Parker Posted January 28, 2020 Share Posted January 28, 2020 @mercer The thing I always notice about GHAlex compared to other luts is how it just adds a nice sort of clear separation to the skin tones, in both color and b&w. It just adds a midtone pop that I really like. mercer and Sage 2 Link to comment Share on other sites More sharing options...
Sage Posted January 29, 2020 Author Share Posted January 29, 2020 The 1080p mode on the GH5 is really quite good; if like me, you are happy with a dense 2K image, then 1080p offers the most bitrate saturated options in the camera (no affect on color) Cine-D has a slight bit depth density edge over VLog, while VLog has a slight extreme gamut edge. With 8 bit, Cine-D is decidedly better Great work Parker and Benjamin! Alas, I've got to get the next update out.. Just finished writing one last tool that I believe will be critical for automating camera support, to do the Exp Pres (it is the fourth 'sub-section' of the ECE) Parker and mercer 2 Link to comment Share on other sites More sharing options...
mercer Posted January 29, 2020 Share Posted January 29, 2020 12 minutes ago, Sage said: Cine-D has a slight bit depth density edge over VLog, while VLog has a slight extreme gamut edge. I assume you have specific, recommended settings for CineLikeD? I'm mostly curious how the highlight detail is with CineLikeD compared to vLogL after it's run through your process? If I can find a GH5 at the right price, 1080p will be my mode of choice so it's good to hear that the quality is so good... especially since you can use the cheaper SD cards. Video Hummus 1 Link to comment Share on other sites More sharing options...
Video Hummus Posted January 29, 2020 Share Posted January 29, 2020 2 minutes ago, mercer said: I assume you have specific, recommended settings for CineLikeD? I'm mostly curious how the highlight detail is with CineLikeD compared to vLogL after it's run through your process? If I can find a GH5 at the right price, 1080p will be my mode of choice so it's good to hear that the quality is so good... especially since you can use the cheaper SD cards. I'm curious as well. Link to comment Share on other sites More sharing options...
Sage Posted January 29, 2020 Author Share Posted January 29, 2020 With Cine-D, you'll want to set Saturation to -5, and the rest at default. Also, use ISO 200 (instead of 400; 200 is the electronic equivalent of HLG/VLog's 400). Highlight range (and gamut) are a 1:1 with HLG/VLog, once PRE'd. Here is an overlay of samples clipping (VLog overlayed on Cine-D): mercer 1 Link to comment Share on other sites More sharing options...
mercer Posted January 29, 2020 Share Posted January 29, 2020 6 minutes ago, Sage said: With Cine-D, you'll want to set Saturation to -5, and the rest at default. Including Sharpness and Noise Reduction? 6 minutes ago, Sage said: Also, use ISO 200 (instead of 400; 200 is the electronic equivalent of HLG/VLog's 400). I assume you mean as a base ISO and not an only ISO? Obviously, like with most cameras, it's best to stay as close to base ISO as possible. Link to comment Share on other sites More sharing options...
mercer Posted January 29, 2020 Share Posted January 29, 2020 12 minutes ago, Sage said: Highlight range (and gamut) are a 1:1 with HLG/VLog, once PRE'd. Here is an overlay of samples clipping (VLog overlayed on Cine-D): And finally do you recommend a similar exposure process with CineLikeD as you do with vLogL? I haven't read your manual but I assume it's either an ETTR or a waveform exposure putting skin tones around 60 IRE... or whatever! Link to comment Share on other sites More sharing options...
Sage Posted January 29, 2020 Author Share Posted January 29, 2020 Sharpness at -5 for sure. NR can be a personal preference (some are noise averse and prefer the ease of NR in cam). Though -5 would be the Arri equivalent, from a purist perspective. Indeed, for VLog, 400 is the base. Then it goes to 200 for Cine-D, but this is just the labeling (200 really is 400, in VLog land) Yes; lately I've been recommending the simple rule of thumb to anchor everything around the center of the waveform (leaning higher rather than lower), no matter the profile. This is because all profiles share this middle 'cross point', and diverge from there (with varying contrasts), and 50-60 is generally where midtones should place (in exposure for EC709, not for post placement). The great news is that exposure/luma is about to become a breeze, in roughly a week. Video Hummus and majoraxis 2 Link to comment Share on other sites More sharing options...
Video Hummus Posted January 29, 2020 Share Posted January 29, 2020 Vlog does have the custom view assist .VLTs...otherwise, I don't see many drawbacks to shooting CineD. Sage 1 Link to comment Share on other sites More sharing options...
seku Posted January 29, 2020 Share Posted January 29, 2020 7 hours ago, Sage said: The great news is that exposure/luma is about to become a breeze, in roughly a week. I'm really curious what you came up with Right now im using CST's to linear and back to do my pre-GHa exposure. Looking forward to your solution! Link to comment Share on other sites More sharing options...
Attila Bakos Posted January 29, 2020 Share Posted January 29, 2020 54 minutes ago, seku said: I'm really curious what you came up with Right now im using CST's to linear and back to do my pre-GHa exposure. Looking forward to your solution! There is a lesser known one node solution to this: https://www.eoshd.com/comments/topic/41483-the-video-that-shows-blackmagic-pocket-4k-raw-image-quality-is-same-as-gh5s-400mbit/page/4/?tab=comments#comment-336234 Link to comment Share on other sites More sharing options...
seku Posted January 29, 2020 Share Posted January 29, 2020 thanks @Attila Bakos! i'll give it a try tonight and see which i prefer Link to comment Share on other sites More sharing options...
JISU Posted January 29, 2020 Share Posted January 29, 2020 I bought ghalex in 2018. I have not received any update mail since V3. Is there a V4 version? I only received 33X at the time, how can I get the 65X version? Link to comment Share on other sites More sharing options...
Sage Posted January 29, 2020 Author Share Posted January 29, 2020 They are Exposure Pres, conversions made with the same interpolation system as the other conversions (converting color in the mix). Its a lot of fun to use in conjunction with the conversion. The P4Ka workflow video shows it in action in Resolve, though it applies to every NLE (and the Posts, which are an essential part of the picture): They may be stacked in order of greatest to least, and all may be used in conjunction with gain key/opacity to dial in an exact value (Post or Pre). mirekti, seku and majoraxis 3 Link to comment Share on other sites More sharing options...
Benjamin Hilton Posted January 30, 2020 Share Posted January 30, 2020 On 1/28/2020 at 12:10 AM, billdoubleu said: @Benjamin Hilton, this looks great! What lenses and/ or filters did you use? Leica photo primes and an nd filter for the interviews Link to comment Share on other sites More sharing options...
Benjamin Hilton Posted January 30, 2020 Share Posted January 30, 2020 On 1/28/2020 at 2:23 PM, mercer said: After watching a lot of Netflix's original programming, I have a growing fondness for that modern, Red look and redcode color science. So, yes that is a great compliment and makes the GH5 a little bit more appealing to me... maybe @Sage can create a GHred workflow in the future. In my opinion, this seems more appealing than making an Alex version for every camera on the market. Can you share the video you showed the director from the TV station? Here it is: majoraxis and Jonesy Jones 2 Link to comment Share on other sites More sharing options...
BjornT Posted February 19, 2020 Share Posted February 19, 2020 Any news @Sage on when we can expect the GH5 update? Link to comment Share on other sites More sharing options...
Sage Posted February 19, 2020 Author Share Posted February 19, 2020 4 hours ago, BjornT said: Any news @Sage on when we can expect the GH5 update? Within the week; I'm finishing the last details and trying to figure out email. Email is a logistical nightmare heart0less, majoraxis, Wild Ranger and 2 others 5 Link to comment Share on other sites More sharing options...
deezid Posted February 19, 2020 Share Posted February 19, 2020 7 hours ago, Sage said: Email is a logistical nightmare tell me about it. Have to do everything manually too many customers. 😄 Sage 1 Link to comment Share on other sites More sharing options...
saame Posted March 3, 2020 Share Posted March 3, 2020 @Sage On the V4 documentation in your website, under Post-workflow, it says that "1. If you recorded to Cine-D (Sat -5), HLG, or VLog to ProRes/DnxHD on an external recorder, apply the appropriate [PRE] file to the first node to convert to normative VLog in advance of the color conversion." Currently I'm shooting 10bit 4:2:2 HD 200Mbps ALL-I in camera, but converting it to 10bit 422 DNxHD (with the great "V6" tool by Wayne Norton) before bringing them into Resolve, as Resolve doesn't recognize the straight-out-of-camera GH5 10bit files... Do I still need to apply the [PRE] file in my workflow as my files are now in DNxHD codec inside Resolve? Sorry if this is a silly question, but I'm still trying to truly understand how the different codecs work and where data / video levels come in. Also, when can we expect the V4 update in mail? Or were they sent already and my mailbox blocked it? Link to comment Share on other sites More sharing options...
