anax276 Posted September 29, 2017 Share Posted September 29, 2017 Hi, I ended up with a large number of LUTs and it has gotten very confusing... Especially since I would like to use different applications from times to times (PremierePro, FCPX, Resolve), which require the LUTs to be in a specific folder to work properly. How do you organize your LUT collection in order to find the LUT you want easily and to use it with different applications? I would like to avoid having multiple copies of the LUTs. I guess I could throw away some LUTs, but I... don't want to! :-) Thanks! Link to comment Share on other sites More sharing options...
jonpais Posted September 29, 2017 Share Posted September 29, 2017 LUT Utility from Color Grading Central for use with FCPX works fine for me, keeps everything organized. Link to comment Share on other sites More sharing options...
sondreg Posted September 29, 2017 Share Posted September 29, 2017 If you use a lot of different application you might want to use Symlink in ur project folders. - since your using FCPX I assume you are on a mac. I don't recall the exact name but I think the software I use was called Symlinker, very easy to setup. It's essentially a folder 'shortcut' that acts as a real folder. Keep 1 master LUTS folder where you store and organize, and symlink it in every programs LUT directory. anax276 1 Link to comment Share on other sites More sharing options...
anax276 Posted September 29, 2017 Author Share Posted September 29, 2017 Thanks, I will try that and see if it works for me! Link to comment Share on other sites More sharing options...
