Orangenz Posted September 27, 2017 Share Posted September 27, 2017 http://av.jpn.support.panasonic.com/support/global/cs/dsc/download/fts/index2.html GH4 - In VFR (Variable Frame Rate) shooting mode, there were cases where the image stabilization did not operate when non-Panasonic interchangeable lens is used. This bug has been fixed. H-HS030 - Macro - Dual I.S.2 is available by this firmware update. (in case of the usage of Camera with this function) H-NS043 - Nocticron 42.5 - Dual I.S.2 is available by this firmware update. (in case of the usage of Camera with this function) GH5 - 1. Compatibility with "LUMIX Tether" PC software This new firmware enables GH5 tethered shooting via USB, using “LUMIX Tether" PC software. Users can control the camera by connecting it to a PC via USB. Click here to the LUMIX Tether Download Program 2. Improved auto focus performance - Auto focus performance for subjects with low contrast in photo shooting is improved. - Tracking auto focus performance in video recording is improved. - The customized AF area can be continuously displayed in [Multi AF] and [Custom Multi AF] during live-view. - The AF area in [Multi AF] can be moved to the other edge (side, top or bottom) when it reaches one edge. - The start point of AF lock can be set on the live view screen in advance in [AF Tracking]. - The AF area can be moved while the shutter button is half-pressed or while recording in [Burst Mode], [6K PHOTO] and [4K PHOTO]. 3. Improved performance in [6K PHOTO] and [4K PHOTO] - The waiting time to start the next burst shooting sequence after [6K Burst] and [4K Burst] is shortened to less than half the time. - [Loop Rec] is available in [6K PHOTO]. * Use of Panasonic SD Memory Card with Video Speed Class 90 is recommended for [Loop Rec] of [6K PHOTO]. 4. An additional ALL-Intra Video Recording mode- 4:2:2,10-bit ALL-Intra video recording mode is added to 4K/FHD video recording. * Use of SD Memory Card with Video Speed Class 60 or higher is recommended for 4K ALL-Intra video recording. Operation is confirmed with Panasonic SD Memory Card with Video Speed Class 90. 5. 4K HDR video recording - [HLG] (Hybrid Log Gamma) is added to [Photo Style]. HDR (High Dynamic Range) is a mode to reproduce both bright part and dark part in an image, making it look just as human eyes see. The camera records video with a designated gamma curve compatible with ITU-R BT.2100, and you can now choose Hybrid LogGamma (HLG) in [Photo Style]. - A low-bit-rate recording mode 4K HEVC for HLG was added. This enables playback on AV equipment compatible with the HEVC compression format, such as Panasonic 4K HDR TVs. 6. Enhancement of the Anamorphic video recording mode- High-Resolution Anamorphic mode, which enables video recording in 18-mega effective pixels, is added. * Recorded in HEVC - [Anamorphic Desqueeze Display] was added, which lets you view an enlarged image in Cinescope size while recording with 2.0x and 1.33x Anamorphic lens. - [Video Guide Line] is added to display the image in a variety of aspects, such as Cinescope, 16:9 and 1:1 while recording video. This can be used not only in Anamorphic mode but also in other video recording mode. 7. Enhancement of Body I.S. (Image Stabilizer) - [I.S. Lock(video)] is added. This powerfully compensates for handshake when the viewing angle is fixed. - A new handshake correction mode is added, which provides optimum correction when using 2.0x and 1.33x Anamorphic lens. - In VFR (Variable Frame Rate) shooting mode, there were cases where the image stabilization did not operate when non-Panasonic interchangeable lens is used. This bug has been fixed. 8. Correction of white balance setting - When the K (Kelvin) value was changed after adjusting the color temperature with 2-axis white balance compensation, the setting was reset. This bug has been fixed. 9. Improved usability of Time Lapse Shot - The time to finish shooting and the number of recordable pictures are displayed on the stand-by screen. 10. Improved usability of Power Save LVF - Power Save LVF can now be used during all stand-by display options. 11. Wireless functions - The Bluetooth Remote Control function can be used with Image App, which will also be updated at the same timing with the GH5 firmware release. - If the camera has not completed image transmission when it is turned off, it restarts transmission when it is turned on with the [Auto Transfer] function. 12. Other improvements - A rating function using a Fn button is available in Playback Zoom and Multi Playback. - The following functions can be assigned to Fn buttons - [Constant Preview] [6K/4K PHOTO Bulk Saving] [Min. Shtr Speed] [RAW Processing] [Rec/Playback Switch] [Destination Slot] and [Mic Level Adj.]. - The DISP.Button can be locked. - In Relay Rec, there were cases where the video file number was not able to be reset. This bug has been fixed. - In Relay Rec, there were cases where the video file number was reset after formatting the SD Memory Card. This bug has been fixed. - In Backup Rec, there were cases where the file number was not reset even after applying resetting. This bug has been fixed. - The image quality when applying the following settings is improved: Extended low ISO, [i.Dynamic] (Intelligent D-range Control) and Highlight Shadow. Notice for the Change of Specifications kidzrevil, deezid, Cinegain and 2 others 2 3 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted September 27, 2017 Administrators Share Posted September 27, 2017 Yes the big 2.0 is now out Orangenz 1 Link to comment Share on other sites More sharing options...
deezid Posted September 27, 2017 Share Posted September 27, 2017 Already installed. 1080p60 All-I 200 Mbit 10 Bit will be my GoTo for slowmo from now on. The details and noise structure are insane considering it's only HD video. Especially after Nnedi3 upscaling. It basically looks like 4k. Am impressed. Seems like sharpening at -5 is completely disabled? Still searching for sharpening halos... That would be amazing! dxotic, Samin, PannySVHS and 3 others 5 1 Link to comment Share on other sites More sharing options...
Orangenz Posted September 27, 2017 Author Share Posted September 27, 2017 I can confirm that my normal sandisk UHS-II (not V rated) works without any problems. No stops until the card full. UHS-I card stopped after 23 seconds. Also, the AF is veeeeery cool. jonpais and Cinegain 1 1 Link to comment Share on other sites More sharing options...
Orangenz Posted September 27, 2017 Author Share Posted September 27, 2017 Some other cool things: Movie menu p3, Stabilizer - I.S. Lock function (video) - when angle of view held stationary this turns super grippy tripod like I.S. on. Custom menu p3, Operation Lock setting - Display button deezid 1 Link to comment Share on other sites More sharing options...
NewFilmMaker Posted September 27, 2017 Share Posted September 27, 2017 I went to Custom menu p3, Operation Lock setting - Display button and set it to OFF, but the display button still working? Anyone have the same problem? Link to comment Share on other sites More sharing options...
Orangenz Posted September 27, 2017 Author Share Posted September 27, 2017 On 9/27/2017 at 5:13 AM, NewFilmMaker said: I went to Custom menu p3, Operation Lock setting - Display button and set it to OFF, but the display button still working? Anyone have the same problem? Expand Yes, have asked Panasonic about this. Link to comment Share on other sites More sharing options...
matthere Posted September 27, 2017 Share Posted September 27, 2017 The de-squeeze is nicely implemented Orangenz 1 Link to comment Share on other sites More sharing options...
Amazeballs Posted September 27, 2017 Share Posted September 27, 2017 Can someone do some adequate AF tests? A-la Max Yuriev style. Link to comment Share on other sites More sharing options...
frankool Posted September 27, 2017 Share Posted September 27, 2017 Green video on premiere? anyone? why? all is with last version, and all codecs installed Link to comment Share on other sites More sharing options...
Orangenz Posted September 27, 2017 Author Share Posted September 27, 2017 On 9/27/2017 at 8:08 AM, Amazeballs said: Can someone do some adequate AF tests? A-la Max Yuriev style. Expand Haha, popups. In my 20 minute 64GB take it seemed to take too long to AF just once. The rest was slightly unnerving as to how good it was in a bloggy sort of way. I'm very impressed so far. On 9/27/2017 at 8:15 AM, frankool said: Green video on premiere? anyone? why? all is with last version, and all codecs installed Expand All good here on PC. Link to comment Share on other sites More sharing options...
Orangenz Posted September 27, 2017 Author Share Posted September 27, 2017 The update manual was just pointed out to me. http://av.jpn.support.panasonic.com/share2/eww/en/dsc/fts/pdf/GH5_V20_ENG.pdf Link to comment Share on other sites More sharing options...
jonpais Posted September 27, 2017 Share Posted September 27, 2017 Slower cards may work, but you won't be able to use a second card as a backup. Link to comment Share on other sites More sharing options...
IronFilm Posted September 27, 2017 Share Posted September 27, 2017 On 9/27/2017 at 1:59 AM, Orangenz said: 1. Compatibility with "LUMIX Tether" PC software This new firmware enables GH5 tethered shooting via USB, using “LUMIX Tether" PC software. Users can control the camera by connecting it to a PC via USB. Click here to the LUMIX Tether Download Program Expand That "LUMIX Tether" PC software is cool news for studio shooters! Something to keep the stills photographers happy! As they often complain about Panasonic being too video focused (they could always just buy Olympus instead!) Link to comment Share on other sites More sharing options...
PannySVHS Posted September 27, 2017 Share Posted September 27, 2017 On 9/27/2017 at 2:44 AM, deezid said: Already installed. 1080p60 All-I 200 Mbit 10 Bit will be my GoTo for slowmo from now on. The details and noise structure are insane considering it's only HD video. Especially after Nnedi3 upscaling. It basically looks like 4k. Am impressed. Seems like sharpening at -5 is completely disabled? Still searching for sharpening halos... That would be amazing! Expand That´s right. That´s what I´d go for. 200MBit is the right data rate for ALL I HD. What profile did you test the sharpening with? Would be awesome to have a REC709/2020 profile without any sharpening. Link to comment Share on other sites More sharing options...
Orangenz Posted September 27, 2017 Author Share Posted September 27, 2017 On 9/27/2017 at 10:12 AM, jonpais said: Slower cards may work, but you won't be able to use a second card as a backup. Expand They not slower if they going at the same speed. Multi stream applications they will fail though. I don't think the GH5 is multi-stream? Might be with the audio adaptor. I don't follow you on your point about second card. If you have the choice to get the SDZA pSLC cards then that should be more reliable all things being equal. Link to comment Share on other sites More sharing options...
jonpais Posted September 27, 2017 Share Posted September 27, 2017 On 9/27/2017 at 10:47 AM, Orangenz said: They not slower if they going at the same speed. Multi stream applications they will fail though. I don't think the GH5 is multi-stream? Might be with the audio adaptor. I don't follow you on your point about second card. If you have the choice to get the SDZA pSLC cards then that should be more reliable all things being equal. Expand The user manual you posted says non v60 v90 cards will not allow backup to 2nd card in ALL I 400. Link to comment Share on other sites More sharing options...
Orangenz Posted September 27, 2017 Author Share Posted September 27, 2017 On 9/27/2017 at 10:55 AM, jonpais said: The user manual you posted says non v60 v90 cards will not allow backup to 2nd card in ALL I 400. Expand Ah that is interesting Link to comment Share on other sites More sharing options...
jonpais Posted September 27, 2017 Share Posted September 27, 2017 AF C still not too useful for vlogging anyhow. Link to comment Share on other sites More sharing options...
Advent1sam Posted September 27, 2017 Share Posted September 27, 2017 Link to comment Share on other sites More sharing options...
