Arthur Woo Posted May 18, 2013 Share Posted May 18, 2013 I'm on OSX. Downloaded the May 17th build, which doesn't seem to be a .app file at all even after changing the extension to .app. 2gb files still crappin out. Help!!! Link to comment Share on other sites More sharing options...
Arthur Woo Posted May 18, 2013 Author Share Posted May 18, 2013 Okay, there's a temp fix for this. 2 Solutions: 1. If you have a pc you can use the raw2dng.exe there. It works for files over 2gb. 2. If you only have OSX, a workaround has been created. Not ideal, but read: http://www.magiclantern.fm/forum/index.php?topic=5404.msg36738#msg36738 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted May 18, 2013 Administrators Share Posted May 18, 2013 Sure it is not the space in path to file that is causing the problem not the 2GB file size? Link to comment Share on other sites More sharing options...
Arthur Woo Posted May 18, 2013 Author Share Posted May 18, 2013 Sure it is not the space in path to file that is causing the problem not the 2GB file size? Thanks for the reply...but not likely the issue. I've been able to convert everything below 2gb on OSX. Once it reaches that threshold it errors out. Other users have reported the same issue on the magic lanter forum - above are the only two solutions i know of until the ML team patches the application for OSX Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted May 18, 2013 Administrators Share Posted May 18, 2013 Yep does seem to be a bug. I am running Windows under VMWare for when I need it. Link to comment Share on other sites More sharing options...
