xzobinx Posted March 21, 2019 Share Posted March 21, 2019 1 hour ago, drm said: @xzobinx I am sure that you know this already but, the 12V port on the camera is designed to take 12V-20V. The battery outputs 8.4V-6V. I am surprised that the camera even turns on with only 8V plugged into the 12V port. I suggest that you get a 12V output battery sled like this one: https://amzn.to/2Fp0I4u I have 3 and they work fine for me. I also use dtap straight from a v-mount battery to the 12V port and it works great. The camera lasts basically all day with one big v-mount battery. If you run a cord straight from the battery, I recommend that you use a dummy battery. The camera is designed to use lower voltages from the battery port. If you use a dummy battery, you will also lose the ability to hot swap your battery during a long shoot. I have 15-20 of those batteries and they work great. I have had only had one of them die over the past 2 or three years of regular use. I have the batteries numbered, but I don't keep track of when I buy them, so I have no idea how long the batteries lasted before dying. IIRC, I think that Tom Antos mentioned killing some of his monitors that provide power to the camera because of the heavy power draw from the BMPCC4K, so I would hesitate trying to draw power from the monitor. Unfortunately, I can't recommend a store that will ship those to Australia. thanks for the head up. I'm aware of your concerns -the 8v should be able to run the camera but not be able to turn it on. So it requires a battery inside the camera at all time. This is similar to using a Sony NP power sled without step up transformer built in. I do have a sony NP power sled and other battery option like the batbox 4k but I'm looking for a smaller setup with a monitor. -Tom Antos did fired a couple of his monitors. However, he power it through the 8v dc out of the monitor. My plan is actually power form the dc out of the battery. -They used to have an older version of the battery with 12v dc out which would be perfect. Unfortunately they "upgrade" it Link to comment Share on other sites More sharing options...
Emanuel Posted March 21, 2019 Share Posted March 21, 2019 Please post here -- there is a open thread for that: https://www.eoshd.com/comments/topic/28146-blackmagic-pocket-4k-media-power-thread-the-best-alternatives/ Link to comment Share on other sites More sharing options...
Newway12 Posted March 22, 2019 Share Posted March 22, 2019 I was using my sigma 18-35 on it to day but for some reason I got a blank white screen. Any suggestions? Link to comment Share on other sites More sharing options...
kye Posted March 22, 2019 Share Posted March 22, 2019 On 3/21/2019 at 3:47 AM, MeanRevert said: Can anyone recommend a good LUT pack out there? I agree with @JordanWright to start with the ones included in Resolve. Specifically the Film Look LUTs. Or design your own in Resolve - Juan Melara consistently shows that it's capable of enormously sophisticated adjustments: Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted March 22, 2019 Share Posted March 22, 2019 Wish they had a Lut for those working in other programs like Premiere. Link to comment Share on other sites More sharing options...
mercer Posted March 22, 2019 Share Posted March 22, 2019 20 minutes ago, thebrothersthre3 said: Wish they had a Lut for those working in other programs like Premiere. Do a search for “Captain Hook LUTS” and you should find something that will work in Premiere. thebrothersthre3 1 Link to comment Share on other sites More sharing options...
Anaconda_ Posted March 22, 2019 Share Posted March 22, 2019 27 minutes ago, thebrothersthre3 said: Wish they had a Lut for those working in other programs like Premiere. Open the Resolve settings go to 'Color Management' - scroll down a little to Lookup Tables and then click 'Open LUT Folder'. Then you can copy whatever LUT you want and copy it to Premiere's LUT folder and away you go. thebrothersthre3 1 Link to comment Share on other sites More sharing options...
Anaconda_ Posted March 22, 2019 Share Posted March 22, 2019 On 3/20/2019 at 11:02 AM, CaptainHook said: Resolve 15.3 has a build of SDK 1.3 which does support LUTs in the sidecar, they just need to be manually placed in the sidecar at this time (we would like to add the ability to add LUTs to the sidecar through the Resolve UI in a future update). That's good to know, but for now it's forcing me to forgo LUTs all together, and only use them for monitoring on location. In the long run, this can only be a good thing for me personally. That said, LUTs built into the sidecar will undoubtedly be beneficial. On the subject, do you know if the Raw Player will one day have the ability to toggle the sidecar, so we don't need to close the application, move the sidecar and then reopen? Link to comment Share on other sites More sharing options...
drm Posted March 22, 2019 Share Posted March 22, 2019 YAY! Metabones just announced support for the BMPCC4K! https://www.metabones.com/article/of/EF-M43_Firmware_Mac I tested the new firmware on my 0.71 EF adapter and AF does now work with my Sigma 18-35. Note that the AF does seem to be slower than with a native lens, but at least you have the option of using it now! Link to comment Share on other sites More sharing options...
Kisaha Posted March 22, 2019 Share Posted March 22, 2019 "Autofocus is enabled for Blackmagic Pocket Cinema Camera 4K but performance may not meet expectation." I guess its better than nothing. Link to comment Share on other sites More sharing options...
drm Posted March 22, 2019 Share Posted March 22, 2019 34 minutes ago, Kisaha said: "Autofocus is enabled for Blackmagic Pocket Cinema Camera 4K but performance may not meet expectation." I guess its better than nothing. LOL...I am surprised that they put that but, yes. The AF *isn't* great. But at least it does work. There is no continuous AF, but the touch to focus does work. AF didn't work at all before, so I will take it. I estimate that the AF is about 1/2 the speed with a Metabones lens as it is with a native lens. But, again, it works By the way, here are the links to the Windows & Mac versions of the firmware to enable AF on the Metabones adapters for anyone who wants it: WIN: https://www.metabones.com/article/of/EF-M43_Firmware_Win MAC: https://www.metabones.com/article/of/EF-M43_Firmware_Mac Link to comment Share on other sites More sharing options...
Emanuel Posted March 22, 2019 Share Posted March 22, 2019 Yes, it works : ) That huge monitor coupled to their tiptop focus assist is so efficient, I doubt you'll want to touch the screen to acquire focus... ; -) Link to comment Share on other sites More sharing options...
drm Posted March 22, 2019 Share Posted March 22, 2019 19 minutes ago, Emanuel said: Yes, it works : ) That huge monitor coupled to their tiptop focus assist is so efficient, I doubt you'll want to touch the screen to acquire focus... ; -) A few days ago, I had my cams up high, with my tripods fully extended, shooting over a crowd at people on a stage. Manually focusing was very difficult, as I was well below the screen on the back of the camera. Touch focus, came in really handy in that situation. I used it several times during that shoot. I could have used the app to focus with my phone, but I had several cameras running and didn't want to keep switching between each camera in the app. Having multiple ways to focus is a great feature. I would love to have an external touch monitor, like my SmallHD, that I could use to interact with the camera. Alternatively, I would like to have a way to easily switch between cameras in an app. I almost always run a 3 cam set. Link to comment Share on other sites More sharing options...
MeanRevert Posted March 22, 2019 Share Posted March 22, 2019 Any of you guys running into problems with really low volume on the mic port? Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted March 22, 2019 Share Posted March 22, 2019 6 hours ago, Anaconda_ said: Open the Resolve settings go to 'Color Management' - scroll down a little to Lookup Tables and then click 'Open LUT Folder'. Then you can copy whatever LUT you want and copy it to Premiere's LUT folder and away you go. Perfect! Link to comment Share on other sites More sharing options...
Emanuel Posted March 22, 2019 Share Posted March 22, 2019 Sure, horses for courses : -) 5 minutes ago, drm said: A few days ago, I had my cams up high, with my tripods fully extended, shooting over a crowd at people on a stage. Manually focusing was very difficult, as I was well below the screen on the back of the camera. Touch focus, came in really handy in that situation. I used it several times during that shoot. I could have used the app to focus with my phone, but I had several cameras running and didn't want to keep switching between each camera in the app. Having multiple ways to focus is a great feature. I would love to have an external touch monitor, like my SmallHD, that I could use to interact with the camera. Alternatively, I would like to have a way to easily switch between cameras in an app. I almost always run a 3 cam set. Link to comment Share on other sites More sharing options...
Anaconda_ Posted March 22, 2019 Share Posted March 22, 2019 6 minutes ago, MeanRevert said: Any of you guys running into problems with really low volume on the mic port? Yes, you need to use a self powered mic that has at least +10 or even better +20db on it. The Rode Videomic Pro and Pro+ have that, and a few others. Unfortunately, the VideoMicro requires plugin power, which this camera doesn't provide. You can record with it, but you'll get a very quiet signal, which you can boost / noramlize in post, but that will also bring up the noise floor. I've heard many people, Curtis Judd for example, aim to record at around -18db and then boost in post. So if your mic can get you around that level, according to that theory, it's fine. I would still find that quite limiting, as it's better to use a louder mic and turn the input down in camera. That way you can reduce the noise floor from the camera's preamp when you push it in post. Alternatively, you could try running your mic into the XLR port, which is said to be 6 - 12 db louder than the 3.5mm jack. Link to comment Share on other sites More sharing options...
MeanRevert Posted March 22, 2019 Share Posted March 22, 2019 31 minutes ago, Anaconda_ said: Yes, you need to use a self powered mic that has at least +10 or even better +20db on it. The Rode Videomic Pro and Pro+ have that, and a few others. Unfortunately, the VideoMicro requires plugin power, which this camera doesn't provide. You can record with it, but you'll get a very quiet signal, which you can boost / noramlize in post, but that will also bring up the noise floor. I've heard many people, Curtis Judd for example, aim to record at around -18db and then boost in post. So if your mic can get you around that level, according to that theory, it's fine. I would still find that quite limiting, as it's better to use a louder mic and turn the input down in camera. That way you can reduce the noise floor from the camera's preamp when you push it in post. Alternatively, you could try running your mic into the XLR port, which is said to be 6 - 12 db louder than the 3.5mm jack. Ok great, I'll see if I can get a 3.5mm to XLR converter for my Rode then. Thank you. Link to comment Share on other sites More sharing options...
AlexTrinder96 Posted March 22, 2019 Share Posted March 22, 2019 Looks like Metabones will be releasing new speedboosters, specifically for the pocket 4k. There will be new Pocket 4k Speed Boosters® with new optics specifically optimized for the unique characteristics of the new Blackmagic Pocket Cinema Camera 4K. We will disclose details in a separate announcement. Each Speed Booster® is designed specifically for the filter stack of the sensor. The existing Speed Booster® XL 0.64x and Speed Booster® ULTRA 0.71x have excellent optical properties on JVC, Olympus and Panasonic cameras but the forthcoming Pocket 4K Speed Boosters will work only on Blackmagic cameras. Looks like they've gone back on what they originally said regarding specific adapters for the camera... https://www.metabones.com/article/of/BlackmagicPocketCinemaCamera_4K?fbclid=IwAR32Ck9ztExd8rXzKVwiRe0kaBuLSOY8sb9yIPHMY8D6hftGCWbgxQf26zY Link to comment Share on other sites More sharing options...
JordanWright Posted March 22, 2019 Share Posted March 22, 2019 it would have to be significantly better than the XL to justify a replacement Link to comment Share on other sites More sharing options...
