Marcio Kabke Pinheiro Posted November 4, 2017 Share Posted November 4, 2017 Hi, guys. Do you know any software (free is possible) that allows you to trim Panasonic's (GX85, in the case) MP4 4k files without recoding? I have a lot of footage with begin / end without usable material (the shutter button of the GX85 sometimes did not stop the recording), and I wish to trim the excesses before moving it to my permanent storage. Thanks. Link to comment Share on other sites More sharing options...
Marcio Kabke Pinheiro Posted November 5, 2017 Author Share Posted November 5, 2017 Already found one, freeware - link if someone need it in the future.http://avidemux.sourceforge.net/ Link to comment Share on other sites More sharing options...
joema Posted November 5, 2017 Share Posted November 5, 2017 Always thoroughly test this type of utility on numerous clips before relying on it. I haven't tested this one but I've seen several cases where such utilities produce a damaged output file. I also suggest testing playback with two different players such as VLC and Windows Media Player or Quicktime Player. Make sure the player will properly show the beginning and end of the trimmed file, also that fast forward and fast reverse followed by normal speed playback works OK. Otherwise it is possible to trim a bunch of files, think they are OK, discard the originals, then later find out the trimmed files are compromised in some way. Link to comment Share on other sites More sharing options...
maxotics Posted November 5, 2017 Share Posted November 5, 2017 31 minutes ago, joema said: Always thoroughly test this type of utility on numerous clips before relying on it. Agree, I've been burned so many times searching for this Holy Grail. I've used avidemux, various ffmpeg frontends, which worked for sometimes, then blew up, for reasons I still don't understand. Recently I tried https://lesspain.software/kyno/ and it blew me away, how well thought-out it is. I thought, finally, the perfect tool! But then it mangled some C100 footage--footage it should be able to deal with easily. I put in a bug report, to this day I have no idea if they've fixed it. Hopefully they do, because they're onto something. Link to comment Share on other sites More sharing options...
maxotics Posted January 4, 2018 Share Posted January 4, 2018 Apparently my bug about the C100 slipped through the cracks at Lesspain / Kyno. They asked me to try it again in the new 1.4 version and I can report that it is fixed. It's a very nicely thought-out piece of software which allows you to trim, copy, re-encode video/audio in whatever manner you want . They have a trial. Highly recommended that you try it out, if you do any footage "pre-processing". https://lesspain.software/kyno/ kaylee and Geoff CB 2 Link to comment Share on other sites More sharing options...
markr041 Posted January 4, 2018 Share Posted January 4, 2018 You want lossless trimmig. TMPEgnc Smart Renderer 5 does that. I have used it for years. You can even merge files losslessly. No issues specifically with GX85 4k files. kaylee 1 Link to comment Share on other sites More sharing options...
buggz Posted January 5, 2018 Share Posted January 5, 2018 ffmeg does this, and much more. Link to comment Share on other sites More sharing options...
markr041 Posted January 5, 2018 Share Posted January 5, 2018 7 minutes ago, buggz said: ffmeg does this, and much more. Command line program, right? Not the easiest to trim clips compared to the commercial TMPEgnc. But, free is free. Link to comment Share on other sites More sharing options...
ac6000cw Posted January 5, 2018 Share Posted January 5, 2018 No personal experience of using it for 4K H.264 files, but VideoRedo TVSuite is also worth a look/tryout - https://www.videoredo.com/en/Products_TVSuite_V5.html and https://www.videoredo.com/en/CompareProducts.htm Link to comment Share on other sites More sharing options...
Ded Posted January 6, 2018 Share Posted January 6, 2018 MPEG Streamclip - http://www.squared5.com Just trim and save as... Very straightforward and reliable, have been using it for years for mp4 without any problem. Link to comment Share on other sites More sharing options...
Vesku Posted January 6, 2018 Share Posted January 6, 2018 Panasonic cameras can also trim own videos. Link to comment Share on other sites More sharing options...
cantsin Posted January 6, 2018 Share Posted January 6, 2018 Avidemux, which has been mentioned above, is indeed the right tool for this job. When trimming h264/mpeg video, it allows you to jump from keyframe to keyframe and set them as in/out markers. This way, it can trim video files in a clean way without any reencoding, quality loss or garbled frames. On top of that, it's Open Source, running on Windows, Mac and Linux, and has been stable and mature for years. Link to comment Share on other sites More sharing options...
maxotics Posted January 6, 2018 Share Posted January 6, 2018 1 hour ago, cantsin said: has been stable and mature for years Do you still use it? I found it buggy. It might work for one set of parameters, but then croak on another. The dev seems to go on and off it. The last news update was almost half a year ago. Whoever is behind Kyno has certainly put a lot of effort into it, and even they ran into problems. The dirty truth is every update to one's OS, or every new camera CODEC settings, threatens to hurt your software. I'm all for open source (use ffmpeg,imagej , dcraw, and imagemagick, etc), but,at least for me, if I can pay to save time and future grief, I will if the price is right. It's a free trial. Why don't you try Kyno and let us know? I'm just one opinion. I've used almost every piece of software mentioned in this thread and most of them are no longer being developed in a significant way. Kyno is a new effort. For that alone, one should see where the latest thinking is at. Or one can go back to the GH2 Link to comment Share on other sites More sharing options...
Marcio Kabke Pinheiro Posted January 8, 2018 Author Share Posted January 8, 2018 Just for info, in my case used avidemux with GX85 4K MP4 files, worked flawlessly. But your mileage may vary with other formats. Link to comment Share on other sites More sharing options...
markr041 Posted January 8, 2018 Share Posted January 8, 2018 On 1/6/2018 at 9:39 AM, maxotics said: I've used almost every piece of software mentioned in this thread and most of them are no longer being developed in a significant way. Kyno is a new effort. For that alone, one should see where the latest thinking is at. Or one can go back to the GH2 Yes, most of the software touted here has stopped developing. I do not understand why TMPGEnc Smart Renderer 5 is not THE solution? It has been constantly updated to add new features (eg, HEVC trimming) and it renders losslessly and quickly - that is its purpose. It is up to date and has been around a long time. Is this forum populated by high schoolers who don't want to pay $59 for software? Or does someone actually have any bad experience to report? It has a free demo. http://tmpgenc.pegasys-inc.com/en/product/tmsr5.html Link to comment Share on other sites More sharing options...
maxotics Posted January 8, 2018 Share Posted January 8, 2018 26 minutes ago, markr041 said: I do not understand why TMPGEnc Smart Renderer 5 is not THE solution? It might be. I have no idea the OP's real-world use. I wouldn't say Kyno is THE solution. It's just A solution. No one knows better than I how little most "filmmakers" pay for accessories, either software or hardware. Under 10 people have ordered one of my vlogging mirrors from me. I'm not in the least surprised. Most of us just want to amuse ourselves with our cameras after work, or during the weekends. You and I are both outliers, like really out there Most don't have a real daily need to shoot much with their cameras, and hence, don't have the need for cutting software or vlogging mirrors, no matter how little they cost. The last person who inquired about my vlogging mirror wanted to buy it for her daughter. I looked at her daughter's channel. I told her, she needs a microphone first! That's also a problem. As much as everyone on EOSHD might want one of my vlogging mirrors for their Sony camera, or that software, they probably need better mics and lights first! If only money grew on trees. markr041 1 Link to comment Share on other sites More sharing options...
Jerry Smit Posted July 13, 2020 Share Posted July 13, 2020 I think ffmpeg is really complicated to use, which needs some commands. As for VLC, it is totally free, but it is not suitable for begginners. Based on my experience, Joyshare Media Cutter works well. You say you want to find freeware. That Joyoshare is nice. It provides 5 free opportunities to trim 4k videos without recoding. If you don't use frequently, it is equal to a free one. Try it! Link to comment Share on other sites More sharing options...
