“The Middle Path”: A Lumix GH5s Short
Neumann Films
1 hour ago, jonpais said:
So what's the headline feature here? According to @IronFilm, it's TC. For me, it's the new sensor. And since I use lights, being able to shoot at ISO 3200 and beyond is a nothing burger to me. If however, skin tones and noise are significantly better than they already are with the GH5 at ISO 400-800, that might sway me.
Everyone has their own biases at to what is the "best" new feature!
I also think the multi aspect ratio sensor is pretty cool. But of course not the "best" feature.
Suspect in the long run I'll think the "best" new feature of the GH5S is something else than TC, but I won't be able to determine that just from reading leaked paper specs, and need to wait for the reviews to come in first.
19 minutes ago, PannySVHS said:
Panasonic would also have to rearrange or even put a completely different IBIS in the camera due to new sensor layout and its slight oversize due to multi aspectratios
I half wonder if multi aspect ratio sensor and IBIS is incompatible with the MFT mount?!
Strongly doubt it, but it is a slim possibility I'm curious about.
5 minutes ago, JordanWright said:
Live streaming now!
Still got to wait a teeny bit longer....
official press release
https://www.43rumors.com/panasonic-gh5-press-announcement/
Panasonic Announces the Ultimate Hybrid DSLM with a newly developed 10.2MP High Sensitivity MOS sensor
Introducing the LUMIX GH5S: Exceptional Mirrorless Videography and Photography, designed and developed for professional filmmakers
• Introducing a newly developed 10.2MP High Sensitivity MOS sensor for enhanced image quality in low light: Allowing up to 51,200 ISO recording without extended ISO.
• Time Code IN/OUT for easy synchronization of multiple cameras and Dual Native ISO, providing low range (400) and high range (2,500) ISO environments.
• True “Multi-Aspect Ratio” Function in Both Photo and Video
Las Vegas, NV (January 8, 2018) – Panasonic is proud to introduce the new hybrid Digital Single Lens Mirrorless Camera LUMIX GH5S with expanded video recording capability and enhanced image quality. Designed and developed for professional filmmakers, the LUMIX GH5S achieves highest-ever image sensitivity and video image quality in the history of LUMIX cameras, especially in low-light situations.
Packed with big features to satisfy demanding photographers and videographers alike The new 10.2-megapixel Digital MOS Sensor with Dual Native ISO Technology and Venus Engine 10 faithfully reproduce even dark parts of the image, allowing high ISO capture when the use of supplemental lighting may not be possible. This sensor is a multi-aspect type with a sufficient margin for realizing the same angle of view in 4:3,17:9,16:9 and 3:2 aspect ratios. The sensor also enables photo shooting in 14-bit RAW format, providing higher flexibility for professional RAW stills development workflows. When shooting in dark environments, videographers can now focus on filming that perfect shot as they no longer need to worry
about noise which often results from having to use higher ISOs. The Dual Native ISO Technology suppresses noise to produce cleaner footage when taken in all light. Both videographers and photographers can now enjoy the same diagonal field of view across all aspect ratios with the True “Multi-Aspect Ratio” Function. This feature means you can easily swap between difference aspect ratios giving you the accuracy you want from your lenses, and making the process easier while producing and editing in post-production. The LUMIX GH5S is compatible with Time Code IN and OUT, like the professional camcorders, which is easy to set using the flash sync terminal and bundled conversion cable for a standard BNC terminal. This is especially important for “lip synchronization” when using multiple cameras.
The LUMIX GH5S can be used as Time Code generator for other GH5S cameras and professional camcorders. The Time Code IN/OUT functionality makes a production teams job pain-free as it provides synchronization for both video and audio devices used on multi-cam productions.
The LUMIX GH5 achieved 4KUHD 60p video recording for the first time as a digital mirrorless camera in 2017.2 The new LUMIX GH5S establishes a new milestone by realizing the world’s first 4K 60p video recording in Cinema 4K (4096×2160), 3 capable of internal 4:2:2
10-bit video recording up to Cinema 4K30p and internal 4:2:0 8-bit Cinema 4K60p. This is a color subsampling commonly used for film production, for even more faithful color reproduction.4
The LUMIX GH5S also records 4:2:2 10-bit 400-Mbps All-Intra in 4K 30p/25p/24p and 200- Mbps All-Intra in Full-HD.
Continuing the LUMIX GH tradition, there is no time limit for both Full-HD and 4K video recording. The LUMIX GH5S complies with 4K HDR video with Hybrid Log Gamma (HLG) mode in Photo Style. A low-bit-rate recording mode, 4K HEVC for HLG, is available. This enables playback on AV equipment compatible with the HLG Display format, such as Panasonic 4K HDR TVs.
The VFR (Variable Frame Rate) function lets users record overcranked (time-lapse) and
undercranked (slo-mo) video in C4K/4K (60 fps, maximum 2.5x slower) and FHD (240 fps, maximum 10x slower). A V-LogL and Rec.709 LUT (Look Up Table) are pre-installed in the camera, so users can play videos recorded in V-LogL without having to separately purchase a Software Upgrade Key. Four additional LUTs can be installed using the Panasonic Varicam (.VLT) file format.
DFD (Depth From Defocus) technology and ultra-high-speed digital signal processing achieve fast auto focusing of approximately 0.07 sec 6 with 12 fps (AFS) / 8 fps (AFC) in 12- bit RAW and 10 (AFS) / 7 (AFC) fps in 14-bit RAW high-speed burst shooting. In addition to a total of 225 focus areas, The options for Face/Eye Recognition, Tracking AF, 1-area AF and Pinpoint AF are available for precise focusing. The 4K PHOTO enables 60 fps high-speed capture in approximately 8-megapixel equivalent resolution.
Achieve outstanding footage in any environment, especially in low light
As a camera that excels in shooting in low light, the LUMIX GH5S boasts -5EV luminance detection performance with Low Light AF thanks to the higher sensitivity and optimized tuning of the sensor. Live Boost is another practical feature that makes it possible to check the composition even in total darkness, by boosting the sensitivity just for Live View. The magnification ratio in MF assist is increased from conventional 10x to 20x, which is convenient especially for astronomical photography. An AF Point Scope function, first introduced in the Lumix G9 and Night mode are also integrated.
In order to make the GH5S tough enough to withstand even heavy field use, it is composed of a magnesium alloy full die-cast front, rear and top frame that is not only splashproof7 and dustproof but also freezeproof down to -10 degrees Celsius. The GH5S is equipped with a double SD Memory Card slot, compatible with the high-speed, high-capacity UHS-II and Video Speed Class 90. Users can flexibly choose the recording method from Relay Recording, Backup Recording or Allocation Recording. The HDMI Type A terminal is provided, along with the USB-C Gen1 interface.
Exceptional image capture without concern
The GH5S has a large LVF (Live View Finder) with a stunningly high magnification ratio of approximately 1.52x/0.76x (35mm camera equivalent) providing smooth display at 120 fps. A high-precision, high-speed OLED (Organic Light-Emitting Diode) display features 3,680K-dot resolution and 100% field of view. In addition to dual dials, an omni-directional joystick enables more intuitive and flexible operation.
The GH5S includes Bluetooth and Wi-Fi® connectivity to offer a more flexible shooting experience and instant image sharing with easy operation. Compatibility with Bluetooth 4.2 (called BLE: Bluetooth Low Energy) enables constant connection with a smartphone/tablet with minimum power consumption. For Wi-Fi, 5 GHz (IEEE802.11ac)8 can be selected in addition to the conventional 2.4 GHz (IEEE 802.11b/g/n) for an even more secure and stable connection.
For extended battery life and a more stable hold, the new Battery Grip DMW-BGGH5 (sold separately) is available. The XLR Microphone Adaptor DMW-XLR1 (sold separately) allows high-res sound recording with an external XLR microphone.9
The Panasonic LUMIX GH5s will be available from end of February 2 and will retail for $2499 (body only).
*1 RAW files are in 14-bit even when 12-bit is selected.
*2 4K 60p/50p(for a Digital Single Lens Mirrorless Camera), 4:2:2 10-bit (for a digital interchangeable lens camera) as of 4 January, 2017
*3 As of January 8, 2018 as a Digital Single Lens Mirrorless camera that complies with 4K (4096×2160) resolution defined by Digital Cinema Initiatives(DCI). According to a Panasonic study.
*4 4:2:0 8-bit in C4K 60p and 4K 60p recording on an SD Memory Card.
*5 Contrast AF with DFD Technology works only with Panasonic Micro Four Thirds lenses.
*6 In AFS, at wide-end with H-ES12060 (CIPA) when LVF display speed is set to 120fps.
*7 Splash Proof is a term used to describe an extra level of protection this camera offers against exposure to a minimal amount of moisture, water or dust. Splash Proof does not guarantee that damage will not occur if this camera is subjected to direct contact with water.
*8 5GHz Wi-Fi is not available in some countries.
*9 In MOV only
3 minutes ago, AaronChicago said:
Is that different than V Log L?
Yeah full VLOG is for EVA1 and Varicam cameras, providing 14stops rather than 12 stops of dynamic range. With full VLOG curve they would have given us the same image as Varicam 35 and LT. Woundn´t that have been crazy and amazing! :) It would also have provided us with the possibility to turn sharpness completely off.
It would be nice to have extra DR. I wouldn't really care for a flatter image though. Arri Log C and BM Film are ideal in my opinion in terms of log curve.
That´s why you would love full curve for that varicam look which is in the same league as arri.
2 minutes ago, Spgreen65 said:
Luke, when do we get to see the finished Sci-Fi Robot short you shot with the GH5S? The low light test footage is crazy clean. No post clean up,(noise reduction) correct?
I haven't seen that online yet, should be soon I would think!  No post clean up outside of a few shots that I got in VLog.  The one that is clearly VLog and then a low angle over the water (with obvious different coloring).  Everything else has no noise reduction applied!
Also, everything in that playlist is GH5s footage, with the exception of "The Super Secret Project" which has some GH5s, some GH5.
Some thoughts (also...that thumbnail)
