jaquet Posted August 9, 2018 Share Posted August 9, 2018 I found out that using the 1080i (HDMI Rec Output) mode for external monitoring the delay/lag is almost invisible compared to the 1080p mode (5frames delay on a smallHD 502B). BUT - If you switch from 25p to HFR (75-100fps) and have a HDMI monitor attached - the cam freezes after 5sec recording. I tried the same setting with a brand new cam in a shop and the bug is the same. So sadly no monitoring without delay when using HFR mode. Hope Panasonic can fix it! Link to comment Share on other sites More sharing options...
