Zhiyun Crane 2 - improvements and drawbacks
mojo43
Pilotfly has also released a new model (adventurer) which looks quite promising. It weights under a kilogram without sacrificing payload capacity. Pay attention to the unit's weight when considering these things. Both Gravity G2 and Ikan Pivot are quite bulky & heavy at around 1.8 kg, so they are totally unsuitable for run and gun situations.
Here is some test footage of some dude running. There is no bob up and down. Does it have post stablization added  as well?
its so smooth. I can’t believe it’s real.
Top one must be bullshit. This is more like it.
  • 2 years later...
Hi there, I am having trouble saving waypoints in a Motion Timelapse. I recently just upgraded the software to version 1.77.
After I set waypoints A&B, I go into the next menu and set the other parameters, and then I MAKE SURE that the save button is highlighted to the right to activate the "Save" Option. I then initiate the motion timelapse, let it do its thing and then when I go to run the exact same parameters under "Preset" it tells me that I need to enable save functions...I have tried about 50 times and 50 times it will not recognize my saved waypoints.
Anyone else have this issue?
