A.T. Posted January 7, 2018 Share Posted January 7, 2018 Holy Smoke Does no one shoot video with a 1Dx? Am I the only guy who shoots video with a 1Dx? Am I the only guys using Nikon manual focus AiS lenses? Holy crap. Somebody out there please tell me what's up with my match needle metering in LiveView using manual lenses with the 1Dx. The histogram is fine but the needle meter reading is out to lunch. It's only an issue in LiveView. I don't have this problem with my 5D MII. Any ideas would be much appreciated. Cheers A.T. Link to comment Share on other sites More sharing options...
webrunner5 Posted January 7, 2018 Share Posted January 7, 2018 I did some research and I found very little on the problem. There are several 1Dx shooters on here. Hopefully one will respond. Link to comment Share on other sites More sharing options...
A.T. Posted January 10, 2018 Author Share Posted January 10, 2018 Thanks. I think I've figured this out. This was a problem with some of the other models as well. It's a little weird but it looks like the camera remembers the last f stop setting of the last Canon lens mounted on the camera and uses that as some kind of registration for the meter system. I tested this with a few of my Canon lenses, 24-70 2.8, 50 1.4. If I have the 50 set to 5.6, then shut down the camera and swap to one of my old Nikon lenses the match needle in LiveView is way off. If I go back to the 50, set it to 1.4 then shut down, remove the lens and go back to the Nikon lens, the meter then works pretty much as expected. So what if I go from a Canon f 4.0 or 2.8 lens back to a Nikon lens you ask? The match needle metering is then messed up. I have to go from the 50 1.4 set to 1.4, shut down and then swap to the Nikon for the meter to be ok. Now I wonder if that is also the case if I'm using a Nikon F 2.0. lens. Do I first have to have a Canon f 2.0 set to f 2.0 when shutting down before going to a Nikon f 2.0 lens? What makes this so freakin' frustrating is that this stuff doesn't happen with my lesser 5D. Aaaaaaaargh! A.T. Link to comment Share on other sites More sharing options...
