Gregormannschaft Posted April 27, 2018 Share Posted April 27, 2018 Need a bit of assistance from anyone who's used CC in Premiere at all. I've almost completed a 15min doc, and I've perhaps stupidly decided to make the closed captions within Premiere - I wanted to do both closed and open captions. Only problem is now I want to move a section from the end to the middle, but changing the timing of the captions is a nightmare. I can cut the captions bar and move it around, which works when previewing, but the timing of the captions remains the same so it will be broken when feeding the srt file into Vimeo or Youtube. Is there a solution I'm missing, or is it really this cumbersome? Link to comment Share on other sites More sharing options...
gethin Posted April 30, 2018 Share Posted April 30, 2018 Sorry cant help with premiere, but I know that when I looked into it, it did my head in and this: https://www.rev.com seemed like a total no-brainer. If you send them a transcript, you should get 100% accuracy. Gregormannschaft 1 Link to comment Share on other sites More sharing options...
