Vautksch Posted March 11, 2018 Share Posted March 11, 2018 Hey peepz, A friend of mine wants to shoot stills and video for fun. Just wants to play a little. He asked for advise and I would like to recommend A camera (that shoots 1080p25 in a ok codec) A Vari ND filter (no high quality needed) A Monitor that has false color, 5" for 300€. I have adapters and a couple of russian/old german lenses that I would loan to him. I thought a GH2 with some feelworld monitor and cheapo vari ND would fit in this budget. Any ideas for monitor? Better camera option? Thanks Tim Link to comment Share on other sites More sharing options...
JordanWright Posted March 11, 2018 Share Posted March 11, 2018 If the GH2 monitor isn't that bad (I haven't used it) I would skip an external monitor and put that money into the vari ND instead. Link to comment Share on other sites More sharing options...
mercer Posted March 11, 2018 Share Posted March 11, 2018 Yeah, video monitors are cumbersome on small cameras and draw unwanted attention. Link to comment Share on other sites More sharing options...
webrunner5 Posted March 12, 2018 Share Posted March 12, 2018 Speaking about False Color. Cheap solution for you high roller Sony Guys. https://www.fs7handbuch.de/false-color-for-sony Link to comment Share on other sites More sharing options...
Aussie Ash Posted March 12, 2018 Share Posted March 12, 2018 Second hand Sony A5100 CineAlta 1 Link to comment Share on other sites More sharing options...
IronFilm Posted March 12, 2018 Share Posted March 12, 2018 Secondhand Panasonic GH2 SLR Magic VND FeelWorld F570 That blows your budget however.... but I don't see the point in going any cheaper. If you want to go cheaper, then you need to ditch something, be it the VND or the monitor. Link to comment Share on other sites More sharing options...
CineAlta Posted March 12, 2018 Share Posted March 12, 2018 Sony NEX5N or NEX5R or NEX5T all make very nice pictures and are priced at around 150eur for a body. Screen flips and can accept a loupe too. Tech heads will moan about the avchd codec but it's the same codec they gave c100 and fs100 users for in body recording. Add a focal reducer adaptor and he will have an extra stop of light and will gain full frame field of view from your lenses meaning a basic 35mm/2.8 russian lens will become a 25mm/2 lens. Focal reducer: https://www.ebay.es/itm/Focal-Reducer-Speed-Booster-Canon-EOS-mount-Lens-to-Sony-E-Adapter-NEX-7-5-A6500/351338788897?hash=item51cd6c7821:g:SFoAAOSwBahU~~~G That's quite a bit under budget and will allow a nice variable nd, some spare ex-pro batteries and will work with even the cheapest sd cards. edit~~ Additionally all of the above cameras shoot up to 50p in full hd. Slow mo is a nice addition Aussie Ash and IronFilm 1 1 Link to comment Share on other sites More sharing options...
cantsin Posted March 12, 2018 Share Posted March 12, 2018 20 hours ago, Vautksch said: A camera (that shoots 1080p25 in a ok codec) A Vari ND filter (no high quality needed) A Monitor that has false color, 5" for 300€. A used GH2, NEX-5N or 550D/T2i, depending on needs/preferences: GH2 has the cleanest/sharpest image, 550D the mushiest but the best colors, NEX-5N is in between the two. GH2 is the only camera with an EVF (unless you get the screw-on EVF for the NEX-5N). GH2 and NEX-5N can adapt more lenses because of their mirrorless mounts. But: NEX-5N and 550D are better for adapting vintage SLR lenses because of their bigger APS-C sensors; building a lens kit is cheaper with these two cameras, since you can use a 35mm lens as a standard lens and a 50mm lens as a portrait lens. (Unless you use a focal reducer for the GH2 which will cost you another $100.) Cheapo vari ND filter: Fotga Vari ND. @Mattias Burling tested it some time ago, and it seems to give decent bang-for-the-buck: External monitor: 5" monitors actually tend to be expensive, go for a cheaper 7" monitor. The brand (Feelworld, Lilliput, ...) doesn't matter so much. Link to comment Share on other sites More sharing options...
Kisaha Posted March 13, 2018 Share Posted March 13, 2018 This is an interesting video which is called "Tiny cinema camera kit for under $250" The cheap Fotga's are ok for the price, if you do not go to extremities can hold quite ok (for the price!). Don Kotlos 1 Link to comment Share on other sites More sharing options...
