Snuff Posted October 22, 2018 Share Posted October 22, 2018 Blackmagic pocket cinema camera 4k test (lowlight) with Panasonic 12-35 f.2.8 first gen (4K DCI Raw Lossless iso 1250 f2.8) shot with only one photography guide light + soft box deezid, Adept and majoraxis 3 Link to comment Share on other sites More sharing options...
IronFilm Posted October 22, 2018 Share Posted October 22, 2018 On 10/22/2018 at 4:04 AM, Chrad said: Hollywood loves the Alexa for its reliability as much as anything else. ""Nobody ever got fired for buying IBM."" On 10/22/2018 at 4:12 AM, Andrew Reid said: Remind me... Is C200 raw internal or external? I have forgotten LOL. C200 can't even output 10bit externally, otherwise that would solve the "middle codec" problem of the C200 for some people. Link to comment Share on other sites More sharing options...
webrunner5 Posted October 22, 2018 Share Posted October 22, 2018 1 hour ago, Snuff said: Blackmagic pocket cinema camera 4k test (lowlight) with Panasonic 12-35 f.2.8 first gen (4K DCI Raw Lossless iso 1250 f2.8) shot with only one photography guide light + soft box Out of likes. Wow that is some thick looking footage. Can't complain about that. Chrad 1 Link to comment Share on other sites More sharing options...
IronFilm Posted October 22, 2018 Share Posted October 22, 2018 22 hours ago, Mattias Burling said: And with a lot of $$$$$$ spent on lights. And a lot of time spent on set And time = $$$ , especially when you're using skilled professional craftsmen. 21 hours ago, Turboguard said: I will try more and see what my median for 60fps is. edit: you’re right, the second I took it outside and shot in sunlight, it stops under 10sec. So with T5 you can at least do 30fps 4K DCI without having to worry. Trying panning the camera back and forth on a long lens, in front of leafy trees on a windy day. That could impact at what point the drive cuts out. Link to comment Share on other sites More sharing options...
Snuff Posted October 22, 2018 Share Posted October 22, 2018 The cinema5D Camera Lab is Back – Dynamic Range Tests • 22 Oct 2018 https://***URL not allowed***/the-cinema5d-camera-lab-is-back-dynamic-range-tests/ Alex Uzan and IronFilm 1 1 Link to comment Share on other sites More sharing options...
Alex Uzan Posted October 22, 2018 Share Posted October 22, 2018 I’d never thought the GH5 would be so low. Link to comment Share on other sites More sharing options...
grex Posted October 22, 2018 Share Posted October 22, 2018 Would be interesting to see the pocket 4K in here since someone on this thread claims the OG pocket has better dynamic range. I forget who it was. deezid 1 Link to comment Share on other sites More sharing options...
Anaconda_ Posted October 22, 2018 Share Posted October 22, 2018 @mercer Has anyone given you the 1080p tests you were looking for a while ago? If all goes to plan, my camera arrives tomorrow, so I'll happily share some OG files. RAW, ProRes, Film, Video, Extended, 24/25/30/50/60/120 you name it. I'm also going to take it for a walk on Wednesday (hopefully) so will share a bunch of footage and audio samples then too. If anyone else would like something specific - apart from water testing - let me know and I'll do my best. Vision 1 Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted October 22, 2018 Share Posted October 22, 2018 2 hours ago, Snuff said: The cinema5D Camera Lab is Back – Dynamic Range Tests • 22 Oct 2018 https://***URL not allowed***/the-cinema5d-camera-lab-is-back-dynamic-range-tests/ I am confused as heck. XT2 higher dynamic range then XT3?? TurboRat 1 Link to comment Share on other sites More sharing options...
BenEricson Posted October 22, 2018 Share Posted October 22, 2018 7 hours ago, Snuff said: Blackmagic pocket cinema camera 4k test (lowlight) with Panasonic 12-35 f.2.8 first gen (4K DCI Raw Lossless iso 1250 f2.8) shot with only one photography guide light + soft box Looks really nice, but when you bring the levels back up, you start to see those highlights that I keep seeing in the P4K footage. If you add a bit of a shoulder, you lose detail but it smooths out the highlights. You probably lose a stop of DR as well. I'm not a colorist, but the c300ii I use often looks closer to the version with the curve, right out of the camera. I find the OG pocket to similar in that regard. The highlights have a lot of roll off. Link to comment Share on other sites More sharing options...
sanveer Posted October 22, 2018 Share Posted October 22, 2018 1 hour ago, thebrothersthre3 said: I am confused as heck. XT2 higher dynamic range then XT3?? If you compare their dynamic range testing over the last few years of the Same camera, you'll probably lose your sanity. Apart from contradicting everyone else, they contradict themselves too, many times over. And I don't think it's their fault TBO. It may have to do with the voltage and some kind of bulb or tube issued with their equipment. ??? elgabogomez and IronFilm 2 Link to comment Share on other sites More sharing options...
deezid Posted October 22, 2018 Share Posted October 22, 2018 3 hours ago, grex said: Would be interesting to see the pocket 4K in here since someone on this thread claims the OG pocket has better dynamic range. I forget who it was. It's me. And yes, would love to see that, A73 in HLG is missing as well. The chart seems quite accurate to me, the FS7 is definitely quite impressive in terms of dynamic range, I just don't like what the processing does to its image. RAW is amazing though. 8 hours ago, Snuff said: Blackmagic pocket cinema camera 4k test (lowlight) with Panasonic 12-35 f.2.8 first gen (4K DCI Raw Lossless iso 1250 f2.8) shot with only one photography guide light + soft box Wow, looks great. Seems like Pocket 4K footage shows way more low contrast texture than the X-T3 does which looks flat in many cases. Link to comment Share on other sites More sharing options...
helium Posted October 22, 2018 Share Posted October 22, 2018 1 hour ago, BenEricson said: Looks really nice, but when you bring the levels back up, you start to see those highlights that I keep seeing in the P4K footage. If you add a bit of a shoulder, you lose detail but it smooths out the highlights. You probably lose a stop of DR as well. I'm not a colorist, but the c300ii I use often looks closer to the version with the curve, right out of the camera. I find the OG pocket to similar in that regard. The highlights have a lot of roll off. This thread is aggravating enough to revive the dead.... You do realize you're grading a grade, not camera original? There's no way to know how much original highlight detail was in the shots, because current levels are baked in. It's like trying to grade a bluray and concluding that 35mm stinks, because you can't push the highlights without clipping. BenEricson 1 Link to comment Share on other sites More sharing options...
BenEricson Posted October 22, 2018 Share Posted October 22, 2018 41 minutes ago, helium said: This thread is aggravating enough to revive the dead.... You do realize you're grading a grade, not camera original? There's no way to know how much original highlight detail was in the shots, because current levels are baked in. It's like trying to grade a bluray and concluding that 35mm stinks, because you can't push the highlights without clipping. It's a 10mb 4k png still... Yes, I think a lot can be revealed about the image when raising the gamma slightly. The file is basically flat anyway... Link to comment Share on other sites More sharing options...
Jim Giberti Posted October 23, 2018 Share Posted October 23, 2018 I've been impressed at how much I've been able to lift the blacks and mids with no noise on a number of challenging scenes. One shoot was brilliant bright fall light streaming through an autumn canopy for an all day mountain bike segment. The light and contrast changed constantly with no time to adjust even with a couple of grips with bounces. Bottom line, I don't even think about ETTR with this. It's a totally different image/negative. Very clean very gradeable - and all we've shot so far is in ProRes HQ UHD. Chrad and BenEricson 2 Link to comment Share on other sites More sharing options...
IronFilm Posted October 23, 2018 Share Posted October 23, 2018 7 hours ago, Snuff said: The cinema5D Camera Lab is Back – Dynamic Range Tests • 22 Oct 2018 https://***URL not allowed***/the-cinema5d-camera-lab-is-back-dynamic-range-tests/ Cinema5D has been so far off the mark in the past, why should we start to believe them now? sanveer 1 Link to comment Share on other sites More sharing options...
webrunner5 Posted October 23, 2018 Share Posted October 23, 2018 25 minutes ago, IronFilm said: Cinema5D has been so far off the mark in the past, why should we start to believe them now? Looks kind of realistic to me for what they have tested. But I would need to see more cameras to be convinced. The Arri sounds about right in a real life situation. Most cameras are overrated, so no surprise. Sure Cinema5D may seem crazy. So does DXO at times. But the one thing they have going for them is they use the same test on Every camera they test. So are they real values? Maybe not. But they do show who is better and worse on their tests. Right or wrong they are all subjected to the same standards. So it will prove the best camera and the worse camera no matter the truthful outcome on DR stats. They are both controlled tests. So I can believe who is on top and who is not. And I don't think anyone on here can be surprised by the outcomes. Better Codecs, better Data rates, better Bit depths are going to be on top, old or new. Link to comment Share on other sites More sharing options...
sanveer Posted October 23, 2018 Share Posted October 23, 2018 12 minutes ago, webrunner5 said: Looks kind of realistic to me for what they have tested. But I would need to see more cameras to be convinced. The Arri sounds about right in a real life situation. Most cameras are overrated, so no surprise. Sure Cinema5D may seem crazy. So does DXO at times. It's beyond blasphemous comparing DXO Labs with Cinama5D. Cinema5D for the SAME CAMERA will show 3 different rantings in dynamic range, given enough time. I had even posted proof of this in one of the discussion threads. Link to comment Share on other sites More sharing options...
webrunner5 Posted October 23, 2018 Share Posted October 23, 2018 6 minutes ago, sanveer said: It's beyond blasphemous comparing DXO Labs with Cinama5D. Cinema5D for the SAME CAMERA will show 3 different rantings in dynamic range, given enough time. I had even posted proof of this in one of the discussion threads. I will admit Cinama5D is all over the place, but their DR rating to me are more realistic than most. DXO is all about Photos. Cinema5D is all about Video. Photo DR is always easily 1 1/2 stops to 2 stops higher than video DR because of Bit Depth. And yeah they have changed the way they test now from years ago. So it is not going to seem the same. They bought some really good, expensive as hell equipment to test it with now. Link to comment Share on other sites More sharing options...
sanveer Posted October 23, 2018 Share Posted October 23, 2018 24 minutes ago, webrunner5 said: I will admit Cinama5D is all over the place, but their DR rating to me are more realistic than most. DXO is all about Photos. Cinema5D is all about Video. Photo DR is always easily 1 1/2 stops to 2 stops higher than video DR because of Bit Depth. And yeah they have changed the way they test now from years ago. So it is not going to seem the same. They bought some really good, expensive as hell equipment to test it with now. I hope there is some consistency with their testing even if they are wrong. To give credit where it's due, I actually check their rating and comments regarding dynamic range whenever I am down. It makes me laugh till my eyes water. Hopefully they don't stop that. They're probably doing all sorts of public service. Link to comment Share on other sites More sharing options...
