webrunner5 Posted January 13, 2018 Share Posted January 13, 2018 This ought to make Zak and others a bit happier. http://www.4kshooters.net/2018/01/12/panasonic-au-eva1-new-firmware-update-ver-1-10-released/ Zak Forsman 1 Link to comment Share on other sites More sharing options...
Rinad Amir Posted January 13, 2018 Share Posted January 13, 2018 FIXED – When the HDMI output is connected to BT-LH1850 monitor and displayed on it, once the monitor’s input setting is switched to SDI, “No Signal” is shown and no image will be displayed any more even if the setting is put back to HDMI. Display of SENSOR TEMP at low temperatures is improved. FIXED – Panning at high speed may cause ghosting. FIXED – Focus Assists are not displayed on the SDI output destination when the LCD panel is disconnected. FIXED – An image on the LCD is defective when Open Iris F. A. is enabled. FIXED – Even if the Wi-Fi setting is switched from INFRA to DIRECT, the display of IP address will not change. FIXED – The camera cannot connect to Wi-Fi using D-Link DWA-171 (For Australian Market). Error in information superimposed on SDI (payload) at 24.00 Hz is corrected to 60.00. Link to comment Share on other sites More sharing options...
NealXu Posted January 16, 2018 Share Posted January 16, 2018 Hi....I may not have shot with the camera yet, but have seen it in person, went through the menus on a pre-pro/engineering model and now can’t wait to get my hands on one from a rental house and use on a project or two just to see what it can do. From the test above, I can’t really tell much, but the HotRod Cameras footage looks pretty sweet. Link to comment Share on other sites More sharing options...
