Help with resizing in premiere.
Turboguard
So I'm making small gifs out of a video and the client wants, for example, a 300x250.
So first I made a sequence in premiere with the exact width and height, and scaled down my images and text, and everything became super blurry. So I decided to work in a bigger sequence and then render it out to clients needs. BUT AGAIN, SUPER BLURRY. I can't find an option in premiere to set the down sampling technique used (like in PS there's bicube and so on).
Any tips how to make this work??
Sure build it "big" but export it at your desired resolution.  In your case, I suppose a sequence of 1200x1000 might be a good bet.
If you're making something that will ultimately be small, adapt your text for readability.  Preview your sequence while you're making it at 25%, for instance.
Thanks, yeah, I ended up 2x sometimes 3x my sequence. But still ended up with blurry end results after encoding. So I ended up encoding in same sequence width and height, then used a program called GIF Brewery, which had tons of more options while finalizing. They look great now, but hate when clients ask for weird ass deliverables. Last week I made 3 intro videos for Queen Latifah, Katie Couric and Madonna Badger for their talk at Cannes Lion and they asked me to send them 720p 0.6Mbps finals, I was like, uhhh okay?!
Well well, THANKS FUZZ
