Xavier Plagaro Mussard Posted October 17, 2017 Share Posted October 17, 2017 Hello! I was contacted to make a recording of a musical which has two one hour long parts. I need to rent a 4K camcorder which wont give me heating or other problems. I would appreciate a lot some recomendations, mostly if they come from people who have tested it! Thanks! Link to comment Share on other sites More sharing options...
Xavier Plagaro Mussard Posted October 18, 2017 Author Share Posted October 18, 2017 Anybody with experience with Sony FS5 with the ND on auto?? Link to comment Share on other sites More sharing options...
EthanAlexander Posted October 18, 2017 Share Posted October 18, 2017 I own an FS5 and the auto variable ND is *mint* - I love it. It's probably the best auto setting of any camera, because of how smoothly it can change values, without changing the aesthetics like shutter speed or aperture would. The lowest it goes is 1/4 (2 stops light loss) though, so it may not be useful for a musical if there's not enough light. The key to getting a great picture from the FS5 is making sure it gets enough light! If you have experience with log curves or cinegammas, I'd use one of those to give you some extra room in the highlights and aim to overexpose as much as you can without blowing the highlights (In the case of using the auto ND, you'll set the exposure compensation to something like +1EV, for instance). I'm guessing the stage lights will make for some dramatic differences between the lit and unlit parts of the stage, so the extra dynamic range will be very useful. If you have a quick turnaround, I'd definitely recommend using one of @Andrew Reid's new Pro Color settings. In short, if you plan on using auto ND you're going to need to make sure you have at least an f/2.8 lens because in effect the lens will be a 5.6 with ND on lowest setting. Perhaps paring it with one of the Sigma f/1.8 zooms would be a great combo, cause then wide open you'd still be at f/3.5. Link to comment Share on other sites More sharing options...
