Kasper Mols Posted May 6, 2013 Share Posted May 6, 2013 I recently invested in this Kowa lens, and I have been in love with it ever since, it is razor sharp, focusses fine and not too heavy. It doesn't flare extremely, but that might be the fault of the FD lens? I am looking for a way to adapt an VariND filter to this setup, so I can start to shoot close to wide open, while keeping the shutter speed on 1/50. I went to the camerastore and no filter size would fit, although it does have a thread. Any tips? The filtersize is around 46-47mm. Link to comment Share on other sites More sharing options...
Rob Bannister Posted May 6, 2013 Share Posted May 6, 2013 It looks like you have a Redstate clamp on there so just get the filter clamp and you are all set. It is a 72mm which my diopters fit and then get cheap step up rings for like 72-77 or 72-82 Link to comment Share on other sites More sharing options...
Lucian Posted May 6, 2013 Share Posted May 6, 2013 Casper looks like you need another clamp with a thread on the front. Redstan and vidatlantic both make them. Link to comment Share on other sites More sharing options...
Hans Punk Posted May 6, 2013 Share Posted May 6, 2013 I would highly recommend a Redstan front filter clamp. If you need an 'emergency' or temporary solution I would suggest putting multiple passes of PVC black electrical insulation tape around the front ring area to build up a diameter, then firmly (but carefully) push on a large step ring that gives you a thread that you can then attach a VariND or other filters to. It is not a substitute for a proper clamp, but can work well if the step ring is wedged on there nice and tight. Link to comment Share on other sites More sharing options...
tony wilson Posted May 6, 2013 Share Posted May 6, 2013 It looks like you have a Redstate clamp on there so just get the filter clamp and you are all set. It is a 72mm which my diopters fit and then get cheap step up rings for like 72-77 or 72-82 redstate clamp more like shit state :) that back clamp is a vid china job Link to comment Share on other sites More sharing options...
Rob Bannister Posted May 6, 2013 Share Posted May 6, 2013 ah I was looking at it on my phone I didnt see the difference but I would highly recommend the redstan clamps. I have the back and front ones for my Kowa 16 and they work really really well. Link to comment Share on other sites More sharing options...
Portable Posted March 18, 2019 Share Posted March 18, 2019 Hi did you find a solution,i have exactly the same adapter and issue... Alan Link to comment Share on other sites More sharing options...
Tito Ferradans Posted March 19, 2019 Share Posted March 19, 2019 Rapido Technology or Redstan. Link to comment Share on other sites More sharing options...
