Mark Romero 2 Posted November 26, 2017 Share Posted November 26, 2017 Noticed the Atomos Ninja Flame 4K recorder is on sale for $595 and am thinking of getting one for my a6500. But I am wondering if it would really make that much of a difference - in particular, to the quality of the 1080p footage. I have searched around the internets and it seems like maybe it doesn't help much with 1080p footage; maybe the only benefit is that it reduces compression artifacts, which are apparently not that high to begin with when using XAVC S codec internally. The other benefit is the brightness of the monitor. Anyone using an external recorder with the a6500 (or a6300) and see any real world benefits in terms of IQ? Looks like the Ninja Flame can record 8-Bit 4:2:2, and as far as I understand, the a6500 / a6300 can output 4:2:2 from HDMI port. Any real world benefit? Thanks in advance. Link to comment Share on other sites More sharing options...
Alex Uzan Posted November 26, 2017 Share Posted November 26, 2017 No, you won’t get any real benefits. The sony a6300/6500 1080p is awful. Worst than any other camera I own. Such a pity since it’s 4k is the better one. I had to buy a gh5 for work (long recording), and I can see that I lost something in IQ. Mark Romero 2 and Geoff CB 2 Link to comment Share on other sites More sharing options...
Mark Romero 2 Posted November 26, 2017 Author Share Posted November 26, 2017 38 minutes ago, Alex Uzan said: No, you won’t get any real benefits. The sony a6300/6500 1080p is awful. Worst than any other camera I own. Such a pity since it’s 4k is the better one. I had to buy a gh5 for work (long recording), and I can see that I lost something in IQ. Thanks for the input. Ok, well I guess I will just continue to use my a6000 for when I need 1080p (mostly for 60fps in sunny conditions so no need for the high iso capabilities of the a6500 sensor). Link to comment Share on other sites More sharing options...
Axel Posted November 26, 2017 Share Posted November 26, 2017 There are certain circumstances in which UHD @100 mbps is a problem: Slog. Even if you bravely try to ETTR all the time, in the real world and in situations of wide dynamic range you'll nonetheless sometimes capture the noise floor. Not necessarily shadows beneath car tires but for instance parts of faces that happened to be heavily backlit. This noise then clots together as macroblocks with banding. You could live with a little noise, but those areas ruin the recording, and you usually see them when it's too late. The GH2 once had all-intra hacks with absurdly high data rates (like 172 instead of 24 mbps), and the fans raved about the added detail. But there wasn't more detail. The hack just preserved all of the noise. The shadows looked more natural, and if there was too much noise, you could perfectly Neat it. A ProRes capture means less compression artifacts, so I wouldn't say it's completely useless. Would I want to schlep a recorder on top of my compact little camera? Definitely not. I try to expose better, and I accept around 5 % rejects where I failed. IronFilm and Mark Romero 2 1 1 Link to comment Share on other sites More sharing options...
Mark Romero 2 Posted November 26, 2017 Author Share Posted November 26, 2017 2 minutes ago, Axel said: There are certain circumstances in which UHD @100 mbps is a problem: Slog. Even if you bravely try to ETTR all the time, in the real world and in situations of wide dynamic range you'll nonetheless sometimes capture the noise floor. Not necessarily shadows beneath car tires but for instance parts of faces that happened to be heavily backlit. This noise then clots together as macroblocks with banding. You could live with a little noise, but those areas ruin the recording, and you usually see them when it's too late. The GH2 once had all-intra hacks with absurdly high data rates (like 172 instead of 24 mbps), and the fans raved about the added detail. But there wasn't more detail. The hack just preserved all of the noise. The shadows looked more natural, and if there was too much noise, you could perfectly Neat it. A ProRes capture means less compression artifacts, so I wouldn't say it's completely useless. Would I want to schlep a recorder on top of my compact little camera? Definitely not. I try to expose better, and I accept around 5 % rejects where I failed. Thanks for sharing your thoughts and experience. Link to comment Share on other sites More sharing options...
ntblowz Posted November 26, 2017 Share Posted November 26, 2017 A63/6500 1080P quality is bad, especially when I cut with sharp cameras like C100MKII, the difference is sooo obvious! my old A5100 have sharper 1080p output. Mark Romero 2 1 Link to comment Share on other sites More sharing options...
Mark Romero 2 Posted November 26, 2017 Author Share Posted November 26, 2017 2 minutes ago, ntblowz said: A63/6500 1080P quality is bad, especially when I cut with sharp cameras like C100MKII, the difference is sooo obvious! my old A5100 have sharper 1080p output. Thanks for the feedback. Yeah, I wish there was an aps-c sensor camera that had the 1080p output of the original a7s Maybe I should just pick up an original a7s and use my APS-C lenses on it for 1080p??? (Since I already have several Sony aps-c lenses and since I am too cheap to buy a Sony 16-35 f/4 lens) Link to comment Share on other sites More sharing options...
Axel Posted November 26, 2017 Share Posted November 26, 2017 3 hours ago, Mark Romero 2 said: The other benefit is the brightness of the monitor. I have the smallHD Focus. Helps with exposure also through false colors. I don't worry about the said car tire shadows, but you always want to expose skin correctly. Kisaha and Mark Romero 2 2 Link to comment Share on other sites More sharing options...
Mark Romero 2 Posted November 26, 2017 Author Share Posted November 26, 2017 4 minutes ago, Axel said: I have the smallHD Focus. Helps with exposure also through false colors. I don't worry about the said car tire shadows, but you always want to expose skin correctly. Thanks again! Link to comment Share on other sites More sharing options...
T@M Posted January 21, 2019 Share Posted January 21, 2019 Hi, old topic but my question is related. I know the 1080 is bad, and that it's probably not any better on a external monitor but what about filming in 4K internal and simultaneously recording HD externally? Or does it always send out the same crappy HD IQ? Link to comment Share on other sites More sharing options...
Mark Romero 2 Posted January 23, 2019 Author Share Posted January 23, 2019 On 1/21/2019 at 7:45 AM, T@M said: Hi, old topic but my question is related. I know the 1080 is bad, and that it's probably not any better on a external monitor but what about filming in 4K internal and simultaneously recording HD externally? Or does it always send out the same crappy HD IQ? I haven't tried, but I don't think you can record 4K internally and HD externally, can you??? I would imagine that you can only record an internal "proxy" file at a lower resolution if you are recording externally. But don't want to swear by that. And I am not sure there would be any real benefit anyway since (pretty much) the only reason to record in 1080p on an a6500 / a6300 / a6400 is for the higher frame rates so you will have slow motion. But if you were ABLE to record internally to 4K then you would be stuck to the lower 30fps max frame rates, which (pretty much) defeats the purpose of shooting in 1080p. To be honest, if I need to shot in 1080p, I either use my a6000 or I shoot at a very narrow depth of field on my a6500 which kind of helps to "hide" some of the nastiness in the out-of-focus areas. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted January 23, 2019 Share Posted January 23, 2019 Doesn't the original A7S have a S35 crop mode? Link to comment Share on other sites More sharing options...
webrunner5 Posted January 23, 2019 Share Posted January 23, 2019 1 hour ago, thebrothersthre3 said: Doesn't the original A7S have a S35 crop mode? Yes it does. And the A7s has a great 1080p. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted January 23, 2019 Share Posted January 23, 2019 13 minutes ago, webrunner5 said: Yes it does. And the A7s has a great 1080p. Looks like you can get em for about he same price as the A6500, used that is. Not as good of a stills camera if you are a photographer as well tho. Link to comment Share on other sites More sharing options...
webrunner5 Posted January 23, 2019 Share Posted January 23, 2019 Well I found as a FF camera it seemed to be pretty good at Photos. An 11 x 18 print is no problem for one. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted January 23, 2019 Share Posted January 23, 2019 Just now, webrunner5 said: Well I found as a FF camera it seemed to be pretty good at Photos. An 11 x 18 print is no problem for one. Not if you are one of those megapixel junkies though. I'd be content with it. webrunner5 1 Link to comment Share on other sites More sharing options...
Leonardo Posted April 9, 2020 Share Posted April 9, 2020 On 1/21/2019 at 12:45 PM, T@M said: Hi, old topic but my question is related. I know the 1080 is bad, and that it's probably not any better on a external monitor but what about filming in 4K internal and simultaneously recording HD externally? Or does it always send out the same crappy HD IQ? Hi, I was messing around with my Ninja V and my Sony a6400, and I notice that when I put the HDMI on 1080P output in the HDMI Menu, and the camera is set for 4K 25P Recording, I can record HD 1080 25p on the Ninja V and with much better resolution. Anyone that has this configuration, please try it out. Link to comment Share on other sites More sharing options...
Leonardo Posted April 9, 2020 Share Posted April 9, 2020 Hi, I was messing around with my Ninja V and my Sony a6400, and I notice that when I put the HDMI on 1080P output in the HDMI Menu, and the camera is set for 4K 25P Recording, I can record HD 1080 25p on the Ninja V and with much better resolution. Anyone that has this configuration, please try it out. You need to select on the menu 4K output select: Memory card+HDMI. You loose face tracking but I always use manual focus. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted April 9, 2020 Share Posted April 9, 2020 8 hours ago, Leonardo said: Hi, I was messing around with my Ninja V and my Sony a6400, and I notice that when I put the HDMI on 1080P output in the HDMI Menu, and the camera is set for 4K 25P Recording, I can record HD 1080 25p on the Ninja V and with much better resolution. Anyone that has this configuration, please try it out. You need to select on the menu 4K output select: Memory card+HDMI. You loose face tracking but I always use manual focus. Yeah downscaled 4k looks better but that doesn't allow you to get 60fps Link to comment Share on other sites More sharing options...
barefoot_dp Posted April 10, 2020 Share Posted April 10, 2020 While we're talking about the a6xxx's, has anyone had any problems with playback in Windows or Premiere? I find that Windows seems to play the clips from my a6400 (HLG) back with extreme overexposure. A clip with proper exposure will playback almost completely white. Once I bring them into Premiere the colour is fine, but changing the playback speed gives stuttering playback in a very strange way. It''s almost like every individual GOP is split in half and played back to front. So for example, it'll play back frames 16-30, then frames 1-15, then frames 46-60, then frames 31-45, etc, etc. This is on two different machines both with Windows 10 and Premiere Pro 2019 & 2020. Link to comment Share on other sites More sharing options...
