maxotics Posted July 24, 2017 Share Posted July 24, 2017 Saw this on YouTube. Fascinating. NOT FOR THE TECHNICALLY FAINT OF HEART. But if you're comfortable with TCP/IP then this is very interesting. Essentially, what Danman has figured out is that this HDMI extender transmits the HDMI signal through standard TCP/IP packets. He discovered that VLC, ffmpeg, etc. will read the stream fairly well, and most other software that will display a network stream. From there, you can save to any video CODEC they support (which is almost every one) There are various hacks to get around some issues (like multi-broadcasting to your whole network) which seem pretty well documented. I suggest watching the YoutTube video by OpenTechLab. The only gotcha for you EOSHDers is the latency, which is about a second and half. https://blog.danman.eu/new-version-of-lenkeng-hdmi-over-ip-extender-lkv373a/ Here's what I believe is the right thing on Ebay. Remember, you want the TRANSMITTER. Not the receiver. http://www.ebay.com/itm/LKV373A-V3-0-HDMI-Extender-100-120M-HDMI-Extender-Over-Cat5-Cat6-Support-1080P/191750919298?ssPageName=STRK%3AMEBIDX%3AIT&var=490770381286&_trksid=p2055119.m1438.l2649 PannySVHS 1 Link to comment Share on other sites More sharing options...
no_connection Posted July 24, 2017 Share Posted July 24, 2017 This would make an interesting wireless solution with a point to point wifi link like UBNT Nanostation. (I use the LocoM2 as a cheap AP with great range) Key would be to force it to output the correct frame rate and resolution. Having it not scale could maybe reduce latency by a little too. Wonder if VLC on a phone would work too. That would make a decently cheap monitor maybe. With a more powerful PC or tablet adding peaking and the like might be possible. btw it's UDP and not TCP/IP so there is no error correction or handling of dropped packets. Link to comment Share on other sites More sharing options...
maxotics Posted July 24, 2017 Author Share Posted July 24, 2017 5 minutes ago, no_connection said: btw it's UDP and not TCP/IP so there is no error correction or handling of dropped packets. That's why I'm not rushing to buy one I've had enough networking protocols for a lifetime. You'll see in the video that you can configure it through your browser a bit. Link to comment Share on other sites More sharing options...
jcs Posted July 25, 2017 Share Posted July 25, 2017 For $299 these work pretty well for 1080p (I added the heat sinks mentioned in the comments (just using rubber bands to hold on): https://www.amazon.com/gp/product/B00I16VQOY/ref=oh_aui_detailpage_o01_s00 For 4K and USB 3.0, this works well with the A7S II and GH4 in 4K: https://www.amazon.com/gp/product/B01H3Y3IL8/. maxotics 1 Link to comment Share on other sites More sharing options...
