jagnje Posted February 19, 2018 Share Posted February 19, 2018 https://www.bhphotovideo.com/c/product/890536-REG/ikan_vh8_e6_8_HDMI_Monitor_With.html Probably not the best out there, but for sure better than bmpcc stock monitor Anybody got one? Link to comment Share on other sites More sharing options...
cantsin Posted February 19, 2018 Share Posted February 19, 2018 Avoid external monitors with the BMPCC. Its HDMI port is directly soldered onto the mainboard and breaks easily if the cable is pulled too hard. When it breaks, your camera is toast. (Using cages with lock screws for the HDMI port helps, but doesn't completely solve the issue. Most broken BMPCCs died because of HDMI. It's the camera's known achilles heel, discussed on forums again and again. If you want external monitoring, better use the Blackmagic Micro Cinema Camera where this issue has been solved.) Link to comment Share on other sites More sharing options...
Mark Romero 2 Posted February 19, 2018 Share Posted February 19, 2018 Will this work with 4K hdmi out from camera or just HD out? Link to comment Share on other sites More sharing options...
majoraxis Posted February 19, 2018 Share Posted February 19, 2018 I believe it is 1080p max resolution for the input source. The LED panel itself is 1600 x 768 resolution. Link to comment Share on other sites More sharing options...
greenscreen Posted February 22, 2018 Share Posted February 22, 2018 It is 199! Pity not similar bargain but for 4K! Link to comment Share on other sites More sharing options...
