Administrators Andrew Reid Posted December 14, 2017 Administrators Share Posted December 14, 2017 Apple have pulled one out of the bag here. A neural network powered image processor and dual-4K image sensors, on something that isn't a proper camera. Read the article webrunner5 1 Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted December 14, 2017 Super Members Share Posted December 14, 2017 Great article. "Why do you still need us to take the card out, put it in a computer, open software, re-touch and re-size with a mouse and keyboard, save to a hard drive and then upload the image to Facebook with a web browser? This isn’t 2007." This haven't been needed in a long time. I transfer raw files from my camera to my phone and edit in Lightroom before uploading. But I get your point Link to comment Share on other sites More sharing options...
salim Posted December 14, 2017 Share Posted December 14, 2017 I see this micro stuttering when you were panning. I wonder if the OIS is not that good in video mode. It like the OIS is trying to hold on stability and then they let go and it catches it again. vaga 1 Link to comment Share on other sites More sharing options...
sanveer Posted December 14, 2017 Share Posted December 14, 2017 12 minutes ago, salim said: I see this micro stuttering when you were panning. I wonder if the OIS is not that good in video mode. It like the OIS is trying to hold on stability and then they let go and it catches it again. It happens with most smartphone cameras since they only compensate for pitch and roll, and not for the yaw axis. kaylee and salim 2 Link to comment Share on other sites More sharing options...
Eduardo Granadsztejn Posted December 14, 2017 Share Posted December 14, 2017 The camera is exact the same as the Iphone 8+? Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted December 14, 2017 Author Administrators Share Posted December 14, 2017 1 hour ago, Eduardo Granadsztejn said: The camera is exact the same as the Iphone 8+? Nope. Faster lens on the telephoto camera for a start. Link to comment Share on other sites More sharing options...
gt3rs Posted December 16, 2017 Share Posted December 16, 2017 Andrew, are you sure that Filmic Pro can turn off both EIS and OIS? this would be cool because OIS doesn't play well with gimbals like the Osmo.... I read that on older iPhones you could not disable the OIS.... Filmic Pro is probably the best app right now but I'm very frustrated with it... the "manual" exposure control are quite bad IMO. First if you set let say 240 fps capture and it allows to go to 1/60... ISO cannot be really set but just biased and it does not really work well, on low light it may max out at 486 ISO but in day light you can go to 900 ISO.... really wired... Would be cool to be able to set shutter angle and let ISO float and use ND to correct if needed but I could not find a way.... You lock the shutter speed at 1/480 and you try to influence the iso with the bias and boom it changes back to 1/60 even if it is locked.... Also at the moment the framerate are all over the place... you set 240 capture and 240 playback I get a file that 200fps.... if I set 240 capture and 25 playback I get a 15 fps file.... Additionally if you save the file from filmic pro to the photo library is converting it from h265 to h264.... why? Would be nice to know what is others experience because at the moment I cannot really trust this app.... So for me I really like the iPhone X and the cameras have potential but the apps are not there IMO, the default one is super limited that is almost embarrassing and Filmic Pro has potential but seems very buggy. Link to comment Share on other sites More sharing options...
JR33D Posted December 21, 2017 Share Posted December 21, 2017 As to this CON: Portrait mode shallow DOF works in real-time on screen, so why not in video mode? I've had some shots where it doesn't even sort out an image on screen or in a still. For instance, if there's not enough distance between your subject and a semi transparent background like a chainlink fence. I've seen portrait mode get confused and blur the fence out in some areas and not others. Same if the subject is in front of a window that the camera can see through in some spots, but where the deeper background is partially obscured by reflections. I would expect trying to apply that level of ai to a similarly confusing situation in video would create strange and awful results. Link to comment Share on other sites More sharing options...
Bob Turnip Posted June 11, 2018 Share Posted June 11, 2018 You've been drinking the Cupertino Kool aid. Neural Nets have been used in quantizing and stream processing for years, they are nothing new and nothing special. Old gif encoders often used neural net quantizing. And often not even particularly effective compared to more traditional algorithms. Link to comment Share on other sites More sharing options...
webrunner5 Posted June 12, 2018 Share Posted June 12, 2018 Yeah like I said I just got my Apple X, 256gb back from my son. So I need to put it to work as they say. I am pretty impressed with it so far just phone wise. Better than my last iPhone 6s Plus, 256gb. My Samsung Note 8 I had was just too damn big. My Last Note. I have had 3 of them, no more. Just too damn big and heavy for a pants camera. But for watching movies hard to beat. I shot this today on the Apple X Photo mode, Not a great one, but not something you don't see very often. Right place, right time. In Hamilton, Ohio. IMG_0005[1].MOV Link to comment Share on other sites More sharing options...
