chadandreo Posted June 26, 2018 Share Posted June 26, 2018 Hi, I am currently having a major issue with the combination of my GH5, Metabone .64x and Tokina 11-16mm. For some reason, the lens will only macro focus no matter what setting I use in manual and autofocus. I have been running this setup for over 3 years with a GH4 and GH5 with no issues until today. I have tested the camera with other lenses on the Metabone and they work fine and I have tested the Tokina on a Canon APS-C camera, and that also works as normal. Can anyone help me to resolve this issue ASAP since this is my only wide lens for my GH5. Thanks Link to comment Share on other sites More sharing options...
IronFilm Posted June 26, 2018 Share Posted June 26, 2018 That is very weird that you're having this problem even in manual focus?! As that should override everything else but your direct changes on the lens, so if manual focus was broken I'd expect it would be broken on the DSLR as well and not just the GH5 Link to comment Share on other sites More sharing options...
chadandreo Posted June 26, 2018 Author Share Posted June 26, 2018 Even in manual focus. My mind is boggled. Link to comment Share on other sites More sharing options...
JordanWright Posted June 26, 2018 Share Posted June 26, 2018 you need to adjust your infinity focus, Its harder to achieve infinity with wide lenses on the XL. Link to comment Share on other sites More sharing options...
webrunner5 Posted June 26, 2018 Share Posted June 26, 2018 Did you drop it, or hit it on something?? Link to comment Share on other sites More sharing options...
chadandreo Posted June 26, 2018 Author Share Posted June 26, 2018 8 hours ago, webrunner5 said: Did you drop it, or hit it on something?? Not that I know of. I used it at my house to show someone who is interested adding a gimbal to their arsenal and it worked as usual. The next day, I grabbed the same rig, which was still completely setup and when I tried to shoot, I noticed the issue. Edit: I just did a test with my 24L and im having the same issue. Link to comment Share on other sites More sharing options...
scotchtape Posted June 26, 2018 Share Posted June 26, 2018 Check the pins. One of mine was bent, and now stuck completely down. I emailed them on the weekend but they still haven't got back to me. I'm getting the viltrox since the optical quality is apparently the same as metabones, not sure if the focusing will be as "good". Link to comment Share on other sites More sharing options...
buggz Posted June 27, 2018 Share Posted June 27, 2018 I think you might need to flash an upgrade to your Speedbooster. I have a Tokina 11-16mm, Metabones 0.64XL Speedbooster, and GH5, works good. Link to comment Share on other sites More sharing options...
chadandreo Posted June 27, 2018 Author Share Posted June 27, 2018 I ended up using the method on their site about adjusting the glass for working with older lenses and it got the camera back to being useable. Now, the focus range seems to be off with varying focal lengths. Thanks Link to comment Share on other sites More sharing options...
JordanWright Posted June 27, 2018 Share Posted June 27, 2018 I set mine for my widest lens and then my others go slightly past infinity, but its no big deal! Link to comment Share on other sites More sharing options...
