Daniel Galli Posted July 7, 2017 Share Posted July 7, 2017 Hi, i have recently have issues with after effects tracking, all my camera files cant be tracked, getting "analysis solved failed" as error message. First i think it was the 120fps, then i re interp footage, and nothing, tried to convert to prores, using another files with native 24 fps, full hd, hd, all resolutions and nothing, then tried with a a7 file and work perfectly. Anyone with the same problem? i use adobe after effects 2017 first release with the hevc update and nx500 120fps and 24fps files. Link to comment Share on other sites More sharing options...
ReinisK Posted July 7, 2017 Share Posted July 7, 2017 I've had this issue, but I don't think it was related to the camera, because other shots worked fine. Most likely it was just a hard scene for the tracker. You could try and convert the files to different format to see, if it's the camera codec's fault. Link to comment Share on other sites More sharing options...
