forum/index.php?topic=22818.msg206134#msg206134 https://www.youtube.com/watch?v=cP6DjS4QgcE kaylee 1 Link to comment Share on other sites More sharing options...
Jimmy Posted September 30, 2018 Share Posted September 30, 2018 Does anyone know the best DPAF camera that is working with magic lantern (even a beta build)? Looking at their list, it seems the 70D, is that correct? Link to comment Share on other sites More sharing options...
Stathman Posted September 30, 2018 Share Posted September 30, 2018 Yes, 70D works well. DPAF also. Jimmy 1 Link to comment Share on other sites More sharing options...
mercer Posted November 11, 2018 Share Posted November 11, 2018 So, I’ve been shooting ML Raw with my 5D3 for over a year and a half now and I’m still as happy with the camera and the image as the day I bought it. I’m even thinking of buying a used one as a backup and to have set up for 48p/60p. I’ve been using a 2014 MacBook Air to process, edit and temporarily grade the footage so far but I really need an upgrade. I’d like to say with a Mac. So I was wondering what bate minimum requirements are to edit 1080p ML Raw? What I have actually works pretty good but the screen is killing me. Any recommendations? Can an iMac or MacBook screen be calibrated with a Spyder or similar product? Also I’d like to know more about the ACR workflow. I was thinking of picking up a pre-subscription copy of Premiere or After Effects if I can find one. Thanks kaylee 1 Link to comment Share on other sites More sharing options...
kaylee Posted November 12, 2018 Share Posted November 12, 2018 @mercer, just wondering, are you not happy with resolve...? every now and then ill use ACR for a clip, but i have no "workflow" cuz i only do it occasionally ? i still love my 5d3 raw too!! ??? Link to comment Share on other sites More sharing options...
mercer Posted November 12, 2018 Share Posted November 12, 2018 @kaylee I only use Resolve as an intermediary to process my footage to ProRes. Well that’s not entirely true... I’ll trim some fat in the editor, make WB corrections, tweak the exposure if needed, turn it into BMDFilm (or sometimes I’ll just leave it in Rec709) and then I’ll transcode it to ProRes. I’m pretty settled with FCPX and don’t really have the time to learn Resolve. So I do any final color work in Final Cut. But I’m really just doing test grades at this point. But I haven’t really settled on a final workflow yet because I am just testing methods as I shoot the film. How do you process your footage in Premiere if you aren’t using ACR? kaylee 1 Link to comment Share on other sites More sharing options...
kaylee Posted November 13, 2018 Share Posted November 13, 2018 actually ive never used premiere with ml raw... when i first started screwing around with the ml files, figuring them out, i used acr through photoshop to grade, exported as tif files, then opened the files as an image sequence. so ghetto i know! ? Link to comment Share on other sites More sharing options...
Katrikura Posted November 13, 2018 Share Posted November 13, 2018 10 hours ago, mercer said: @kaylee Yo solo uso Resolver como intermediario para procesar mi material de archivo a ProRes. Bueno, eso no es del todo cierto ... Recortaré un poco el contenido del editor, haré correcciones de WB, modificaré la exposición si es necesario, lo convertiré en BMDFilm (o algunas veces lo dejaré en Rec709) y luego lo transcodificaré. a ProRes. Estoy bastante resuelto con FCPX y realmente no tengo tiempo para aprender a resolver. Así que hago cualquier trabajo de color final en Final Cut. Pero en realidad solo estoy haciendo calificaciones de examen en este punto. Pero todavía no me he conformado con un flujo de trabajo final porque solo estoy probando métodos mientras filmo la película. ¿Cómo procesa sus imágenes en Premiere si no está utilizando ACR? hello, I use mlvproducer, to convert raw mlv files to prores, it works on windows and it gives me very good results. Try it works on any PC. regards Link to comment Share on other sites More sharing options...
