IronFilm Posted April 24, 2018 Share Posted April 24, 2018 Exactly as the subject says, how do I mute the left channel during playback, is this even possible with the GH5? If so it would be a life saver for ease of use with a Tentacle. Link to comment Share on other sites More sharing options...
Orangenz Posted April 24, 2018 Share Posted April 24, 2018 Playback via ...? Headphone socket? jonpais 1 Link to comment Share on other sites More sharing options...
IronFilm Posted April 24, 2018 Author Share Posted April 24, 2018 Via the built in speakers. Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted April 24, 2018 Super Members Share Posted April 24, 2018 Oh, the internal speakers... [EDIT] Erases link to 3.5mm stereo to 2 mono jacks cable and inline attenuator. [EDIT] Though come to think of it you could fake it by using that cable to come out of the headphone socket (which I presume mutes the internal speakers) and then attach the right split to a tiny speaker. Orangenz 1 Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted April 24, 2018 Super Members Share Posted April 24, 2018 A pair of the flat type over ear headphones with enough grunt could do the trick as well where you just cut the left one off with a pair scissors. We could market it as the Van Gogh solution. Orangenz and IronFilm 1 1 Link to comment Share on other sites More sharing options...
IronFilm Posted April 24, 2018 Author Share Posted April 24, 2018 On 4/24/2018 at 8:21 AM, BTM_Pix said: Though come to think of it you could fake it by using that cable to come out of the headphone socket (which I presume mutes the internal speakers) and then attach the right split to a tiny speaker. Expand I'm afraid this might be my only solution :-( :-/ Orangenz 1 Link to comment Share on other sites More sharing options...
docmoore Posted April 26, 2018 Share Posted April 26, 2018 Please tell us how the Tentacle is being used ... if you are syncing TC ... the the audio of the GH5 should be TC only ... and your external recorder will fill the gap. On the Canon 5D Mk IV and a Nanolockit I manually adjust levels for the NL input ... then in post sync the TC for the audio. Perhaps I do not understand what you wish to accomplish. Bob Link to comment Share on other sites More sharing options...
docmoore Posted April 26, 2018 Share Posted April 26, 2018 Forget the post above. Checking footage in camera you could probably use a set of earbuds ... just insert the right one ... yes TC audio sounds awful. I wonder if the internal mic Is off when external mic is plugged in .... does the tentacle scratch mic record to right channel? Link to comment Share on other sites More sharing options...
kye Posted April 27, 2018 Share Posted April 27, 2018 Does the GH5 have physically separated speakers? If so, would sticky tape provide enough attenuation? Link to comment Share on other sites More sharing options...
IronFilm Posted April 27, 2018 Author Share Posted April 27, 2018 On 4/26/2018 at 12:13 AM, docmoore said: Please tell us how the Tentacle is being used ... if you are syncing TC ... the the audio of the GH5 should be TC only ... and your external recorder will fill the gap. Expand Just to be clear for any one else reading: this is not for post, but for playback of people viewing the monitor on set. On 4/26/2018 at 1:19 PM, docmoore said: Checking footage in camera you could probably use a set of earbuds ... just insert the right one ... yes TC audio sounds awful. Expand Should have made it clearer: this needs to be quickly and easily usable for when more than one person is reviewing, earbuds are out! (although yes, this is the approach we took with the GH5 on a feature film last year) On 4/26/2018 at 1:19 PM, docmoore said: I wonder if the internal mic Is off when external mic is plugged in .... does the tentacle scratch mic record to right channel? Expand Bingo, this is exactly what happens. On 4/27/2018 at 12:11 AM, kye said: Does the GH5 have physically separated speakers? Expand Worth checking out if it is possible. On 4/27/2018 at 12:11 AM, kye said: If so, would sticky tape provide enough attenuation? Expand However I'm doubtful, as it is pretty loud and obnoxious! Link to comment Share on other sites More sharing options...
kye Posted April 27, 2018 Share Posted April 27, 2018 On 4/27/2018 at 10:57 AM, IronFilm said: Worth checking out if it is possible. However I'm doubtful, as it is pretty loud and obnoxious! Expand I've noticed that the speaker on my iPhone can be muted almost completely if you can get a complete seal over the speaker, so maybe. If it has separated speakers then maybe try a few layers of gaffer tape and see if it's enough. As you say, it may not be! Link to comment Share on other sites More sharing options...
docmoore Posted April 27, 2018 Share Posted April 27, 2018 Wonder if a 1/8 TRS to stereo RCA cable ... powered monitor speaker ... just plug the R RCA ... Of concern is presence of cross-talk from the L channel if it overpowers the internal amps Link to comment Share on other sites More sharing options...
