KarimNassar Posted May 20, 2013 Share Posted May 20, 2013 Hello everyone, I started testing my 16F on my red one mx. The 4k anamorphic mode is quite handy, gives the correct aspect ratio with the 2x squeeze of the 16f. And it directly feeds desqueezed footage out of the camera no need for a monitor that has this function. Tested on the 50mm and 85mm. Need to see if it is possible to go lower. It should be because there is a 3k and 2k anamode that crops into the sensor so I feel like even if 28mm shows vignetting at 4k, it might not at 3 or 2. Here is the first vid shot with the 4k ana mode: https://vimeo.com/66549568 This one was shot with the 4k widescreen mode, giving a wider aspect ratio. And a close to 9k image when desqueezing horizontally... https://vimeo.com/66459473 dahlfors, Sean Cunningham and Julian 3 Link to comment Share on other sites More sharing options...
Jorge De Silva Posted October 23, 2013 Share Posted October 23, 2013 I love this stills! Ana :wub: hahah Link to comment Share on other sites More sharing options...
