francescosabphoto Posted August 28, 2018 Share Posted August 28, 2018 Hello everyone , I recently saw on a website someone selling his 18-55 kit lens for 25$ - very interesting even if this lens costs only 100$, because I'm not really going to use it a lot. The seller said that this lens didn't work under 24mm , and that the error "error of communication between lens and dslr - please check lens contact" appeared if he tried to set a focal lenght under 24mm. Although I don't think it will be a problem for me, do you think this kind of error is repairable easily ? Thanks for your help Link to comment Share on other sites More sharing options...
webrunner5 Posted August 30, 2018 Share Posted August 30, 2018 No it is not repairable easily. Now maybe His camera needs to have the contacts cleaned, and it Might work on your camera. For that kind of money, if you don't already have that lens sure it's worth it. Link to comment Share on other sites More sharing options...
Mako Sports Posted August 30, 2018 Share Posted August 30, 2018 18 - 55 kit lens isn't even worth the time to get it fixed, if the lens had good image quality then sure. Link to comment Share on other sites More sharing options...
noone Posted August 31, 2018 Share Posted August 31, 2018 Unless it was all you can find/afford, I would pass on it as 18-24 is a fair size chunk of focal range to go without and limits you to around 39mm FF equivalent and up if using Canon or 36mm FF equivalent for Sony/Nikon/Pentax (assuming APSC use). The lenses can be found very cheap if patient. If it is Canon and you just want a lens, maybe look at pawn shops and on line for old EOS film cameras as they often have a fully working EF lens attached for very little money (though probably not stabilized and probably starting at 28mm but will give longer range and less likely to stop working all together). Ask friends and family if they know anyone who has an old camera of the same make as yours sitting around unused that might have a lens or two you can use. It would cost a LOT more than the lens is worth to fix it unless it is something like simply dirty contacts on the camera. Link to comment Share on other sites More sharing options...
IronFilm Posted August 31, 2018 Share Posted August 31, 2018 Offer him $5, that is what it is worth. tigerbengal 1 Link to comment Share on other sites More sharing options...
maryjunjun08 Posted September 5, 2018 Share Posted September 5, 2018 I do not think it's worth worrying about. You can find out more about old camera stores, and they can help you. gomovies Link to comment Share on other sites More sharing options...
maryjunjun08 Posted October 15, 2018 Share Posted October 15, 2018 On 9/5/2018 at 11:01 AM, maryjunjun08 said: I do not think it's worth worrying about. You can find out more about old camera stores, and they can help you. gomovies jonpais 1 Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted October 15, 2018 Share Posted October 15, 2018 Show me who is selling it for $25 I'll buy it. serious message me? Link to comment Share on other sites More sharing options...
