Administrators Andrew Reid Posted May 18, 2013 Administrators Share Posted May 18, 2013 This was a great week. It is the first time we've seen this kind of moving image from a full frame sized sensor in raw. A pristine 2K 14bit image that's like a 24fps digital film negative or a digital scan of Super 35mm. It's also a breakthrough for accessibility bringing raw video to many talents for the first time, when the only other accessible raw shooting cameras out there have been in extremely limited supply. [url=http://www.eoshd.com/content/10407/the-impact-of-5d-mark-iii-raw-and-what-does-vincent-laforet-think-of-it]Read the full article here[/url] earnesync 1 Link to comment Share on other sites More sharing options...
peederj Posted May 18, 2013 Share Posted May 18, 2013 Best use of a Blackmagic cage to date! JHines 1 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted May 18, 2013 Author Administrators Share Posted May 18, 2013 Haha. Well had to fill the empty space! That is the Wooden Camera Cage. ReWo cage is superb but obvious by design does not fit the 5D Mark III. I have their 5D Mark II cage, will try that. When the Blackmagic Cinema Camera MFT model does finally arrive, I'll keep it but I don't need the EF version any more now I have the 5D Mark III. Raw and image quality was the only reason I bought one. Link to comment Share on other sites More sharing options...
blackrat Posted May 18, 2013 Share Posted May 18, 2013 "Vincent: " – and can the body TRULY survive doing this over time (heat/damage?)"" 1. I bet it runs a trace cooler if anything. 2. Even if it did eventually do something (and I don't see how it would anymore than using Liveview a lot would) look at the price of it! JHines 1 Link to comment Share on other sites More sharing options...
Germy1979 Posted May 18, 2013 Share Posted May 18, 2013 None of those guys will embrace this. The only one I haven't heard from is Hurlbut and I'd imagine he'll be negative about it too... but secretly wishing this had happened around Act of Valor. It may be a hack, but these guys release versions so reliable they label them "Alpha".. and working professionals rely on them. I'm happy with my C100 - Ninja combo, but 2 months ago I had a Mark 3. These results are speaking for themselves. Link to comment Share on other sites More sharing options...
Larry Vaughn Posted May 18, 2013 Share Posted May 18, 2013 The people with the guarded response to the raw file developments with the EOS cameras likely get some compensation from equipment manufacturers that they won't get from free software for the EOS bodies. If you go to cinematography forums, you don't always hear and see so much talk about cameras, because there is so much more to filmmaking. The common equipment bloggers are not so well known in those forums and in many cases derided as receiving some compensation for their constant equipment promoting or just not really having the experience as long time cinematographers. A photo of someone standing next to a camera they don't even use was one example of this that was discussed. So is a lot of the equipment they tend to promote. This firmware is in its infant stage. Every day more improvements in workflow and programming happen. Truly an independent labor of love free from the commercialism that in many cases stifles true innovation. Canon would likely benefit by embracing this effort. I recently purchased 2 eos bodies and 4 lenses so I could benefit from the magic lantern firmware. It's not likely that I will ever buy a C500 or any other camera that will be worth about 1/2 of the retail cost 2 years from its original availability, magic lantern or not. However, if they ever manage to hack the C-300 in the same way I might consider buying a used one. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted May 18, 2013 Author Administrators Share Posted May 18, 2013 "Vincent: " – and can the body TRULY survive doing this over time (heat/damage?)"" The camera has a thermometer inside and Magic Lantern displays the temperature on the LCD with global draw. I haven't noticed any heat problems yet, and with people doing 12hr continuous card tests for raw, I think we can safely say the electronics can handle it. Raw takes less CPU power as it requires less processing. When copying a huge file from a USB drive, does your MacBook overheat? No. People don't understand the inner workings when they say damage will occur due to a software process. One of the most obvious attempts to protect vested interests was from Michael Sutton earlier this week on Twitter where he claimed to have 'insider NDA knowledge' from a Canon engineer that the raw recording would damage the sensor. Actually the sensor is constantly outputting raw when in live view mode with or without Magic Lantern. It is designed to do it, and to do so until the battery goes flat. Link to comment Share on other sites More sharing options...
Steve M. Posted May 18, 2013 Share Posted May 18, 2013 Who cares what Vincent Laforet thinks? What matters is what you think. May I ask, why do so many websites put Vincent Laforet on a pedestal? Why? Just curious, I'm not meaning for that to sound negative. Ernesto Mantaras, gibbygoo, simonfilm and 2 others 5 Link to comment Share on other sites More sharing options...
mattlundstrom Posted May 18, 2013 Share Posted May 18, 2013 "C Series and other cameras are what people should be focusing on" I'm shocked, SHOCKED, that a man sponsored by Canon who's main focus in the last 6 months has been to convince the public that the C series is where it's at would speak against the mother of all hacks that completely undercuts the value of the C series of cameras. Halycon, Germy1979, OzNimbus and 2 others 5 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted May 18, 2013 Author Administrators Share Posted May 18, 2013 I like the image so much that I have decided to adjust my strategy for the cameras I shoot with. Out goes the Sony FS100. That was my main low light tool but now the 5D Mark III with raw is that. Blackmagic EF mount version will also be sold. I have the Pocket Cinema Camera and 4K AND MFT versions pre-ordered!! I don't need all of them and can use my EF glass on the 5D. I am heavily invested in Micro Four Thirds glass so will likely keep the MFT Blackmagic for a while. 4K and global shutter will be interesting on the Production Camera. I need to clear out some of my other DSLRs. Nikon V2 don't need, got it for raw bursts! Amazing sensor technology, nice as a stills camera too (very good AF, very light, very compact, lots of other cool stuff) but now the Sony RX1 is by far my most compelling stills cam and it wasn't cheap. Nikon D5200 can go too. Nice bargain but it's no longer competitive with the image on the 5D Mark III. Canon don't deserve this, what a crazy situation. Julian and Ernesto Mantaras 2 Link to comment Share on other sites More sharing options...
gelly Posted May 18, 2013 Share Posted May 18, 2013 Huge respect for this site, but I have to say 'the blogger' section in this post left something of a sour taste. Surely there's room for both cautious and enthusiastic approaches to this development. We're all different after all. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted May 18, 2013 Author Administrators Share Posted May 18, 2013 Does it leave a sour taste because I am being sour, or does it leave a sour taste because I criticised someone you like? I suspect the latter. Really, it is time for a more open and honest debate on the merits of our DSLR community leaders I think. Ernesto Mantaras, Neumann Films, nahua and 2 others 5 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted May 18, 2013 Author Administrators Share Posted May 18, 2013 Surely there's room for both cautious and enthusiastic approaches to this development. We're all different after all. Absolutely. Never implied otherwise. For some, raw isn't suitable. Link to comment Share on other sites More sharing options...
kurth Posted May 18, 2013 Share Posted May 18, 2013 Andrew...what do you think of this....? http://www.youtube.com/watch?feature=player_embedded&v=SFBc7i1Q_0w#! ...looks like the ole gh2 ties the resolution of the raw 5d ! Link to comment Share on other sites More sharing options...
Neumann Films Posted May 18, 2013 Share Posted May 18, 2013 The truth hurts at times. I trust what my eyes see. I trust the test footage that has been uploaded by others. The images coming out of the Mark III make me giddy with each and every shot I capture. I too am selling my Epic and going to roll with the hacked Mark III and the Pocket Cinema Cam. Link to comment Share on other sites More sharing options...
thelebaron Posted May 18, 2013 Share Posted May 18, 2013 Ha, that Michael Sutton guy runs a site where the rental prices are exorbitantly high, at least in comparison to lensrentals. 150 a day for a bmcc vs 275 for 6 days :rolleyes: makes a little more sense why hes so keen to say magic lantern will melt your camera. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted May 18, 2013 Author Administrators Share Posted May 18, 2013 Ha, that Michael Sutton guy runs a site where the rental prices are exorbitantly high, at least in comparison to lensrentals. 150 a day for a bmcc vs 275 for 6 days :rolleyes: makes a little more sense why hes so keen to say magic lantern will melt your camera. It's funny because it's true. Link to comment Share on other sites More sharing options...
zephyrnoid Posted May 18, 2013 Share Posted May 18, 2013 Excellent summary and update. I do share Vince's skepticism with regard to heat damage over a long period of time. Heat & Dust are the arch enemies of Digital Video and we know that 4K processing in a small container is going to result in parts decay eventually. Then again, this update is really for the installed base. I wouldn't run out and buy this camera just for 4K ( knowing that in the horse race, first out the gate, only sets the pace). No doubt, Nikon ( last out the gate) and the others are looking closely. I'm still hopeful for that 4KRaw 10Bit in a smaller box but NOT a DSLR. Hell may freeze over before I get that wish fullfilled. Link to comment Share on other sites More sharing options...
kabuto1138 Posted May 18, 2013 Share Posted May 18, 2013 Thanks Andrew for such a great article. It felt almost way to personal. Had to post this, too funny not to http://www.youtube.com/watch?v=AOAsL9hA4Hg Link to comment Share on other sites More sharing options...
AaronChicago Posted May 18, 2013 Share Posted May 18, 2013 I'm still hopeful for that 4KRaw 10Bit in a smaller box but NOT a DSLR. Hell may freeze over before I get that wish fullfilled. Hopefully hell wont freeze over before July. Link to comment Share on other sites More sharing options...
