Grégory LEROY Posted August 12, 2017 Share Posted August 12, 2017 Hello, I mainly deliver in 1080p/50fps. Do you guys have some comparison shot? GH5 1080p is supposed to record at higher bit rate + you can record 4k50p then converted to1080p. But I'm curious if there's a massive difference, will my client see it? (on youtube) Thank you. Link to comment Share on other sites More sharing options...
aldolega Posted August 12, 2017 Share Posted August 12, 2017 GH5 will be much sharper (higher resolution). The G85 1080p is ok when there isn't much movement in the frame and you don't need to grade/adjust much in post. The GH5 will withstand motion better, and you can shoot in 10-bit 4:2:2 in 1080p. jonpais 1 Link to comment Share on other sites More sharing options...
Inazuma Posted August 12, 2017 Share Posted August 12, 2017 Your client probably wont see the difference if its only viewed on youtube. kidzrevil 1 Link to comment Share on other sites More sharing options...
