anonim Posted April 23, 2019 Share Posted April 23, 2019 13 minutes ago, Kisaha said: If I use an ND filter (which I am planning to do anyway) is there less IR, or it is completely irrelevant? If I have to use ND, do I have to put ond of those aforementioned filters before or after the ND? 1. I'm afraid there is more IR with ND filter. 2. I think it is irrelevant where to put IR filter. (If you in aesthetic choice chase for little bit of vintage look, IR pollution actually might be useful.) webrunner5 and Kisaha 1 1 Link to comment Share on other sites More sharing options...
Geoff CB Posted April 23, 2019 Share Posted April 23, 2019 On 4/22/2019 at 2:36 AM, seanzzxx said: Wait, you know you're not going to get the full dynamic range on rec.709 recordings, right? They were all recorded in Film mode and then converted to Rec. 709. Link to comment Share on other sites More sharing options...
MeanRevert Posted April 23, 2019 Share Posted April 23, 2019 6 hours ago, Kisaha said: If I use an ND filter (which I am planning to do anyway) is there less IR, or it is completely irrelevant? If I have to use ND, do I have to put ond of those aforementioned filters before or after the ND? IR is always there but when you put on an ND, it cuts light except it doesn't cut IR. So when you do that, IR is more easily seen by the sensor. I use the SLR image enhancer and put it in front of the ND. There's a post somewhere with John Brawley saying that the Pocket 4K has an IR Cut but it's slight as to not affect image quality. So BM is leaving it up to us to decide. Kisaha 1 Link to comment Share on other sites More sharing options...
mercer Posted April 23, 2019 Share Posted April 23, 2019 8 hours ago, Shirozina said: I tested ProRes vs CDNG when I first got my P4k last year and I could see no DR advantage to RAW. Infact unless you used NR in resolve the usable DR on RAW was less. Other differences between RAW and Pro Res exist and have been debated at length but both codecs get the the full DR from the sensor. I think the 12bit color depth gives the perception of more DR. Take a shot of a tree in CDNG and ProRes HQ and the texture of the tree bark in Raw will look more realistic and defined due to the extra shades of color. I also notice it with it skin as well. That isn’t measurable DR but it definitely looks better to the eyes. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted April 23, 2019 Share Posted April 23, 2019 I haven't used the Pocket 4k only the OG pocket. With Highlight recovery in resolve it gets more dynamic range. mercer 1 Link to comment Share on other sites More sharing options...
Mustyblowfish Posted April 23, 2019 Share Posted April 23, 2019 Hi Guys. Thinking of getting the P4K but only have EF glass. Obviously the new metabones seems like a safe bet but don’t really want to spend that much right now on an adapter. Are there any decent non glass adapters? Any feedback greatly appreciated! Link to comment Share on other sites More sharing options...
Shirozina Posted April 24, 2019 Share Posted April 24, 2019 10 hours ago, thebrothersthre3 said: I haven't used the Pocket 4k only the OG pocket. With Highlight recovery in resolve it gets more dynamic range. Can you post some side by side examples as this has not been my experience unless the Resolve has misinterpreted ProRes as Video range and clipped the highlights. 12 hours ago, mercer said: I think the 12bit color depth gives the perception of more DR. Take a shot of a tree in CDNG and ProRes HQ and the texture of the tree bark in Raw will look more realistic and defined due to the extra shades of color. I also notice it with it skin as well. That isn’t measurable DR but it definitely looks better to the eyes. Can you post some side by side examples of this as I've not seen it in my tests. Link to comment Share on other sites More sharing options...
anonim Posted April 24, 2019 Share Posted April 24, 2019 1 hour ago, Shirozina said: Can you post some side by side examples as this has not been my experience unless the Resolve has misinterpreted ProRes as Video range and clipped the highlights. Just to note or remind: in case of additional (and crucial) highlithts recovery possibility (that thebrothersthre3 mentioned in post) there's no need for examples: with RAW you can do it on rec.709 timeline, with ProRes you can't. As simple scenario, shot same scene with both, intentionally making clipped highlights. With ProRes you can't bring them back. With CDNG do such settings in Resolve CameraRaw menu Decode Using: Clip WB: As Shot Color Space: Rec.709 Gamma: Gamma 2.4 ... and picks of highlights are coming back from void (and such view has metaphysical impact on me), so you can further mold distribution of DR as you wish. Link to comment Share on other sites More sharing options...
Shirozina Posted April 24, 2019 Share Posted April 24, 2019 4 hours ago, anonim said: Just to note or remind: in case of additional (and crucial) highlithts recovery possibility (that thebrothersthre3 mentioned in post) there's no need for examples: with RAW you can do it on rec.709 timeline, with ProRes you can't. As simple scenario, shot same scene with both, intentionally making clipped highlights. With ProRes you can't bring them back. With CDNG do such settings in Resolve CameraRaw menu Decode Using: Clip WB: As Shot Color Space: Rec.709 Gamma: Gamma 2.4 ... and picks of highlights are coming back from void (and such view has metaphysical impact on me), so you can further mold distribution of DR as you wish. You are saying that if there is clipping at the sensor level with RAW then you can fix this in Resolve? This would be highly worthy of posted examples. Link to comment Share on other sites More sharing options...
leslie Posted April 24, 2019 Share Posted April 24, 2019 21 hours ago, MeanRevert said: IR is always there but when you put on an ND, it cuts light except it doesn't cut IR. So when you do that, IR is more easily seen by the sensor. I use the SLR image enhancer and put it in front of the ND. There's a post somewhere with John Brawley saying that the Pocket 4K has an IR Cut but it's slight as to not affect image quality. So BM is leaving it up to us to decide. i might investigate this. i have a couple of inferred filters, a 680 and 720 nm from memory and one ir modified digital still camera. i should be able to fit something to the front of the bmp4k and see how responsive the camera is to inferred. its already a given that it would have an ir filter as pretty much all cameras have ir cut because, well infered red looks odd or weird even peculiar in photos. not that i have anything against inferred. i think the issue is our eyes aren't accustomed to seeing inferred and when we do it tends to stand out. if its a sunny day i'll try to get some footage with and with out filters then you can judge for yourselves Link to comment Share on other sites More sharing options...
kye Posted April 24, 2019 Share Posted April 24, 2019 1 hour ago, Shirozina said: You are saying that if there is clipping at the sensor level with RAW then you can fix this in Resolve? This would be highly worthy of posted examples. I believe that what is being referred to is "super whites" where the output signal is above the white point by default, but can be brought back as the data is in the file. The XC10 does this. I suspect that if you're recording in prores then the conversion that happens may clip those super whites and they wouldn't be recoverable. I could be wrong, but I've seen super whites myself, and this clipping behaviour is very similar to the way that still images are processed with RAW / JPG files. Link to comment Share on other sites More sharing options...
mercer Posted April 24, 2019 Share Posted April 24, 2019 @Shirozina okay let’s backtrack a bit... your footage is noisy? Why? I thought the P4K sensor was supposed to be pretty clean? In fact, there are only two reasons why it would be noisy... 1. You’re underexposing it. Are you using ETTR? 2. You’re not shooting at base iso. As far as DR between raw and ProRes... I think I may have some side by side examples from some old Micro or Pocket footage... I’ll have to check my drives. Although, I would think the extra bit depth with Raw would make the idea of “perceived DR” pretty simple to understand. As far as Highlight Recovery I’m Resolve... have you ever used the Raw Panel? Bring in Raw footage that ETTR’d and you should see it completely overexposed with the Rec709 default... change it to BM Film and your waveform will drop but in many instances the highs will still be flat (slightly clipped) click Highlight Recovery and you get the top end back... it’s one of the best features in the Raw Panel. Link to comment Share on other sites More sharing options...
webrunner5 Posted April 24, 2019 Share Posted April 24, 2019 https://blackmagiccameraclub.wordpress.com/2015/01/25/prores-lt-vs-prores-hq-vs-raw-on-the-black-magic-pocket/ Link to comment Share on other sites More sharing options...
StHubbins Posted April 24, 2019 Share Posted April 24, 2019 4 hours ago, Shirozina said: You are saying that if there is clipping at the sensor level with RAW then you can fix this in Resolve? This would be highly worthy of posted examples. Yes... and no. What the "Highlight Recovery" setting does with RAW is find areas where one channel (say, red) is clipped, but another (say, blue) is NOT clipped. Resolve then fills that red channel with information from the blue channel. In ProRes, this info would just be "clipped", and come out as white. But in RAW with Highlight Recovery, that detail appears... but with a caveat. That detail is basically black and white. Because the actual red color info is gone, the best Resolve can do is kind of guess the color, and it defaults to desaturating (it used to make that detail pink, which was pretty ugly). So usually what this means is, instead of a window being blown-out flat white in ProRes, in RAW, you can barely see the frame of the window panels. It's not gorgeous, but it is kind of nice. More importantly, in a hot spot on someone's skin, RAW can bring back a bit of (desaturated) texture in the skin, which CAN be kind of a big deal. It's up to you whether these subtle differences in the extreme highlights are worth the trouble or not. Geoff CB 1 Link to comment Share on other sites More sharing options...
Shirozina Posted April 24, 2019 Share Posted April 24, 2019 3 hours ago, mercer said: As far as Highlight Recovery I’m Resolve... have you ever used the Raw Panel? Bring in Raw footage that ETTR’d and you should see it completely overexposed with the Rec709 default... change it to BM Film and your waveform will drop but in many instances the highs will still be flat (slightly clipped) click Highlight Recovery and you get the top end back... it’s one of the best features in the Raw Panel. Well if you use REC709 then yes you may have clipped highlights but who has this setting if you are shooting RAW?. Again I've not seen any hidden DR above clipping in RAW. Highlight recovery is a bodge to clean up highlights when one channel has clipped. Link to comment Share on other sites More sharing options...
anonim Posted April 24, 2019 Share Posted April 24, 2019 6 hours ago, webrunner5 said: https://blackmagiccameraclub.wordpress.com/2015/01/25/prores-lt-vs-prores-hq-vs-raw-on-the-black-magic-pocket/ Thanks, test confirm me my one experience: difference is pretty obvious even in exposing just one snapshot. RAW has noticeable better 3d definition, more details in the ground, more DR in left part of the clouds which seems to keep same form and position through shots. Watching footage flow without web compression makes difference even more pronounce. Prores HQ might be sufficient for somebody, not enough sufficient for someone else. For me, personally, having possibility of RAW shooting is exclusive quality and reason why to choose BM cameras instead others with better ergo, IBIS etc. Link to comment Share on other sites More sharing options...
mercer Posted April 24, 2019 Share Posted April 24, 2019 3 hours ago, Shirozina said: Well if you use REC709 then yes you may have clipped highlights but who has this setting if you are shooting RAW?. Again I've not seen any hidden DR above clipping in RAW. Highlight recovery is a bodge to clean up highlights when one channel has clipped. Re-read my comment you quoted... I didn’t say to use Rec709... Rec709 is the default in the Raw Panel... or maybe it’s SRGB... either way, I was trying to explain how Highlight Recovery can give you a little more dynamic range in Raw than you would have in ProRes. This function is particularly useful if you have a light in your frame... especially the sun. Link to comment Share on other sites More sharing options...
jack86 Posted April 24, 2019 Share Posted April 24, 2019 My pocket has finally returned from assistance (pixel burned on the monitor). My first test .. Every criticism on the color is welcome (I'm studying).. The lasts shots are too dark and noisy.. Sorry PW: ISOLA BRAW 12 downconverted to HD Metabones xl 0.64 Tamron 24-70 2.8 ef Canon ef 100 2.8 macro usm Canon 70-300 4-5.6 Erthal, Papiskokuji, webrunner5 and 1 other 4 Link to comment Share on other sites More sharing options...
mercer Posted April 24, 2019 Share Posted April 24, 2019 24 minutes ago, jack86 said: My pocket has finally returned from assistance (pixel burned on the monitor). My first test .. Every criticism on the color is welcome (I'm studying) PW: ISOLA Nice job, I liked the color a lot. If this is you studying, I look forward to what you do when you graduate! What lens(es) did you use? webrunner5 1 Link to comment Share on other sites More sharing options...
jack86 Posted April 24, 2019 Share Posted April 24, 2019 Thank you mercer! Metabones xl 0.64 Tamron 24-70 2.8 ef Canon ef 100 2.8 macro usm Canon 70-300 4-5.6 Link to comment Share on other sites More sharing options...
