no_connection Posted August 16, 2018 Share Posted August 16, 2018 I jumped in when someone was accused of being wrong when there statement was correct, but I guess you rather have ppl being wrong than argue right? If you intentionally misrepresent what I wrote as an example and intentionally use it to miscredit me then I guess I really don't have any more to say. Link to comment Share on other sites More sharing options...
seanzzxx Posted August 23, 2018 Share Posted August 23, 2018 *edit: wrong thread. Link to comment Share on other sites More sharing options...
Rinad Amir Posted August 23, 2018 Share Posted August 23, 2018 25 minutes ago, seanzzxx said: I'm hijacking this thread to ask: how do you expose your 400mbps V-log? I'm renting this camera in a bit and just looking to make sure everything is in place. I generally over-expose Sony camera's by two stops, is this still necessary with the 10-bit 4:2:2 codec? I know I never felt the need with Blackmagic camera's for example, but if I don't over-expose Sony camera's the noise will get insane. Best way is to enable Waveform option Try keeping your IRE in mid 75 and you should be ok Link to comment Share on other sites More sharing options...
interceptor121 Posted June 27, 2019 Author Share Posted June 27, 2019 As I started this mess I wanted to give an update some time later AVC-I at 400 Mbps beats the xxxx out of ProRes 422 and I could not see any difference to ProRes 422 HQ at naked eye and pixel peep Looking for explanations I believe is due to two things 1. intraframe predictive coding on 16x16 blocks that achieves high level of compression than standard discrete cosine transform in ProRes 2. CABAC entropy encoding squeezing additional bits without loss in the clips It is difficult to average what the benefits are compared to ProRes but is not difficult to see that they are at least 30% based on perceived quality As there are no fast enough SD cards this is limited to 30p on the GH5 but in terms of non RAW capture this appears to be very good And with this I think I have closed the case I opened myself KC Kelly, sanveer, Volumetrik and 2 others 3 1 1 Link to comment Share on other sites More sharing options...
Video Hummus Posted June 28, 2019 Share Posted June 28, 2019 The 200Mbps ALL-I @ 1080p codec is quite stellar. It’s only 1/2 the bitrate of the 400 but at 1/4 the resolution of 4K, so the compression ratios are quite good. 23 hours ago, interceptor121 said: 1. intraframe predictive coding on 16x16 blocks that achieves high level of compression than standard discrete cosine transform in ProRes 2. CABAC entropy encoding squeezing additional bits without loss in the clips And this is why comparing codecs is so hard. I’m not sure if this has been posted before: https://pro-av.panasonic.net/en/sales_o/p2/concept/img/technology.pdf But it basically restates what @interceptor121 did above. Even the AVC-Intra is very efficient when dealing with I-frames due to predictive algorithms in I-frames and near optimal adaptive CABAC encoding. I think it’s here where the 400Mbps is misleading and why I think wolfcrows conclusions are wrong. Link to comment Share on other sites More sharing options...
