dvcrn Posted August 7, 2017 Share Posted August 7, 2017 I know the Canon M's don't have the biggest fanbase here but I thought I'll ask anyway I am looking for a small cage (or other accessory) that allows me to mount a normal coldshoe microphone sideways to the camera. Reason is, putting anything on the normal hotshoe will make the flippy screen unusable so I can't put mic there. The smallrig 1658 looks interesting: Here's a pic of it I found on the m3 which has almost the same dimensions as the m6: I can leave out the top piece and screw a coldshoe to the cheese rod but I'd prefer something that fits even tighter to the m6 and doesn't have that empty space to the side. Also can I even use this cage without the top piece for stability? If possible I just want something that I can screw into the tripod hole that allows me to put the microphone to the side. Any ideas? Link to comment Share on other sites More sharing options...
aldolega Posted August 7, 2017 Share Posted August 7, 2017 A simple flash bracket will let you relocate the mic. For a more compact cage, look up the camera's dimensions and see if another Smallrig option will work. Maybe a GX85 or A7 cage would work. Link to comment Share on other sites More sharing options...
