Ron Posted February 27, 2012 Share Posted February 27, 2012 Been a still shooter for over 40 years but I'm very new (and very green) to DSLR video but the GH2 shooters guide has really provided a wealth of information. I found 28mm 2.8 FD and a 50mm 1.8 FD in great shape on eBay for almost nothing. The Ciecio adapter just arrived from Poland and both lenses mount to the camera just fine but I'm not sure if I should be able to stop down the aperture (it stays wide open) or if I have to shoot this way. Any suggestions? Link to comment Share on other sites More sharing options...
Francisco Rios Posted February 28, 2012 Share Posted February 28, 2012 Ron, the adaptor has a ring to move. When you put the lens on , the ring has to be on one position and after the lens is on , you move the ring back. My adaptor has two position Lock and open. Take a look on these and you will have control on the iris, otherwise the lens will be always open. Cheers. Link to comment Share on other sites More sharing options...
davidp158 Posted April 18, 2012 Share Posted April 18, 2012 Hi Ron. I purchased some old Canon FD lenses and use a really cheap ($20) adapter off of ebay. The adapter worked fine with my Canon FD 50mm lens, but the aperture of my Canon FD 28mm lens would get stuck wide open. I noticed a lever on each lens that gets pushed into position when connected to the adapter. My adapter has a very small screw that engages this lever. On my 28mm lens, the screw was just a bit too small to make good contact. After searching for a longer screw and not finding one, I gently bent the lever, and now it works fine. I wouldn't have done this with an expensive lens, but as the 28mm only cost me $40, I wasn't too concerned. Suffice to say the better adapters are probably made to much higher tolerances, and this probably wouldn't have been an issue. cheers, Dave Link to comment Share on other sites More sharing options...
texcam Posted April 19, 2012 Share Posted April 19, 2012 i had this same problem with my adapter. there is a little metal finger that sticks up. You have to slide this to the side and hold it there as you put the lens into the adapter. Then the aperture works perfectly on the lens. strange but true ;) Link to comment Share on other sites More sharing options...
