Iscorama 36 Proxiscope rehousing – close focus and cine gears
redimp
On 4/12/2020 at 6:18 AM, redimp said:
@HockeyFan12 what's the password to the video?
Just changed it to:
password
But don't worry about it. When using a 35mm retrofocus (stills) taking lens I am seeing no vignetting at all. I tried 35mm f2 nFD and 35mm f2.8 QBM and both looked good on S35.
Maybe I remember something wrong. Regardless this is wide enough and I can use a wide angle adapter on the Iscorama if needed since the close focus distance is improved (no need for diopters at normal focus distance). So it works great for me and the focus is smoother than it ever was with the original housing. I don't think there's significantly more vignetting than before. But I do think if you milled down the front threads further there might be room for even more FOV since the vignetting I do see appears to be caused by the filter threads, not the edges of the image circle.
  • 1 month later...
  • 4 weeks later...
