ntblowz Posted June 29, 2017 Share Posted June 29, 2017 Basically same function as EOS-M5 for half the price, minus EVF and EIS but comes with fully articulated touchscreen and same DPAF! Makes me want to ditch A5100 for it.. the only Sony camera I have left, even in winter it still overheat arghh Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted June 29, 2017 Administrators Share Posted June 29, 2017 Why would you get either when the old 100D (£200) and EOS M (£120) shoot 10bit raw video? Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted June 29, 2017 Super Members Share Posted June 29, 2017 The Raw out of the M leaves a lot to be desired imo. But as a stills camera its very fun and ML gives it a distance scale for zone focus. tweak 1 Link to comment Share on other sites More sharing options...
ntblowz Posted June 29, 2017 Author Share Posted June 29, 2017 4 minutes ago, Andrew Reid said: Why would you get either when the old 100D (£200) and EOS M (£120) shoot 10bit raw video? Well I dont shoot raw and doesn't care about it, this cam will be used for client or temp assistant that don't really know how to operate camera, so touchscreen dpaf will be huge help lol. Link to comment Share on other sites More sharing options...
tweak Posted June 29, 2017 Share Posted June 29, 2017 9 minutes ago, Mattias Burling said: The Raw out of the M leaves a lot to be desired imo. But as a stills camera its very fun and ML gives it a distance scale for zone focus. Raw out of either of those cams is fun but not amazing imo. 7D and beyond is where it becomes practical for me. I have a few eosm lying around now that I rarely touch except if I want to take out a small stills camera. Mattias Burling 1 Link to comment Share on other sites More sharing options...
mercer Posted June 29, 2017 Share Posted June 29, 2017 The M5 has focus peaking. The SL2 does not. And like most features that Canon slowly introduces, it's the best focus peaking I've ever used. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted June 29, 2017 Administrators Share Posted June 29, 2017 2 hours ago, tweak said: Raw out of either of those cams is fun but not amazing imo. 7D and beyond is where it becomes practical for me. I have a few eosm lying around now that I rarely touch except if I want to take out a small stills camera. I am under the impression 10bit RAW the same quality on the EOS M as the 100D and 70D... Have you actually tried it? 1600 x 864 (1.85:1) 10bit RAW is continuous according to the raw calculator. Link to comment Share on other sites More sharing options...
mercer Posted June 29, 2017 Share Posted June 29, 2017 4 minutes ago, Andrew Reid said: I am under the impression 10bit RAW the same quality on the EOS M as the 100D and 70D... Have you actually tried it? 1600 x 864 (1.85:1) 10bit RAW is continuous according to the raw calculator. Will that look better downscaled to 720p or upscaled to 1080p? I've always liked the idea of 720p Raw. Any word if the 10bit variant cures the pink dot issue? I'll have to pull mine out from the depths of my gear closet and give this a test one of these days. I have a bunch of c-mounts just dying to get used. Link to comment Share on other sites More sharing options...
tweak Posted June 29, 2017 Share Posted June 29, 2017 I'm under the impression 10bit raw doesn't really work 100% properly from my tests with Eosm (also 7D). Not to mention the benefits of Raw are much more apparent at a minimum of 12bit on theses cams, if I was going to shoot 10bit I'd just buy a different camera (almost any panasonic 4K cam and down sample to 1080). I've used eosM quite a bit for 14bit raw, but I got really sick of the focus pixels and the extra hassle of getting rid of them. That new app for Mac cuts down the process, but still you're pretty limited with it. For me 7D is truly the cutoff point, any less quality than that and I can't be bothered with it, unless I was doing an 8mm emulation video or something. mercer 1 Link to comment Share on other sites More sharing options...
