jlev23 Posted May 20, 2013 Share Posted May 20, 2013 On 5/20/2013 at 6:28 PM, Bruno said: It's not only bullshit, it's also how most, if not all, of the (digital workflow) movies you ever watched were edited. Editors work with lower res files, often ugly looking with timecode and sequence/shot info printed on top. Once they have a picture lock, they replace only the used clips with the high res raw versions, and that's what you use for grading. Technology might catch up soon, but in the meantime editing raw files is cumbersome and hurts your editing workflow more than it helps. exactly, maybe OSCAR M. will see your statement and understand now why i was hoping we could still do a prores capture via hdmi, while recording raw, so that we could negate the transcoding process on set for the raw files, and have the editor to be able to start loading material in the morning after the shoot. thank you. Link to comment Share on other sites More sharing options...
Ernesto Mantaras Posted May 20, 2013 Share Posted May 20, 2013 On 5/19/2013 at 7:57 PM, AnotherDave said: I don't want to shoot raw only then to have to convert it to ProRes 422 to edit it... that is (excuse my french) bullshit. What is the point if I can't have it in my NLE? There's the option of converting the footage into CineformRAW and keep all of the RAW goodnes while keeping the file sizes down (around 5 times smaller, close to ProRes).http://cineform.com/products/gopro-cineform-studio-premium Link to comment Share on other sites More sharing options...
Shield3 Posted May 20, 2013 Share Posted May 20, 2013 Good afternoon Andrew. In this article you state: "Is the 4GB file size a limitation? Thankfully no, with future build of Magic Lantern you can go until the card is full as the 5D Mark III supports the more modern ExFat file system for larger files than 4GB. Already people have recorded long takes of raw video in a single 12GB file!" Isn't it true the neither the Windows/MAC version of raw2dng.exe support files over 4GB? I have read even with the "raw_rec.mo" file the allows recordings larger than 4GB that you need LINUX to extract the dng files. Link to comment Share on other sites More sharing options...
Bruno Posted May 20, 2013 Share Posted May 20, 2013 On 5/20/2013 at 7:05 PM, Ernesto Mántaras said: There's the option of converting the footage into CineformRAW and keep all of the RAW goodnes while keeping the file sizes down (around 5 times smaller, close to ProRes). RED gives you that kind of compression in raw, but you still need to use lower res proxies to edit it. On 5/20/2013 at 7:24 PM, Shield3 said: Isn't it true the neither the Windows/MAC version of raw2dng.exe support files over 4GB? I have read even with the "raw_rec.mo" file the allows recordings larger than 4GB that you need LINUX to extract the dng files. The mentioned solution is not about having files larger than 4gb, it's about having the camera create a new file automatically before reaching the limit, those files could later on be merged seamlessly. Some cameras already do this. Magic Lantern already does this with h264 files and their 12 minutes limit, even though in that case there's a few frames dropped in the process. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted May 20, 2013 Author Administrators Share Posted May 20, 2013 On 5/20/2013 at 7:24 PM, Shield3 said: Good afternoon Andrew. In this article you state: "Is the 4GB file size a limitation? Thankfully no, with future build of Magic Lantern you can go until the card is full as the 5D Mark III supports the more modern ExFat file system for larger files than 4GB. Already people have recorded long takes of raw video in a single 12GB file!" Isn't it true the neither the Windows/MAC version of raw2dng.exe support files over 4GB? I have read even with the "raw_rec.mo" file the allows recordings larger than 4GB that you need LINUX to extract the dng files. A developer's branch of code had the 4GB cut off disabled and a tester on the Magic Lantern forums recorded a 12GB raw file in one take. Yes Raw2DNG will need updating, all this is to come please be patient. That app was only put together about a week ago! Link to comment Share on other sites More sharing options...
Samir Posted May 20, 2013 Share Posted May 20, 2013 Andrew, Can you clarify? I just received a Komputerbay 64GB 1000x card and disapointed it drops out in 1920x1080p with globaldraw on. When I turn off globaldraw I am able to get up to the 4GB file recording but I have to have the audio not recorded. Are your cards experiencing the same or are you just skipping using the global draw and seperate wav file in camera? Thanks. Link to comment Share on other sites More sharing options...
letusa_play Posted May 21, 2013 Share Posted May 21, 2013 Hi Andrew, I was wondering if it is possible to simultaneously record a sequence of images on both cards in the Mark III? I think this could be a solution to reach larger image resolutions. You could spend 12 images to SD and 12 images to the CF from every second of shots. For the audio I do not see any problem. In a professional recording this recording with condenser microphones and external recorders and can be synchronized with a blackboard. Thanks. Link to comment Share on other sites More sharing options...
kabuto1138 Posted May 21, 2013 Share Posted May 21, 2013 So nobody has tried the Toshiba 1066x yet? I am thinking of buying one, just waiting for the first review on that, see if its worth it. Link to comment Share on other sites More sharing options...
Oscar M. Posted May 21, 2013 Share Posted May 21, 2013 LOL . . . The EOS 50D - an ancient camera back to life . . . Julian and Andrew Reid 2 Link to comment Share on other sites More sharing options...
Oscar M. Posted May 21, 2013 Share Posted May 21, 2013 On 5/20/2013 at 6:40 PM, jlev23 said: exactly, maybe OSCAR M. will see your statement and understand now why i was hoping we could still do a prores capture via hdmi, while recording raw, so that we could negate the transcoding process on set for the raw files, and have the editor to be able to start loading material in the morning after the shoot. thank you. OK for on set I understand. But for other "not time constrained" projects, why not grade first? which would be pretty easy with DNGs in AE or photoshop. All you have to do is grade one frame and AE will apply it to the rest of the sequence, then export your graded footage to ProRes for editing. The point is, for grading, ProRes just does not have the shadow/highlight recovery flexibility of RAW dng. I think though that Cinema DNG is the way to go for ML. Lee Mullen 1 Link to comment Share on other sites More sharing options...
Julian Posted May 21, 2013 Share Posted May 21, 2013 On 5/21/2013 at 11:55 AM, Oscar M. said: LOL . . . The EOS 50D - an ancient camera back to life . . . Only DNG burst so far, but I guess it should work in theory. This is going to be the biggest joke of all. Never liked the 50D... Now I will :) Link to comment Share on other sites More sharing options...
peederj Posted May 21, 2013 Share Posted May 21, 2013 On 5/21/2013 at 3:44 AM, letusa_play said: Hi Andrew, I was wondering if it is possible to simultaneously record a sequence of images on both cards in the Mark III? I think this could be a solution to reach larger image resolutions. You could spend 12 images to SD and 12 images to the CF from every second of shots. For the audio I do not see any problem. In a professional recording this recording with condenser microphones and external recorders and can be synchronized with a blackboard. Thanks. SD runs less than 1/5th the speed of UDMA7 CF. So you could maybe get a 10-15% speedup including the SD card in the writes. But better would be writing an IPB proxy to the SD card simultaneously. If that wouldn't tie up the CPU too much. And it's a clapboard or slate not a blackboard. Blackboards are written on with chalk in schools. Link to comment Share on other sites More sharing options...
jlev23 Posted May 21, 2013 Share Posted May 21, 2013 OK for on set I understand. But for other "not time constrained" projects, why not grade first? which would be pretty easy with DNGs in AE or photoshop. All you have to do is grade one frame and AE will apply it to the rest of the sequence, then export your graded footage to ProRes for editing. The point is, for grading, ProRes just does not have the shadow/highlight recovery flexibility of RAW dng. I think though that Cinema DNG is the way to go for ML. understood, but i only work on sets, so not understanding the context of the question i was asking you should of not of been so quick to say i dont understand raw, just be careful what you say to professionals on this forum, some people arent as nice as me :) Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted May 21, 2013 Author Administrators Share Posted May 21, 2013 LOL . . . The EOS 50D - an ancient camera back to life . . . http://vimeo.com/66622780 Wow 50D is looking very impressive, better than 600D. Ssshhh don't tell ebay!! Link to comment Share on other sites More sharing options...
Alexey Danilin Posted May 21, 2013 Share Posted May 21, 2013 So nobody has tried the Toshiba 1066x yet? I am thinking of buying one, just waiting for the first review on that, see if its worth it. I have 32GB Toshiba 1066x card. Unfortunately, dispite its price, it only allows 91MB/s read and 119MB/s write in 16384 blocks. And it sometimes skips frames in 1920x1080 24fps Link to comment Share on other sites More sharing options...
Oscar M. Posted May 22, 2013 Share Posted May 22, 2013 understood, but i only work on sets, so not understanding the context of the question i was asking you should of not of been so quick to say i dont understand raw, just be careful what you say to professionals on this forum, some people arent as nice as me :) Agreed. Wow 50D is looking very impressive, better than 600D. Ssshhh don't tell ebay!! The cheapest RAW Camera ever made! Link to comment Share on other sites More sharing options...
hmcindie Posted May 22, 2013 Share Posted May 22, 2013 The point is, for grading, ProRes just does not have the shadow/highlight recovery flexibility of RAW dng. I think though that Cinema DNG is the way to go for ML. That's funny considering how many projects have been shot with the Alexa straight to prores. And it has GREAT highlight/shadow dynamics. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted May 22, 2013 Author Administrators Share Posted May 22, 2013 Yeah and those same Alexa crews carry a generator and Arri suns 100m down the road, spending countless dollars to do so, then go and shoot ProRes. Madness. Link to comment Share on other sites More sharing options...
Brellivids Posted May 22, 2013 Share Posted May 22, 2013 I see few discussion threads around the web for hacking a connector from the pins inside the camera (cf pins) into a SSD or HHD. People seem to be confused in one thing and thinking that they could use regular IDE-harddrives. Where as in reality a IDE-harddrive is not even 80MB/s in consistent writing speed. I would only Tinker with a proper SSD like Samsung 830, 840 , Crucial M4, M500 series. The power draw of the SSD might a choosing factor as well. And when I had made up my mind about it.. Komputerbay 1000x 64GB CF cards are out from Amazon.de. Link to comment Share on other sites More sharing options...
dhallowell19 Posted May 23, 2013 Share Posted May 23, 2013 I'm starting with a KomputerBay 128GB 1000x CF card. At, say, 1280x720 I wonder if the pattern in the poor performance is a sign I'm missing something in the setup -- exactly every 37 frames acquired it drops a frame. I'd think there'd be a little statistical variation around that -- so I'd appreciate any tips, including 'the obvious' for things besides a lousy card that might be causing that. Thanks Dave H Link to comment Share on other sites More sharing options...
