Wee man !
Dick Sweeney
4 hours ago, whoisjsd said:
Why so many step rings? Shouldn't one do the job? Then you have less vignetting...
Yes and yes - it was all I had at hand before i did that trip. I have one on order now that should bring it all together with hopefully less vignetting. Which I kind of didnt mind for the this subject ie no nd - stopped right down and high shutter speeds - run n gunning and having some fun too
2 hours ago, tweak said:
Vignette is ok, but if it's moving around like that it looks horrid imo. Better to use a longer taking lens if you want to stabilise.
I could not agree more. I think the shaky footage would actually be better than the shaky vignetting :D
Why don't you just crop so that you don't see the vignette ? Looks like you have the extra resolution. Just crop so that the vignette is not visible and export in 2K/FHD :)
Also it seems that the stretch factor is a bit off. But maybe it's just me, not sure about this one.
The images are quite good, just hide that shaky vignette and you're good to go again ;)
