Vladimir Posted May 5, 2018 Share Posted May 5, 2018 Since i dont want yet dive into DIY solution. Any thoughts on this scheme? CP-W126 (http://www.fujifilm.com/products/digital_cameras/accessories/batteries/index.html#coupler) + qualcomm 3.0 power bank through usb-dc adapter. There's also posibility to use any 5V powerbank and usb-dc 5Vto9V converter but qualcomm 3.0 seems like better solution ( thats a technology that lets chargeable device decide itself how many A/V it needed) Link to comment Share on other sites More sharing options...
Kisaha Posted May 5, 2018 Share Posted May 5, 2018 General comment: The fast charging ability of the Qualcomm depends if the device is fast charging 3.0 (or 2.0). My phone\power bank/laptop/monitor has 3.0 and is a great feature, all the devices should have Quickcharge 3.0 or 4.0, a lot more useful than slow wireless charging. Link to comment Share on other sites More sharing options...
tupp Posted May 5, 2018 Share Posted May 5, 2018 The batteries for the X-h1 are probably 7.2 volts, so it's best to supply your camera with that voltage. So, it might be good to consider using readily available and inexpensive, 7.2 volt Sony NP batteries (which come in various sizes/capacities). You can connect them to your CP-W126 cable with an NP battery plate. Here is a tutorial on powering a camera with these items. Link to comment Share on other sites More sharing options...
Vladimir Posted May 8, 2018 Author Share Posted May 8, 2018 On 05.05.2018 at 9:01 AM, tupp said: The batteries for the X-h1 are probably 7.2 volts, so it's best to supply your camera with that voltage. output of an original dc power supply is 9V 2A. maybe there is converter inside original dummy battery. tupp 1 Link to comment Share on other sites More sharing options...
tupp Posted May 9, 2018 Share Posted May 9, 2018 6 hours ago, Vladimir said: output of an original dc power supply is 9V 2A. Are you sure that DC power supply is made by Fuji? 6 hours ago, Vladimir said: maybe there is converter inside original dummy battery. Or maybe the camera just runs hot and noisy when powered by 9V. The voltage of the X-h1's internal battery is definitely 7.2V. I would avoid running any camera at a voltage higher than that of its internal battery. Link to comment Share on other sites More sharing options...
UncleBobsPhotography Posted May 9, 2018 Share Posted May 9, 2018 55 minutes ago, tupp said: The voltage of the X-h1's internal battery is definitely 7.2V. I would avoid running any camera at a voltage higher than that of its internal battery. It's not uncommon for a 2 cell 7.2V battery to have a voltage up to 8.4V when fully charged, so 9V is probably within the tolerance limit of the camera. On the other hand, it's not a bad idea to be on the cautious side. To the OP: Unless the dummy battery or the adapter has a QC2.0/QC3.0 chip, I don't think it will be able to tell the powerbank that it needs 9V. As far as I know, both the supplier and the consumer needs QC if you want anything above 5V. tupp 1 Link to comment Share on other sites More sharing options...
thefirstdj Posted May 9, 2018 Share Posted May 9, 2018 With this diy method you can use any QC power bank to deliver 9v or 12v. Or just use this QC trigger: https://lygte-info.dk/review/USBmeter QC2-QC3 trigger UK.html UncleBobsPhotography and Vladimir 2 Link to comment Share on other sites More sharing options...
Vladimir Posted May 9, 2018 Author Share Posted May 9, 2018 4 hours ago, tupp said: Are you sure that DC power supply is made by Fuji? im sure - the store where im looking at dc power supply is on official fuji site. and as you can see CP-W126 itself have 9V marking. tupp 1 Link to comment Share on other sites More sharing options...
thefirstdj Posted May 9, 2018 Share Posted May 9, 2018 You can also use this type of power bank that has a DC out: https://www.amazon.co.uk/aceyoon-Power-Bank-20000-mAh/dp/B075LTVG1Y/ref=pd_sbs_107_4/257-5896293-4573361?_encoding=UTF8&psc=1&refRID=75NHPZ7VFH0RVBS8TB7D Link to comment Share on other sites More sharing options...
tupp Posted May 9, 2018 Share Posted May 9, 2018 5 hours ago, Vladimir said: as you can see CP-W126 itself have 9V marking I see it. 8 hours ago, UncleBobsPhotography said: It's not uncommon for a 2 cell 7.2V battery to have a voltage up to 8.4V when fully charged, so 9V is probably within the tolerance limit of the camera. On the other hand, it's not a bad idea to be on the cautious side. Yes, batteries' voltage is higher when fully charged. So, likewise, if you start with a fully charged 9V battery (as opposed to a 7.2V battery), you will probably see voltages higher than 9V -- significantly higher than the 8.4V peak of the fully charged internal battery. Again, it's a good idea to start with an external battery that has the same voltage as the unregulated internal battery. Thus, you know that you have enough voltage for the camera to properly function, while you will not be unduly increasing the camera's internal temperature (possibly causing extra noise). Link to comment Share on other sites More sharing options...
UncleBobsPhotography Posted May 9, 2018 Share Posted May 9, 2018 59 minutes ago, tupp said: Yes, batteries' voltage is higher when fully charged. So, likewise, if you start with a fully charged 9V battery (as opposed to a 7.2V battery), you will probably see voltages higher than 9V -- significantly higher than the 8.4V peak of the fully charged internal battery. But the 9V is delivered through QC, which can boosts the voltage to 9V regardless of whether the source battery is at 4.2V or 3V. It would have been different if we were talking about an actual 9V battery. tupp 1 Link to comment Share on other sites More sharing options...
tupp Posted May 10, 2018 Share Posted May 10, 2018 11 hours ago, UncleBobsPhotography said: But the 9V is delivered through QC, which can boosts the voltage to 9V regardless of whether the source battery is at 4.2V or 3V. It would have been different if we were talking about an actual 9V battery. The AC adapter delivers 9V. If there is no voltage regulator inside the "dummy" battery, then the camera is running off of a 9V supply. If the there is a voltage regulator in the dummy battery, then the camera is likely running off of ~7.2V. Either way, there is likely extra heat being generated inside the camera (compared to merely running off of a 7.2V internal battery), which could result in extra noise. Best to keep everything inside the camera at nominal voltage. Not familiar with "QC." Link to comment Share on other sites More sharing options...
Vladimir Posted May 31, 2018 Author Share Posted May 31, 2018 well its working. thanks @thefirstdj for mentioning qc 2.0 trigger. it be better to run 9V without relying on cheap chinesse chip (and if you go this way make sure to order atleast ~5 of them, i've buying it from local place and the one that workin as it should was not the first i've try), but now i can use a whole variety of affordable qc2.0 power banks. here is my 15600mah rig: last thing to do is to make weather sealing for qc trigger and to find a black zip ties) UPD forgot to mention i've tried 7.4v output (thx to qc3.0) and body recognised it as lowest battery level (using original battery adapter) Link to comment Share on other sites More sharing options...
Gaurav Singh Posted March 10, 2024 Share Posted March 10, 2024 On 5/5/2018 at 6:43 AM, Vladimir said: Since i dont want yet dive into DIY solution. Any thoughts on this scheme? CP-W126 (http://www.fujifilm.com/products/digital_cameras/accessories/batteries/index.html#coupler) + qualcomm 3.0 power bank through usb-dc adapter. There's also posibility to use any 5V powerbank and usb-dc 5Vto9V converter but qualcomm 3.0 seems like better solution ( thats a technology that lets chargeable device decide itself how many A/V it needed) Link to comment Share on other sites More sharing options...
