Clovis Posted February 15, 2018 Share Posted February 15, 2018 Hi all, I really hope someone at Panasonic reads this. If they can do [C4K] 4096x2160, 59.94p, 150Mbps (4:2:0 8-bit LongGOP) and [C4K] 4096x2160, 24.00p, 400Mbps (4:2:2 10-bit ALL-Intra), would it be possible to do [C4K] 4096x2160, 25.00p, 400Mbps (4:2:2 10-bit ALL-Intra) ? C'mon, 1 tiny little frame more ... filmspa 1 Link to comment Share on other sites More sharing options...
jonpais Posted February 15, 2018 Share Posted February 15, 2018 You can deliver your project in 25p and I can almost guarantee nobody would notice. Link to comment Share on other sites More sharing options...
jagnje Posted February 15, 2018 Share Posted February 15, 2018 But you need to re-sync the audio if you want it done properly. Shooting under artificial non cine lights and you get flicker. Link to comment Share on other sites More sharing options...
jonpais Posted February 16, 2018 Share Posted February 16, 2018 @Clovis I see... I’m assuming you’re in a 50Hz country. How about shooting at 24p 1/50? Link to comment Share on other sites More sharing options...
IronFilm Posted February 16, 2018 Share Posted February 16, 2018 Is of course what everyone does (or 1/60th if in the other half of the world). As who the hell lives in a country with 48hz electricity? :-P Link to comment Share on other sites More sharing options...
jonpais Posted February 16, 2018 Share Posted February 16, 2018 25p and 30p are frame rates for television so I don’t see Panasonic including them in a cinema format. Link to comment Share on other sites More sharing options...
IronFilm Posted February 16, 2018 Share Posted February 16, 2018 2 minutes ago, jonpais said: 25p and 30p are frame rates for television so I don’t see Panasonic including them in a cinema format. Is silly though, as shooting say 30fps can give a nice subtle slow motion effect to some shots once slowed down to the base frame rate. If the camera was capable of higher frame rates, it would be nice to have it. Link to comment Share on other sites More sharing options...
jonpais Posted February 16, 2018 Share Posted February 16, 2018 Yeah, 30p slowed down to 24p can look nice. Link to comment Share on other sites More sharing options...
jagnje Posted February 16, 2018 Share Posted February 16, 2018 it`s not that 25p is for television, it`s a pal/ntsc thing...it`s a necesity! But yes, a cine package(DCP) is 24p and we have to re-sync everything when delivering for cinema and festivals. Link to comment Share on other sites More sharing options...
jonpais Posted February 16, 2018 Share Posted February 16, 2018 @jagnje PAL and NTSC were developed for television. Link to comment Share on other sites More sharing options...
jagnje Posted February 16, 2018 Share Posted February 16, 2018 yes, but to the regard of the electrical current frequency. US has a 60Hz electrical current, while most of the EU uses 50Hz. 24, 48, 60fps sync with 60Hz to avoid flicker in US , while the EU as you may gues uses 25, 50 fps to avoid flicker in 50Hz. Link to comment Share on other sites More sharing options...
Clovis Posted February 16, 2018 Author Share Posted February 16, 2018 Very true jagnje. Yes, indeed living in a PAL-country. It is just that the combo 400Mbps, 4:2:2 10-bit ALL-Intra (very appealing as a codec) and 25p in [C4K] 4096x2160 isn't available on the GH5s, even though I think it could be possible. It should be included in a next firmware update. filmspa 1 Link to comment Share on other sites More sharing options...
hijodeibn Posted February 16, 2018 Share Posted February 16, 2018 13 hours ago, jagnje said: yes, but to the regard of the electrical current frequency. US has a 60Hz electrical current, while most of the EU uses 50Hz. 24, 48, 60fps sync with 60Hz to avoid flicker in US , while the EU as you may gues uses 25, 50 fps to avoid flicker in 50Hz. A solution is to use the flicker free program in premiere, it is really good, you will remove all the flicker in a few seconds.....since I doubt 25p and 30p will be included in the near future...for Audit sync it is more work, but anyway doable... Link to comment Share on other sites More sharing options...
fuzzynormal Posted February 17, 2018 Share Posted February 17, 2018 I like SECAM. Link to comment Share on other sites More sharing options...
