maxotics Posted January 10, 2018 Share Posted January 10, 2018 In my ongoing self-appointed role as "LOG gamma" police, I've created a video that shows how RAW is processed into images we use, both for photography and video. It drives me nuts that people talk about 14+ stops of DR, as if noise, or sensor pixel sensitivity, stays constant from lower to higher values. After 5 stops, IMHO, noise makes any extra DR recorded by the sensor quite undesirable. Further, even in 5 stops of DR there is a huge difference between how well cameras record DR even in fairly well exposed image. That is to say, the GH5S isn't better only because it can record in low light. It can be better because even at ISO 800 it will get a richer image in the shadows. However, it is still 8-bit. It still throws out gobs of sensor data. Well, enough of that. Another video to put you to sleep teddoman, EthanAlexander, PannySVHS and 2 others 4 1 Link to comment Share on other sites More sharing options...
teddoman Posted January 10, 2018 Share Posted January 10, 2018 Great explainer. Helpful primer on photographic data. You should be a teacher, if you aren't one already. maxotics 1 Link to comment Share on other sites More sharing options...
seku Posted January 10, 2018 Share Posted January 10, 2018 Walking through the debayering and log curve in Excel is genius! I need to give it a try as well, thanks for the great video! Link to comment Share on other sites More sharing options...
PannySVHS Posted January 10, 2018 Share Posted January 10, 2018 48 minutes ago, teddoman said: Great explainer. Helpful primer on photographic data. You should be a teacher, if you aren't one already. Max is a great teacher but it would be cool two have the same content with less real time:) Cut the same fantastic content from a 27min video to a 15min video. Great knowledge, just a little, little bit much real time action.:) Link to comment Share on other sites More sharing options...
EthanAlexander Posted January 10, 2018 Share Posted January 10, 2018 Please change your member status to "Log Police" in your profile maxotics, PannySVHS and teddoman 2 1 Link to comment Share on other sites More sharing options...
maxotics Posted January 10, 2018 Author Share Posted January 10, 2018 49 minutes ago, seku said: I need to give it a try as well I put the Excel file where you, or anyone, can get it, if interested in the code. It's a freakin' mess. Lost of old stuff in there, but if you're like me, you just need to poke around to get what bits you want. The hardest part for me was figuring out how to get the RAW data out as integer values. Turned out it could be done in a few lines of Python code. Excel with VBA Download: https://drive.google.com/open?id=1d6-tBeVcbyiVOCXgSRiV2eNe80ipfruR PYTHON import rawpy import numpy raw = rawpy.imread('D:\\Files2018_Maxotics_Analysis\\RAWExplainDR\\7D_RAW\\DNGs\\M08-2120_DNG_000001\\M08-2120_000520.DNG') rawdata = raw.raw_image numpy.savetxt("D:\\Files2018_Maxotics_Analysis\\RAWExplainDR\\7D_RAW\\DataToCSVs\\dng520.csv", rawdata, delimiter=",") seku 1 Link to comment Share on other sites More sharing options...
seku Posted January 10, 2018 Share Posted January 10, 2018 thanks a lot! Link to comment Share on other sites More sharing options...
EthanAlexander Posted January 10, 2018 Share Posted January 10, 2018 @maxotics YESSSS! And here's your profile pic: Ricardo Constantino, maxotics, mercer and 2 others 3 2 Link to comment Share on other sites More sharing options...
